mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,545 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Looks great.. Keep the updates coming.
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Closing in on closing it in! A few more pieces to fab then it's time for riveting and welding. That is looking great. For detail you need to bead in something. (IMG:style_emoticons/default/confused24.gif) what I do not know. If you are wishing to run down a deep habit hole, there is so much you can do with a bead roller. From the simple, to the extreme. ![]() Not sure I would waste the days doing something that intricate, but I would add a few just to get rid of any possible tin can effects. I want to see the car on the road, and the huge smile on your face when it is done. |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,550 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Stephen - I was thinking of a crest on the front section of the removable fire wall panel. Probably not bead rolled...! (IMG:style_emoticons/default/wacko.gif) I'm no where near skilled enough for that.
However, since I'm clearly in no hurry to get it running ( (IMG:style_emoticons/default/av-943.gif) ), I stayed with my "hmmm, I don't like that/think I'll do it over" approach. As I'm working on the fire wall, I'm not liking the corners - too sharp an angle. To my eye, it conflicted with the nice, soft 1" round tube edges of the rest of the console... So... I wasn't sure I could pull it off (and I've only done one corner so the final outcome remains to be seen) but I went "full fiddly" and worked out the necessary angles, cut the appropriate shape and did my first "around a corner" bead. Then I had to (IMG:style_emoticons/default/sawzall-smiley.gif) and bend and trim and (IMG:style_emoticons/default/smash.gif) tweak, but I think it looks LOADS better and keeps a consistent theme with the rest of the corners. Here's the before and after. I still need to weld and finish that clipped area but: What say you? Attached thumbnail(s) ![]() ![]() |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Oooh. I like that! Nice touch. (IMG:style_emoticons/default/aktion035.gif)
914forme |
If you look closely the basics of the crest are bead rolled the rest was etched / scribed. So lay out the shield and a couple of the center dividers and then "cheat" a little and laser etch, acid etch, or CNC the other sections for the look you want. Or cheat the entire thing take it to the beach find an air brush artist and have them brush the crest in. Since you have a CNC plasma cutter it would be a lot faster the plasma the details out, TIG them on in the best dime stack you can muster and just clear coat it out for the world to see. (IMG:style_emoticons/default/aktion035.gif) |
tygaboy |
I keep being distracted by the fire wall work. I want to get the engine to the dyno guys and all that it needs is to finalize the muffler mount. So...
If this isn't "getting jiggy wi't it", I don't know what is! (IMG:style_emoticons/default/lol-2.gif) Yes, seriously. This really is the fixturing craziness that I came up with. Attached thumbnail(s) ![]() |
tygaboy |
Almost there...
tygaboy |
Sorta like this. I still have to add a flange all around the plate to stiffen it up but you get the idea.
tygaboy |
Once the mount is complete, tabs get added to the muffler.
A couple small items after that then the motor comes out and I can get back to work on the chassis and all the remaining sheet metal, Tangerine Racing rear pick up points and the last parts of the rust repair. Still a ways to go... Attached thumbnail(s) ![]() |
motoTrooper |
Newbie ![]() Group: Members Posts: 39 Joined: 18-March 16 From: Palo Alto Member No.: 19,774 Region Association: None ![]() |
Nice progress there, I'd have been happy with the beaded corners but the radius is nicer to inadvertently bump against. That muffler bracket is lovely.
I've been finally able to spend some time looking at those roof panel pieces and figuring out how to mount one... |
tygaboy |
That earlier version of the muffler bracket plate simply wouldn't do. A little plasma table and some added style points.
Still need to finish welding but you get the idea. It's not real light, but it likely won't ever fail! (IMG:style_emoticons/default/laugh.gif) Attached thumbnail(s) ![]() |
914forme |
Chris that looks great, nice design and artwork all in one.
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,839 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Chris that looks great, nice design and artwork all in one. (IMG:style_emoticons/default/agree.gif) In with Stephen on this. Couldn’t say it better. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Dang Chris, you need to be a designer at Bugatti or Pagani....nice
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,000 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Dang Chris, you need to be a designer at Bugatti or Pagani....nice If you’re interested in doing the design thing at Bugatti, the head of designs daughter goes to school with my youngest. He is a Porsche fan too. Achim Ansheit? https://m.youtube.com/watch?v=eAY5fRglsb4 |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
That earlier version of the muffler bracket plate simply wouldn't do. You and I simply do things so much differently (IMG:style_emoticons/default/smile.gif) Good enough just isn't in your vocabulary (IMG:style_emoticons/default/wink.gif) |
tygaboy |
Thanks for the kind words, gents. It does help with the motivation.
Back to the fire wall. I wasn't happy with any of my ideas for closing in the upper portion because they all seemed to conflict with the 1" round edges of the console. So I took a step back and tried to get a clean slate in my head about what this should look like. Here's the latest: Continue the console all the way up to the top! Still a few things to work out and, as always, it's not over til it's over but I think I like this better. The front of it will still be removable for access. Attached thumbnail(s) ![]() ![]() |
tygaboy |
I needed a break from the fire wall. The chassis has a few more spots that need rust repair so I figured I'd get after the frunk seal channels.
Time for my best effort at an impersonation of Brent, Cary and Kent... Attached thumbnail(s) ![]() |
dan10101 |
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest ![]() |
I think I missed it. What's a frunk?
I'm trying to pay more attention, now. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,410 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
front trunk
Lo-Fi Version | Time is now: 21st April 2025 - 08:44 PM |
