| 913B |
Sep 5 2016, 08:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 877 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
The brake switch on my master cylinder has 2 wires. I didn't see any reset button. When I unplug the brown/white signal wire going to the brake light in the gauge. The brake light will respond accordingly to the hand brake and go out. Before it would stay lit all the time regardless if the handbrake was applied or released.
So the question is how do you reset the brake switch or do I need to bleed the brakes ?? The brake light was working fine until the transport company moved my vehicle. I think the driver may have applied the brakes too hard maybe (IMG:style_emoticons/default/confused24.gif) Let me know you thoughts. Thanks everyone ! (IMG:style_emoticons/default/driving.gif) |
| Krieger |
Sep 5 2016, 09:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,861 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
The reset is on the left side of the master cylinder. You can get at it without lifting the car. Turn the steering wheel all the way to the right. Get a flashlight. It is a small rubber protusion maybe 5mm on the left side. Just push it back in. You also might want to check the switch under the handbrake. It is on the crossmember. It may be stuck, broken or corroded. It is also possible the handbrake is not making contact with the switch and is not pushing the switch down when you put the brake handle down. My gauge light flashes red when the e-brake handle is up.
| 913B |
Sep 5 2016, 10:03 PM
The reset is on the left side of the master cylinder. You can get at it without lifting the car. Turn the steering wheel all the way to the right. Get a flashlight. It is a small rubber protusion maybe 5mm on the left side. Just push it back in. You also might want to check the switch under the handbrake. It is on the crossmember. It may be stuck, broken or corroded. It is also possible the handbrake is not making contact with the switch and is not pushing the switch down when you put the brake handle down. My gauge light flashes red when the e-brake handle is up. Is it on the switch itself ?? I don't suppose someone has a pic ? I even took the wheel out and didn't see any switch though? I want to fix it so I can pass my vehicle inspection for my registration. |
| 913B |
Sep 5 2016, 10:06 PM
The reset is on the left side of the master cylinder. You can get at it without lifting the car. Turn the steering wheel all the way to the right. Get a flashlight. It is a small rubber protusion maybe 5mm on the left side. Just push it back in. You also might want to check the switch under the handbrake. It is on the crossmember. It may be stuck, broken or corroded. It is also possible the handbrake is not making contact with the switch and is not pushing the switch down when you put the brake handle down. My gauge light flashes red when the e-brake handle is up. The handbrake part works fine. With the signal wire that goes to the gauge disconnected. The handbrake operates the brake light fine. Thanks for tip |
| Krieger |
Sep 6 2016, 09:33 AM
Post a pic of your master cylinder
| North Coast Jim |
Sep 6 2016, 12:02 PM
Member ![]() ![]() Group: Members Posts: 345 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
The brake switch on my master cylinder has 2 wires. I didn't see any reset button. When I unplug the brown/white signal wire going to the brake light in the gauge. The brake light will respond accordingly to the hand brake and go out. Before it would stay lit all the time regardless if the handbrake was applied or released. So the question is how do you reset the brake switch or do I need to bleed the brakes ?? The brake light was working fine until the transport company moved my vehicle. I think the driver may have applied the brakes too hard maybe (IMG:style_emoticons/default/confused24.gif) Let me know you thoughts. Thanks everyone ! (IMG:style_emoticons/default/driving.gif) Just reworked my entire brake system with help from PMB Performance. Replaced the master cylinder as well. I too had the persistent "brake" light flashing/alarm and didn't know how to remedy the situation. Was told by Eric at PMB that I needed to reset the switch. Since I had the car up on stands I could easily get to the master cylinder again. Removed the boot protecting the two electrical wires. Adjacent to the two electrical posts is the switch, not really a switch since all you have to do is push it in. It is only a protrudence of plastic and not easily recognized as a switch. Push on it while the key is turned to the on position. You will hear the cessation of the brake alarm. The brake light will stop blinking. Easy. I've had to do this twice now once with the car on the ground. |
| Kansas 914 |
Sep 6 2016, 12:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
It is the black "shaft" in this picture.
| 913B |
Sep 6 2016, 01:07 PM
I wish I had a pic of my switch the center part is like a plastic divider. It is slightly different design than yours (IMG:style_emoticons/default/sad.gif)
| 913B |
Sep 8 2016, 09:36 PM
So I have come to the conclusion there is no reset button on the early 2 wire brake switch.
