V-8 question, later style water pumps |
jwalters |
Apr 16 2005, 11:50 AM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) To the V-8 gurus out there--I know the standard mod is a stand alone water pump--but what about the low profile pumps on very late chebbies--they are very small and compressed--would it still need to be removed and replaced with a stand alone??
skline |
Apr 16 2005, 11:53 AM
Show me a picture and I will be able to tell. If it is belt driven, most likely it will not fit.
jwalters |
Apr 16 2005, 11:58 AM
sorry no pics--but I am guessing it is lt-1 style--where it is driven directly off the cam--I know for a fact it has no belt to it--hope it helps out-- |
Chris Julian |
Apr 16 2005, 12:14 PM
Member Group: Members Posts: 159 Joined: 19-March 04 From: SF Bay area Member No.: 1,821 |
HI, basically on the typical swap there is just no room for the pulley that would mount to the balancer. that's why we use a grooved balancer. Unless you relocated the motor back towards the rear of the car, but then the angle of the half shaft may be too extreme.
Chris |
Brent |
Apr 16 2005, 05:56 PM
Every month is Oktober Group: Members Posts: 1,360 Joined: 16-December 04 From: North San Jose Member No.: 3,291 Region Association: Northern California |
My V6 conversion package has a pump with a shortened shaft, had it rebuilt once and cost about $80 about 10 years ago.
ajracer |
Apr 24 2005, 12:26 PM
Member Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
Greetings jwalters:
Let me share my thoughts and experience since I HAVE an Chevy LT1 going into my 914 as we speak. My research and calculations and measurements conclude the following, based on the standard location of the V8 into the 914 engine bay. Thus using the engine mounting bar or RSH type mounts: 1/ The V8 engine fits fine with the "old style" Chev 6 cyl. harmonic balancer with the twin pulley for the external mounted water pump and alternator. 2/ The LT1 with the OEM water sticks (with internal spline gear drive) out too far from the front of the engine, by about three inches. In addition IF you tried to use the Opti Spark ignition system then you are really in trouble because it sticks out another 2 -3 inches more. 3/ The next question revolves around the Bottom crank flange, OEM type harmonic balance/pulley combination (which is serpentine belt), this unit sticks out a total about 5+ inches from the block and into the firewall of the 914 according to all my measurements and mock ups, before I concluded that the stock OEM water pump and opti spark along with he bottom flange were GONE and would not work "without" extensive modifications to the firewall and surrounding area. Conclusion for me: go with the “old style” V8 set-up which meant replace front bottom pulley with the GM 6 cyl. Unit, exterior mount water pump, delete opti spark/water pump and seal up the timing cover holes. Then I decided (for now) to use a GM performance LT1 intake manifold with the traditional rear mounted distributor hole for ignition system. Solution everything fits and should work fine. I have posted A progress thread under “Project 914-LT1 Canadian V8 conversion” If you have any specific questions feel free to ask, and I will give my experience and reasons for various decisions. Good Luck with your project and enjoy the pride of doing it yourself. Allan ps. Attached Photo of my friends Lamborghini, which shows the engine into the passenger compartmnt. But this is a larger passenger compartment than our 914's and thus they have room, an engine cover goes over this area and is next to the drivers arm rest. Attached image(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 07:23 AM |
