> Targa Horizontal Trim, how do you remove?
STL914
post Apr 16 2005, 01:53 PM
I need some HELP!!
I'm removing the aluminum targa trim from my car, both vertical pieces are off. Is there some trick to removing the horizontal piece from the targa bar? Do I need to delicately pry it from some mounting tabs?
I did a search on the site with no luck, so I decedied to post a request for help from you guys .
Thanks,
Porsche Rescue
post Apr 16 2005, 02:37 PM
Saving and Enjoying Old Porsches
It is held on with 3 or 4 spring clips. You carefully pull/pry straight back to the rear of the car.
McMark
post Apr 16 2005, 04:21 PM
914 Freak!
Pull. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
jasons
post Apr 16 2005, 07:14 PM
Jackstand Extraordinaire
You can actually reach up through the rear wheel well and pinch the clips so they pop out easier. You may not be able to do this for the one closest to the door however.
STL914
post Apr 17 2005, 10:57 AM
Thanks guys, I got it done! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 06:33 AM
