| 914werke |
Sep 9 2016, 02:02 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,746 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
| 914werke |
Oct 25 2017, 09:03 AM
Attached thumbnail(s) |
| DRPHIL914 |
Oct 26 2017, 06:47 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I am interested in getting one of these, but what type of tow bar do you use for the rest of it? I had a Blue Ox tow bar we used for towing our truck behind a RV- would it be some thing like that?
| 914werke |
Oct 26 2017, 09:24 AM
I believe so. Also available from Draw Tite, Reese & others.
Example: Attached image(s)
| Lucky9146 |
Dec 4 2017, 02:02 PM
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,711 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California
You show a picture of the bar but a picture of it actually mounted on a 914 might really help! Interested.
(IMG:style_emoticons/default/white914.jpg) |
| 914werke |
Jan 23 2018, 01:22 AM
Ya its been on my list ... will work on that directly.
| pilothyer |
Apr 4 2018, 08:53 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
How, Exactly, does it attach to the car ????? |
| 914werke |
Apr 5 2018, 08:33 AM
Like this
| 914werke |
Apr 5 2018, 08:38 AM
I'm shocked it's still available. I assumed Featured Items sold fast! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/rolleyes.gif) They typically do. This is into my 2nd run of these. I never expected this to be a huge sell'er. The rub is as the cars become more valuable more folks are trailering thier 914's (IMG:style_emoticons/default/sunglasses.gif) |
| Boomingbeetle |
Apr 19 2018, 04:22 PM
Member ![]() ![]() Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
PM Sent
| 914werke |
Apr 23 2018, 07:07 PM
WCR is fast approaching (IMG:style_emoticons/default/smile.gif)
If you are planing on towing ....here's a option! Attached image(s)
| jkb944t |
Apr 24 2018, 06:13 AM
Member ![]() ![]() Group: Members Posts: 470 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
How well does it tow using this method? Do you leave the car in neutral and leave the steering wheel unlocked so it finds its center?
Jeff B |
| 914werke |
Apr 24 2018, 10:03 AM
How well does it tow using this method? Do you leave the car in neutral and leave the steering wheel unlocked so it finds its center? Jeff B You got it. I logged a LOT of miles with various 914's flat towing. Pulling with everything from a Ranger to an RV. Current tow rig is a 05 F150 (IMG:style_emoticons/default/smile.gif) No Problems. |
| strawman |
May 2 2018, 04:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 892 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
What are the three bolts on each side for? And how much shipped to 93401?
| 914werke |
May 2 2018, 11:02 PM
Those are the included mounting hardware.
Due to the added dimension of the bracket the bolts need to be longer + the front mount. There are mounts welded to the bracket so the bolts & spacer don't get lost when not in use. (IMG:style_emoticons/default/smile.gif) |
| loux951 |
Jun 25 2018, 09:01 AM
NOLA 914 ![]() Group: Members Posts: 35 Joined: 30-May 03 From: New Orleans, LA Member No.: 758 Region Association: South East States |
Will it clear a standard front valance? If you can send/post a pic of one on a car with the standard valance you will have yourself a quick sale!
(IMG:style_emoticons/default/aktion035.gif) |
| 914werke |
Jun 25 2018, 09:26 AM
If you are asking if you can tow with the OE valance in place, Sorry you can not.
Because the orig. standard valance curves back under the car it actually covers the the suspension pickup points where he bracket mounts. I had been playing with a way to more easily remove & reinstall any valance. You have to unscrew 6 fasteners (4 in the Frunk 2 in the wheel wheels) the screws in the front trunk are easy and Dzus fasteners work perfectly there , but the two 8mm bolts that retain the far ends of the valance are tougher as there is very little room there for a quick release mechanism. I currently have a pair of cleco's in those spots which work but dont have the positive locking or small /low profile Im after. |
| loux951 |
Jun 25 2018, 01:00 PM
If you are asking if you can tow with the OE valance in place, Sorry it will not. Because the orig. standard valance curves back under the car it actually covers the the suspension pickup points where he bracket mounts. I had been playing with a way to more easily remove & reinstall any valance. You have to unscrew 6 fasteners (4 in the Frunk 2 in the wheel wheels) the screws in the front trunk are easy and Dzus fasteners work perfectly there , but the two 6mm screws that retain the far ends of the valance are tougher as there is very little room there for a quick release mechanism. I currently have a pair of cleco's in those spots which work but dont have the positive locking or small /low profile Im after. Darn it...that thing is awesome. Time to start looking for an aftermarket front valance! |
| 914Toy |
Jun 25 2018, 01:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
PM sent.
| a9146luvr |
Jun 26 2018, 11:08 PM
Member ![]() ![]() Group: Members Posts: 55 Joined: 2-January 04 Member No.: 1,495 Region Association: None |
did this ever sell?
Lo-Fi Version | Time is now: 15th September 2026 - 12:21 PM |
