232 Pages V « < 109 110 111 112 113 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Jan 16 2020, 03:16 PM
Post #2201
I'll post one more of these then stop. It's essentially the same on each one: the flare ends aren't even close to what they need to be, they aren't symmetrical, side to side, etc.
This next one is a good example of that. Note how the one I did earlier looks and how it has a straight shot inboard from where the lip terminates, This other one has a totally different shape there, almost like a chunk was taken out.
tygaboy
post Jan 16 2020, 03:20 PM
Post #2202
Anyway, first I hammered the lower area flat and into shape to match that first angled portion of the chassis, then clamped the dolly in place and added the crease needed to match the lower portion of the chassis.
tygaboy
post Jan 16 2020, 03:21 PM
Post #2203
Get things to this point...
tygaboy
post Jan 16 2020, 03:22 PM
Post #2204
The original factory piece I cut off wasn't going to work so I bent up a channel and tacked in into place.
Here you can also see the "patch" I made to address that missing chunk.
tygaboy
post Jan 16 2020, 03:24 PM
Post #2205
Next, I made a template of the other side that I used to determine final size and shape for this side.
tygaboy
post Jan 16 2020, 03:25 PM
Post #2206
Tack, hammer, trim, grind. Getting there.
tygaboy
post Jan 16 2020, 03:26 PM
Post #2207
A bit more fine tuning and I'll call this area done.
Andyrew
post Jan 16 2020, 10:59 PM
Post #2208
Spooling.... Please wait
Wow Chris! Your on a whole other level with this perfection! This car is going to be simply stunning!
tygaboy
post Jan 27 2020, 01:39 PM
Post #2209
Since I was never going to use them, today I fabbed the needed pieces and plated over the jack post areas.
Then it was welding on the Patrick Motorsports toe adjuster attachment blocks.
I even remembered to drill the clearance hole for the bolt before I welded it on!
I still need to weld the joint between the top of the plate and the chassis.
tomeric914
post Jan 27 2020, 02:01 PM
Post #2210
One Lap of America in a 914!
Great metal fabrication porn @tygaboy !
tygaboy
post Jan 27 2020, 06:04 PM
Post #2211
Both sides complete! And note that these toe adjusters usually run parallel to the chassis/ground. But with the Tangerine pickups raising things up 2", I get this nice sloping install.
I'm slowly ticking off these to-do's and should have all the chassis fab complete in a couple weeks, fingers crossed. (IMG:style_emoticons/default/welder.gif)
Andyrew
post Jan 28 2020, 10:30 AM
Post #2212
Two weeks and your done with your chassis? Whats after the chassis? Engine/trans mounting?
tygaboy
post Jan 28 2020, 12:59 PM
Post #2213
QUOTE(Andyrew @ Jan 28 2020, 08:30 AM) *
@Andyrew - the engine/trans mounting are all done, as is the exhaust. That said, the drive train has to be installed again so I can finish all the little stuff like where the ECU and coils will mount, things like that. Once the chassis is finished, it's off to media blasting and primer/sealer.
Andyrew
post Jan 28 2020, 03:00 PM
Post #2214
QUOTE(tygaboy @ Jan 28 2020, 10:59 AM) *
Cant wait to see it!
tygaboy
post Jan 31 2020, 05:31 PM
Post #2215
Back to working on things that aren't part of any other 914! Uninteresting to most, I know, but I have to get it done and I may as well document it.
Today was fabbing a piece to close off between the engine compartment and interior. This opening was created when I removed the stock firewall and added the removable access panel. I need to seal off between that curved top area of the firewall and the upper portion of the access panel's frame, just above the upper attachment points.
tygaboy
post Jan 31 2020, 05:36 PM
Post #2216
I had part of the firewall from a donor/parts car so I sliced off the area that matches the lip of the firewall curved section. I cleaned everything up, flipped the piece upside down and used the spot welder to attach it on the inside of the firewall's curve.
Note I now have a nice little return to which I can weld a panel!
tygaboy
post Jan 31 2020, 05:44 PM
Post #2217
Next, I made a quick template to get the panel shape and used that to cut a piece of 18 ga to fit. Because this panel is mounted at an angle, and against a curve, I bent it accordingly.
I then bend up a couple flanges, determined where they needed to be and spot welded them to the panel. Then I used the bead roller to tip a slight flange into the curved edge of the panel so it would lay at the same angle as the curved piece I'd spot welded on earlier.
I'll add a flange on the front edge, too. The curved edge will be spot welded on but I'll use structural panel bond on the faces of the flanges where they attach to the access panel frame piece.
Cairo94507
post Feb 1 2020, 08:56 AM
Post #2218
Michael
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Feb 4 2020, 04:48 PM
Post #2219
MAJOR MILESTONES!
- the console frame is welded in
- the floor has been plug welded to the console frame
- the lower parts of the fire wall have been bonded in
This is my first time trying something like this. I figure there's no kill like overkill so I'm using 3M structural adhesive to attach the fire wall panels. I'm not doing the rivets until after things are painted as I want the rivets to contrast with the paint.
Riveting on fresh paint... I'm so looking forward to that! (IMG:style_emoticons/default/blink.gif)
I understand this stuff is pretty incredible. A buddy of mine said, "You realize that you'll NEVER get those panels apart. It's stronger than spot welding." Fine by me!
So here we go...
tygaboy
post Feb 4 2020, 04:58 PM
Post #2220
Apply the adhesive to both surfaces and tool it out with an acid brush. Add another small bead to one surface to be sure there is plenty of adhesive and any potential voids are filled while the parts are clamped and curing.
The lower section here is made up of three separate pieces and a number of mating surfaces had to be prepared ahead of fitting. This adhesive has a working time of 60 minutes so I felt like I had plenty of time.
I still felt a bit nervous but it went pretty well. After everything was in place and clamped, I double checked and cleaned out all the rivet holes and decided to use Clecos only in those that had no sign of adhesive in them. That's why some holes aren't being used. Bonding in a Cleco wouldn't be good.
Once things were aligned, clamp, clamp, clamp and wait 24 hours for a full cure.
Again, not too exciting for most of you but a HUGE deal to me. After all this time, the fire wall is being permanently installed! (IMG:style_emoticons/default/cheer.gif)
- Lo-Fi Version Time is now: 26th April 2025 - 01:18 AM
