232 Pages V « < 67 68 69 70 71 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Dec 2 2018, 04:11 PM
Post #1361
The remnants of sneaking up on the desired fit.
I always snip then pick up the off cut. You DO NOT want to step on one of those things, believe me.
Then to get the desired corner radius, I lay the edge on the 1" tube and use the nylon mallet to just drop the edge of the part.
tygaboy
post Dec 2 2018, 04:13 PM
Post #1362
Nearly ready for tacking in place. A little bit more fitting to do. I still need to work the corners at the lower edge of the piece.
tygaboy
post Dec 2 2018, 04:14 PM
Post #1363
And the overall, as it sits at this point.
tygaboy
post Dec 2 2018, 04:18 PM
Post #1364
Am I the only one seeing a similarity?
Matty900
post Dec 2 2018, 04:21 PM
Post #1365
QUOTE(tygaboy @ Nov 30 2018, 05:40 PM) *
To quote AC/DC:
"Back in Black"
Some stock parts, some of the items I fabbed. After nothing but raw surfaces, it's so nice to see things in a final finish.
Headlight pieces should be grey (IMG:style_emoticons/default/poke.gif) Just kidding. Looks Awesome as usual Chris!
Also, I think it is called (IMG:style_emoticons/default/welder.gif) Tygaboy Syndrome
dan10101
post Dec 2 2018, 06:07 PM
Post #1366
TORQUE-o-holic
QUOTE(tygaboy @ Dec 2 2018, 02:07 PM) *
QUOTE(dan10101 @ Dec 1 2018, 07:06 PM) *
I'd say there was a therapy group for all problems, but I'm afraid yours is unique. (IMG:style_emoticons/default/poke.gif)
@dan10101 - Yours has to be my favorite entry on this build thread! (IMG:style_emoticons/default/av-943.gif)
And, it would seem, based on those self-identifying with this same affliction, you've helped spotlight a larger population in need of some sort of help.
In true 914 World fashion, I suppose we need to hold a contest to name this disease.
I'll start with a few that immediately popped into my head:
- Refab-itis
- Do-overism
- Jesusmanjustgetonwithitwouldyou Syndrome
Have at it, gents. I feel another t-shirt design coming on...
Whatever the name put to this disease, I would be glad to hold an online group therapy session for all those in need. After all I am fully trained in auto therapy I watched a youtube video on it once (maybe twice).
Andyrew
post Dec 3 2018, 08:25 AM
Post #1367
Spooling.... Please wait
QUOTE(tygaboy @ Dec 2 2018, 02:13 PM) *
(IMG:style_emoticons/default/blink.gif)
That fit is incredible!
Are you going to weld these pieces? Because if so, and take this with the right light, that seems to be an excessive amount of fitting (IMG:style_emoticons/default/poke.gif) I normally LIKE ~ 1/16" gap for butt welding but it looks like your going to tig these pieces with no filler rod!
ChrisFoley
post Dec 3 2018, 09:54 AM
Post #1368
I am Tangerine Racing
QUOTE(tygaboy @ Dec 2 2018, 05:11 PM) *
What, no handmade leather faced wooden slapper?
Shame on you.
tygaboy
post Dec 5 2018, 11:55 AM
Post #1369
In the category of "while I'm at it...", I decided to see if I could up my design for the firewall doghouse and stamp in some recesses for the cover panel and its fasteners.
@914forme Stephen, here's an example of what you asked about in your PM:
The blue lines are the raw panel. The white lines are edges of the male/female die set.
The gap between them is ~2x the material thickness. Just a guess for the first attempt. If it works, great! If not, it's back to the drawing board and I change the size of the gap.
(Or, it may not work out at all and I go another direction.)
The larger purple ovals are slots that I can use to align the panel in the die set.
I hope to do a trial stamping later today. Fingers crossed...!
tygaboy
post Dec 5 2018, 11:59 AM
Post #1370
QUOTE(ChrisFoley @ Dec 3 2018, 07:54 AM) *
Shame on you.