I even tried reversing the connections, but no such luck, The short term fix is leaving the brown/white signal wire unplugged from the switch. The brake light on the gauge will only be controlled by the hand brake lever. The long term fix is next time I am under the vehicle. I'm going to swap out the switch with the single pole type with the reset switch. That is my update for now. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
| Garland |
Sep 8 2016, 10:20 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I have the same concern, have left the one wire loose. I think the switch is bad. Going to replace it with a 2 pole switch.
| 913B |
Sep 8 2016, 10:41 PM
you want to switch to 2 pole ?? You mean to replace it with 1 pole with the reset button ?
| Garland |
Sep 8 2016, 11:36 PM
| Dave_Darling |
Sep 9 2016, 09:55 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,345 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I have a two-pole switch with a reset button...
My understanding is that the switches without reset buttons do not "latch", so that when the pressure balance is removed they turn off themselves. Do you have a good photo of your switch? --DD |
| NoEcm |
Sep 9 2016, 10:35 PM
Member ![]() ![]() Group: Members Posts: 95 Joined: 20-June 05 From: Seattle, WA Member No.: 4,309 |
I just installed a new single pole switch because the old one was leaking brake fluid.
The defective one had a little reset button you you could depress. The new switch that I just installed does not have a reset button. Pictured below is the defective switch that I purposely tripped for this thread. Push the little nub back in and the switch gets reset. ![]() |
| 913B |
Sep 11 2016, 04:50 PM
Thanks everyone for the contributions. I want to see the reset sw on the 2 pole type if there is such a thing ?
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
| Kemo |
Jun 13 2026, 01:02 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 8-February 06 From: Austin, TX Member No.: 5,546 |
im bringing up this old thread because im having a few issues with a blinking red light in the dash above the fuel level.
ive been banging my head against the wall on this one. i have a 1973 1.7 and i have a 2 pole brake switch that does not have a reset. i have two wires plugged into it and if i pull them out it makes no difference. so my fasten seatbelt light is on when the brake is down or up...its real iintermittent as im moving the brake up and down. but it goes out when buckled. on the back of the cluster, if i pull the "black/white stripe/green wrap stripe" wire, the blinking stops and the fasten seatbelt light continues to work until buckled. any ideas here? i did recently replace the soft lines and one hard line and bleed the brakes. thanks for any help, just trying to get the electrical sorted out before attempting to get the motor in there. |
| emerygt350 |
Jun 13 2026, 01:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,636 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
im bringing up this old thread because im having a few issues with a blinking red light in the dash above the fuel level. ive been banging my head against the wall on this one. i have a 1973 1.7 and i have a 2 pole brake switch that does not have a reset. i have two wires plugged into it and if i pull them out it makes no difference. so my fasten seatbelt light is on when the brake is down or up...its real iintermittent as im moving the brake up and down. but it goes out when buckled. on the back of the cluster, if i pull the "black/white stripe/green wrap stripe" wire, the blinking stops and the fasten seatbelt light continues to work until buckled. any ideas here? i did recently replace the soft lines and one hard line and bleed the brakes. thanks for any help, just trying to get the electrical sorted out before attempting to get the motor in there. The switch for the parking brake is down on the floor under the parking brake lever. Fills with garbage over the years. Pull the driver seat and clean it up... |
| emerygt350 |
Jun 13 2026, 01:19 PM
Lo-Fi Version | Time is now: 13th June 2026 - 02:57 PM |
