Alternator assistance |
Luke15 |
Sep 19 2016, 05:54 AM
Newbie Group: Members Posts: 10 Joined: 6-August 16 From: Baltimore Member No.: 20,268 Region Association: None |
H- My 1972 914 (1.7) just had a light pop up on the dashboard with a circled "g" on it. I know that means there is something wrong with my charging system.
I am hoping it does not need a new alternator as I understand the labor for this is quite expensive. What is my case scenario to fix this? How do I know if I really need an alternator? If I do, does my mechanic have to drop the engine to fix it? Thanks. |
wndsrfr |
Sep 19 2016, 06:14 AM
Senior Member Group: Members Posts: 1,444 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
H- My 1972 914 (1.7) just had a light pop up on the dashboard with a circled "g" on it. I know that means there is something wrong with my charging system. I am hoping it does not need a new alternator as I understand the labor for this is quite expensive. What is my case scenario to fix this? How do I know if I really need an alternator? If I do, does my mechanic have to drop the engine to fix it? Thanks. Check to see if the belt is still spinning the alternator....with the engine OFF you can feel the belt tension reaching in the front of the fan opening.... |
Lo-Fi Version | Time is now: 17th January 2025 - 08:13 PM |