It's true: I'm a slacker....
bbrock
post Dec 5 2018, 01:30 PM
Post #1371
QUOTE(tygaboy @ Dec 5 2018, 10:55 AM) *
Yeah, good thinking because up until now this design was looking pretty half-assed. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/lol-2.gif)
tygaboy
post Dec 5 2018, 02:41 PM
Post #1372
A quick trip to the metal shop for some 12 gauge plate, a bit of plasma table and some edge finishing and we have the die set.
The die material thickness determines the depth of the stamping. I want the step to be thicker as I want to make the removable cover out of .050 aluminum (maybe thicker) and I also wanted some clearance for the fasteners.
Let's see how this turns out...
tygaboy
post Dec 5 2018, 03:04 PM
Post #1373
Clamp the raw panel to the lower die, position the upper die, using the alignment slots and place in press.
(Note that the die that's under the panel is cut to the same outer dimension as the panel. This makes is simple to get the die and panel all nicely aligned.)
Cross fingers, say a prayer, twirl around 3 times while chanting to the fabrication gods...
Then hit the "go" button!
tygaboy
post Dec 5 2018, 03:07 PM
Post #1374
Fresh out of the press. Hmmm... I see a bit of a non flat spot at the nub at the 10:30 ish position.
tygaboy
Post #1375
Yep, not quite right in that one area.
tygaboy
post Dec 5 2018, 03:08 PM
Post #1376
What to do? I reassembled everything and put it back in the press. I went nub-by-nub and pressed each area again! What do you know... It worked! (IMG:style_emoticons/default/cheer.gif)
It is pretty neat to be figuring out how to do this sort of thing. I really like what it adds to the overall design.
tygaboy
post Dec 5 2018, 03:49 PM
Post #1377
And with a successful proof of concept, I figured I'd see if I could update the existing panels. It's a bit trickier in that I'd already fit them and added some bends. You can see that the die ended up just a bit off and one side of the fastener indent is sharper than the other.
And now that I see where the fastener indents actually end up on the trimmed and fit part, I think I'll cut a new die set and move them to "better" locations. The upper- and lower-most indents need to be farther away from the ends of the panel, IMHO.
In all, a great learning experience. I proved to myself that I can execute this technique on a reasonably complex shape. I have a few other places on the car that I can use this sort of thing, too.
I'm calling today a success. (IMG:style_emoticons/default/beerchug.gif)
914forme
post Dec 5 2018, 06:22 PM
Post #1378
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/aktion035.gif) That is a great looking (IMG:style_emoticons/default/drooley.gif)
Thanks Chris the PM explains the process and the pictures filed in the blanks.
We will talk at some point (IMG:style_emoticons/default/shades.gif)
Off to do a bit of calculating, measuring, and then order some Steel and Aluminum, I really need to upgrade my press.
tygaboy
post Dec 6 2018, 05:31 PM
Post #1379
Some more analysis led me to updating the die set. I was after three changes:
- move the upper- and lower-most fastener recesses farther away from the corners
- less depth in the step for the removable panel
- a tighter radius on that step
So I redesigned the die and narrowed the gap between the pieces. I also made the male die with an opening and some slots, thinking this might make aligning things a bit simpler.
The last change was that I used 14 gauge vs the 12 gauge of the first set.
Clearly, one of the only times I go for function over form! (IMG:style_emoticons/default/shades.gif)
tygaboy
post Dec 6 2018, 05:37 PM
Post #1380
I figured out a couple tricks that really helped: I used two blocks of 1" aluminum to sandwich the dies. These provided nice, smooth surfaces to back up the dies.
This was important in that I have to use both sides of the die set to make the mirror image side panels. These blocks eliminated any change of marring any of the die surfaces that would end up being stamped into the panels.
Anyway, here they are. The step is much more crisp and the fastener areas more even.
I'm really happy with how these turned out.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: East coaster
- Lo-Fi Version Time is now: 22nd April 2025 - 05:08 PM
