232 Pages V « < 104 105 106 107 108 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Dec 7 2019, 04:45 PM
Post #2101
A bit of edge trimming and the inside upper plates are tacked in.
On the driver side, I ended up having to weld on about a 3/16" extension to the front, inside vertical edge of the plate to get a nice fit round the entire plate. Again, no surprise in that we know there's all sorts of variation across 914 chassis.
tygaboy
post Dec 7 2019, 04:48 PM
Post #2102
But I was able to get complete contact on all mating surfaces!
Most all of that credit goes to the quality of the Tangerine product, but I did take the time to fine tune.
tygaboy
post Dec 7 2019, 04:53 PM
Post #2103
Now it's on to the "fun" part: fitting the plates that live inside the fender well.
Ugh. Not great access and really hard to get line of sight to all the joints that need welding.
And as it relates to the inner and outer large plates, these need to be first in line for final welding as any shrinkage here will add negative camber. I need to lock these down before going after those inners I just tacked in.
But I'll figure it out!
Hmmm, maybe this is the time to add some fender vents... (IMG:style_emoticons/default/idea.gif)
914forme
post Dec 7 2019, 05:54 PM
Post #2104
Your fenders are tacked in place with several welds, easy to remove and redo. It would only be your _______ time.
Andyrew
post Dec 7 2019, 07:44 PM
Post #2105
Spooling.... Please wait
QUOTE(tygaboy @ Dec 7 2019, 03:53 PM) *
He's a mad man!! (IMG:style_emoticons/default/sawzall-smiley.gif) (i would love to see this)
dan10101
post Dec 8 2019, 09:57 AM
Post #2106
TORQUE-o-holic
Woops, that was really OT. 'deleted'
Carry on..
I would like to do fender vents too, but I don't have the steel for it... (IMG:style_emoticons/default/smile.gif)
FourBlades
post Dec 8 2019, 10:57 AM
Post #2107
From Wreck to Rockin
Wow, great work as always! Looking good. The time you spent getting it all square and level will pay off the rest of the cars lifetime.
Sorry to hear about the health issues, hopefully they can take care of it easily.
Keep on building an entertaining us all! (IMG:style_emoticons/default/chowtime.gif)
Helps inspire me work on my own projects.
John
tygaboy
post Dec 8 2019, 11:24 AM
Post #2108
QUOTE(dan10101 @ Dec 8 2019, 07:57 AM) *
Carry on..
@dan10101 - Dan, come on now! I have a roll of carbon fiber and mold making capabilities... Just sayin'. (IMG:style_emoticons/default/happy11.gif)
Mueller
post Dec 8 2019, 12:44 PM
Post #2109
914 Freak!
Nice trailing arm mounts, Chris
ChrisFoley
post Dec 8 2019, 07:03 PM
Post #2110
I am Tangerine Racing
QUOTE(tygaboy @ Dec 7 2019, 03:32 PM) *
Then there's the "top cap" (even though it's the bottom part. Hey, the car is upside down and it's my build. Deal with it. (IMG:style_emoticons/default/happy11.gif) )
I haven't verified this w/ @ChrisFoley , but I suspect these pieces are used in both the 2" raise and the 3" raise kits. Since mine is the 2", you can see there's some trimming needed on that inside leg to get it to sit down where it needs to be.
They are different. However that doesn't negate the possibility I sent you the wrong ones. (IMG:style_emoticons/default/smile.gif) Due to space considerations, parts storage is not fully organized.
tygaboy
post Dec 9 2019, 01:39 PM
Post #2111
Flip things over and you can see there are some openings to close!
The kit comes with a piece that closes the long and extends over to the inner pick up plate and the inner support piece I covered in the last couple posts.
However, it didn't quite fit my chassis/pick up. I assume it's another "all these cars are slightly different". No matter as I opted to go with a slightly different design.
tygaboy
Post #2112
First, I cut this piece to close off the long.
tygaboy
post Dec 9 2019, 01:40 PM
Post #2113
Then I tacked it in and fully welded the areas that wouldn't be accessible once I added the other gusset plate I had planned.
tygaboy
post Dec 9 2019, 01:41 PM
Post #2114
Next, I cut, folded, fit and tacked in this piece. I also fit the trailing arm, just to be sure there would be no clearance issues.
Yes, I see that little opening in the corner... (IMG:style_emoticons/default/poke.gif)
tygaboy
post Dec 9 2019, 01:43 PM
Post #2115
Little opening in the corner all gone. Everything in this area ready for final welding.
On to the other side! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
tygaboy
post Dec 9 2019, 04:57 PM
Post #2116
Lather, rinse, repeat. For some reason, I ended up with some sort of contamination on the under side of the one plate and ended up with a couple surprise "POPs" that left me with a couple holes. No worries, they'll be addressed during final welding.
tygaboy
post Dec 9 2019, 05:00 PM
Post #2117
Now the fun part: fitting and welding in the outside upper reinforcements.
After starting on the passenger side, I was reminded I haven't yet patched the hell hole-related inner wheel housing damage at the battery tray. You can see the holes, just above the upper edges of the plate.
Anyway, this gives an idea of the available access I have.
tygaboy
post Dec 9 2019, 05:04 PM
Post #2118
I wanted to make at least some progress with one of these uppers so I moved to the driver side.
Have I said that I don't see how folks do this install without a rotisserie? (IMG:style_emoticons/default/blink.gif)
This piece needed just a bit of trimming in a couple spots. I was able to get it tacked in and with a touch of hammering, should be able to get the edges in contact with the chassis all the way around its perimeter.
Again, this is the piece I want to final weld first (on each side) to help control any distortion-induced camber change.
In all, a pretty productive day.
Jeff Hail
post Dec 9 2019, 07:40 PM
Post #2119
[quote name='tygaboy' date='Dec 9 2019, 03:04 PM' post='2768607']
Just reverse the polarity, its like flipping the tub upside down! (IMG:style_emoticons/default/lol-2.gif)
tygaboy
post Dec 13 2019, 04:47 PM
Post #2120
Boring, I know, but progress is being made!
I patched all the battery acid and rust damage on the inner wheel house (except the small hole you can see just ahead of the reinforcement plate). This allowed me to get the passenger side outer reinforcement fit and tacked in; I can deal with that hole later. I REALLY want to wrap up the install of these raised pick ups.
And after looking more closely, I think I can weld these plates in with the access I have. At the very least, I'll give it a go with things as they are.
- Lo-Fi Version Time is now: 25th April 2025 - 10:47 AM
