234 Pages V « < 61 62 63 64 65 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Oct 6 2018, 05:05 PM
Post #1241
Whichever way I go with the hose routing, this is essentially final layout for the reservoir. Hoses not pushed all the way on as they are no fun to remove...
bbrock
post Oct 6 2018, 05:11 PM
Post #1242
There you go just cobbling stuff together without thinking about the details again. (IMG:style_emoticons/default/lol-2.gif)
I admit, I thought you were insane until I saw the pick of your 45 degree bracket. That does look nicer and I assume less strain on the hose. (IMG:style_emoticons/default/smilie_pokal.gif)
914forme
post Oct 7 2018, 09:31 AM
Post #1243
Why do I check this thread (IMG:style_emoticons/default/headbang.gif)
Great work as usual Chris. (IMG:style_emoticons/default/pray.gif)
Now to get my stuff done so I can get back to my builds.
914forme
post Oct 7 2018, 09:32 AM
Post #1244
BTW, love the drivers side gas fill.
tygaboy
post Oct 7 2018, 02:53 PM
Post #1245
Thanks guys. It's always a motivation helper to get feedback, good (and otherwise!)
So thinking about the design of this panel got me wondering if I could get a little fancier and pull off a nicer final piece. After all, if I haven't given it at least three tries, I know I'm not done yet... (IMG:style_emoticons/default/laugh.gif)
So, what's going on here?
tygaboy
post Oct 7 2018, 02:55 PM
Post #1246
It struck me that if I redesigned the panel like above, and if I got my bends right, those tabs would end up touching and I'd have a much tidier outer edge.
And it worked! (IMG:style_emoticons/default/cheer.gif)
tygaboy
post Oct 7 2018, 02:58 PM
Post #1247
My TIG welding is coming along and these little pieces are great practice, ahead of tackling the flares.
With the tabs joined, all I had to do was cut a little triangle and weld it in. I still haven't totally dressed the weld but you get the idea.
I'm happy with how it turned out.
tygaboy
post Oct 7 2018, 02:59 PM
Post #1248
Mock up, just to see it in place.
Matty900
post Oct 7 2018, 08:28 PM
Post #1249
QUOTE(tygaboy @ Sep 2 2018, 01:28 PM) *
And the tank side. It'll be soft lines from here up to the pump. One supply, one return.
Looking good as always Chris.
You may want to consider 45's on this depending on the length of the hose to the tank and I am assuming pump. If you use Gates hose and have too much it likes to kink. If you use SS Braided hose, it will be stiffer to deal with but shouldn't kink. It will just be a little fun getting the lengths right.
Keep up the good work (IMG:style_emoticons/default/beerchug.gif)
Dion
post Oct 8 2018, 03:27 PM
Post #1250
RN
Chris, that hydraulic line set up is awesome.
Love the tig work. Really fantastic. I think NASA would
approve! Keep at it man. I need to apprentice under your guidance.
Cheers
tygaboy
post Oct 9 2018, 04:35 PM
Post #1251
Decision made, complete with holes drilled!
And don't miss the front brake line bulkhead fitting. It's a T on the other side. Pretty tidy.
tygaboy
post Oct 9 2018, 04:37 PM
Post #1252
I figured it was time to get the radiator mounted. Still a few minor tweaks and some holes to drill to secure all the panels.
Suddenly, the frunk is feeling a bit crowded.
tygaboy
post Oct 9 2018, 04:41 PM
Post #1253
While I've been doing so much at the front of the car, I remembered I had a GT headlight kit. Got it from our friends at 914 Rubber: (IMG:style_emoticons/default/aktion035.gif)
So I started the install. A new opening has to be created for the "catch and release" lever. I have some add'l shaping to do but you get the idea.
tygaboy
post Oct 9 2018, 04:43 PM
Post #1254
Here's the "catch and release" lever in place.
Overall, I'd say it's a really nice kit. You will have to supply some of your own hardware but it's only a few fairly standard fasteners so not a big deal.
bbrock
post Oct 9 2018, 06:28 PM
Post #1255
QUOTE(tygaboy @ Oct 9 2018, 04:37 PM) *
Where are you going to fit your luggage for that road trip we talked about when I was at your place? Looks tidy though, but knowing you, you still have a couple solid rocket boosters to stuff in there. (IMG:style_emoticons/default/idea.gif)
tygaboy
post Oct 9 2018, 07:41 PM
Post #1256
QUOTE(bbrock @ Oct 9 2018, 05:28 PM) *
Looks like I'll need a trailer after all!
Andyrew
post Oct 10 2018, 05:44 AM
Post #1257
Spooling.... Please wait
Are you planning to fully shroud the radiator so you have a small parcel shelf?
As always, loving the progress!
tygaboy
post Oct 10 2018, 08:10 AM
Post #1258
QUOTE(Andyrew @ Oct 10 2018, 04:44 AM) *
Hey Andrew! Note that all I've done is Sharpie a possible fender vent... I've also Sharpied a "through the hood" vent design. I haven't committed to my, ahem, "exit strategy" at this point. (IMG:style_emoticons/default/happy11.gif)
Though your idea of a little parcel shelf is interesting... (IMG:style_emoticons/default/idea.gif)
We shall see.
tygaboy
post Oct 10 2018, 01:11 PM
Post #1259
Well, it's been an interesting morning. The net/net is that I now have lots more time to get this build done!
Who wants to join in and welcome me to RETIREMENT!!!
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beerchug.gif)
Cracker
post Oct 10 2018, 01:39 PM
Post #1260
Congratulations Chris! This has been a long time coming...enjoy the freedom!
Tony
QUOTE(tygaboy @ Oct 10 2018, 03:11 PM) *
- Lo-Fi Version Time is now: 14th December 2025 - 04:57 AM
