dgraves |
1974 914 2.0 ![]() ![]() Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains ![]() |
As I continue the refurbishment of my '74 914, I notice that the floor pan inside the car has some kind of a 3/16" protective coating. Parts of this have chipped away. Does anyone have a substitute application to patch and restore the floor pan?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,767 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
It's basically a tar pad. They are known to have hidden and even promoted rust by holding water. Others have used Dynamat, and Home depot actually has the material inexpensively. The question is do you want to put it back in, once you have removed it.
dgraves |
Thank you. Luckily, the car is pretty rust free amazingly enough. So, I thought re-establishing it would be a good thing. It appears that it was applied right over the bare metal and then the stock/original paint applied over it. Do you know what was used in the areas where the floor met the side walls?
It's basically a tar pad. They are known to have hidden and even promoted rust by holding water. Others have used Dynamat, and Home depot actually has the material inexpensively. The question is do you want to put it back in, once you have removed it. |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,951 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Do you know what was used in the areas where the floor met the side walls? Factory seam sealer. Lots and lots of factory seam sealer. Taking out that tar board is a worthwhile but time-consuming project. I think getting that stuff out of the car is a good idea. As Mark said, you can put something in its place for sound dampening (like dynamat). Do a search here for tarboard threads and you'll see how people handled removing this stuff and what they did (or did not do) to replace it. I remember Scotty advising to put dynamat (or something similar) except in the low spots on the pan where water could collect. |
Mikey914 |
If you really want to protect it, I'd have it coated with bed-liner. If you really want the OEM look, put the tar over it. You can easily cut yourself, but protect the metal.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,090 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
It appears that it was applied right over the bare metal and then the stock/original paint applied over it. This is the problem with it. Water gets under the tar and ust starts since the metal is not painted or primed or sealed. You can't see the rust because the tar is so thick. Many here have found lots of rust under the tar when they though there was little or no rust there. Jim |
slotty008 |
Member ![]() ![]() Group: Members Posts: 192 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None ![]() ![]() |
It's a pain to remove the tar coating . But I think you really should do it , because the rust gets underneath. I'm in the course of doing it right now; takes a lot of time. Afterwards I'm gonna put 2 coats of zinc paint on the metal and then a layer of Dynamat.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,965 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
ndfrigi |
Mr.Nobody |
Member ![]() ![]() Group: Members Posts: 133 Joined: 24-March 15 From: San Diego, Ca Member No.: 18,557 Region Association: Southern California ![]() ![]() |
What are people's thoughts on the best way to remove the tar?
Does the dry ice trick work? Or is this a grinder type of operation? |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
Heat gun and large screw driver or chisel worked for me. Came off in big chunks.
stevegm |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States ![]() ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
$39 multi tool at Harbor Freight. It cuts the tar out like hot butter. 80% less time and mess of a heat gun
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
My .02c.
Heat gun and multi-tool or air chisel. Your using the heat gun to break the adhesive bond, not melt the tar. So the heat gun is going on and off the field of material. Works for me ................. |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,843 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
My .02c. Heat gun and multi-tool or air chisel. Your using the heat gun to break the adhesive bond, not melt the tar. So the heat gun is going on and off the field of material. Works for me ................. Same reason some guys use dry ice. Breaks the adhesive bond. |
cary |
I plan to try that on the next race car strip down.
74ravenna |
Member ![]() ![]() Group: Members Posts: 472 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States ![]() ![]() |
I hate to ask but does anyone know what the "tar" consists of?
Has anyone had it tested? In my industry tar coating is usually asbestos. Asbestos is added for strength and corrosive protection. I can't imagine they would've needed asbestos in the mix, but it was the 70s. I'm guessing I'm going to catch hell for this question but my concern isn't so much for me as it is for you and your family members (who am i kidding, actually i am concerned for me too). Steve |
74ravenna |
Did porsche use this method of coating on the 911s also?
rmdinmd |
Member ![]() ![]() Group: Members Posts: 489 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
As long as the fibers don't float in the air you are fine. if sanding or wire wheeling wear a dust mask. like many things a one time encounter isn't going to hurt you. sort of like a sunburn; one probable won't cause cancer, keep getting sunburns a lot and good chance it might. (IMG:style_emoticons/default/beer.gif)
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
If you don't want to to use an adhesive backed sound sheet for fear of water entrapment, consider something like Spectrum or Spectrum Sludge
http://store.secondskinaudio.com/spectrum/ I used Spectrum on a VW Bug pan over 10 years ago and it's still going strong. I used a brush to apply multiple coats after I had completed all rust repairs and primed the pan. Definitely got rid of the tinniness of a bare metal pan. |
Lo-Fi Version | Time is now: 19th April 2025 - 05:45 PM |
