tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,552 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
I wasn't happy with the way the lower outer panel edge just ended and how it sorta forced the rivet line to stop. So I made a little extension that I silicone brazed on to the seatbelt recess panel.
I still have a bit of clean up to do but to me, this looks a lot more complete. Of course, this means I now have to do the same thing for the top area. It's always something... (IMG:style_emoticons/default/wacko.gif) Attached thumbnail(s) ![]() |
tygaboy |
That's an awesome starter switch! It looks like a great fit! Was it a lot of work? @Krieger - Not too bad. Let me point out that I used an early steering column. I didn't even know there was a difference. Here's a pic of the one that came in my '75. Completely different and if I'd only seen this version, I doubt I would even have thought to try. Attached thumbnail(s) ![]() |
tygaboy |
This is the early column.
The start button unit has locating ridges that run down it's length. Clearance had to be cut for these. A small Dremmel made pretty quick work of this. Attached thumbnail(s) ![]() |
tygaboy |
Then the locating ridges needed to be trimmed to length to allow the unit to fit in the column. But a gap needed to be cut at the upper area of the ridge that the column's removable switch plate/retainer cover would use to hold the start button unit in place.
tygaboy |
Here's how the retainer plate locates / locks in with the start button unit.
tygaboy |
Into the column it goes!
tygaboy |
On goes the retainer.
tygaboy |
And into the car! (IMG:style_emoticons/default/aktion035.gif)
tygaboy |
Let the console fabrication begin! That center trim panel is just a mock up to check dimensions.
I still have some designing to do but at this point, I think I'm going to make most all of this upper console section removable. Maybe do a frame under it to support the shifter and this just becomes a cover. (IMG:style_emoticons/default/idea.gif) Decisions, decisions. Attached thumbnail(s) ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,300 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
That looks really nice Chris. (IMG:style_emoticons/default/beerchug.gif)
tygaboy |
One for the tool whores: Looking to create nice, evenly spaced holes? Forget measuring and get a rivet fan. It makes this almost impossible to screw up.
I scribe a line the distance in from the edge that I want (no less than 3x the rivet diameter) then set the rivet fan to the desired spacing. Lay the fan's holes right on top of the scribe line and poke a Sharpie in the hole. Come back and mark the spots with a spring loaded center punch then drill the holes. Don't use the fan as a drill guide! Attached thumbnail(s) ![]() |
tygaboy |
Driver side lower outer partially done.
tygaboy |
I made some pretty good progress on the console today. I've moved to a much simpler design. I think with all the stamping, a fairly plain console works better.
I fabbed the rear supports for the shifter and used them to locate the rear console panels. Then I worked up the front sections. Now it's a simple matter of playing "connect the dots". Here, the rear panels are in final position - the shifter is bolted down to the rear mounts - and I've set set the other pieces in rough position, just to get a feel for how things fit and look. I like it. It looks much cleaner than the previous version. Easier to paint or cover with carpet, etc. Note that all this console sheet metal will be removable so I can service the stuff that runs in this new tunnel. And yes, those are mock up circles for the cup holders! (IMG:style_emoticons/default/beerchug.gif) (rootbeer, that is!) Attached thumbnail(s) ![]() |
tygaboy |
The final version will have a "cover panel" that runs front to back that sits down in the recessed area and is riveted in place.
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Thats starting to look really nice!!!
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Awesome! (IMG:style_emoticons/default/first.gif)
tygaboy |
I want to be able to run the car without the console cover so I needed a shifter support stand of some kind. Here's what I came up with.
The console cover sit right on top of it. Still a little bit of trimming to finish it up. Attached thumbnail(s) ![]() |
tygaboy |
Nearly-major milestone: Almost ready for final install of the fire wall panels. (IMG:style_emoticons/default/piratenanner.gif)
tygaboy |
Door bar trim panel, version 2. I added the upper lip / bend. I think it looks more finished than just the upper edge ending in line with the main fire wall panel.
tygaboy |
Passenger side lower / upper outer added. See post #1701 for a pic of what it looked like before. This looks far more integrated, IMO.
On to the driver side to do the same. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 23rd April 2025 - 07:05 PM |
