232 Pages V « < 112 113 114 115 116 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
Andyrew
post Feb 14 2020, 11:16 AM
Post #2261
Spooling.... Please wait
QUOTE(tygaboy @ Feb 13 2020, 11:27 AM) *
I had some scrap carbon fiber so thought I'd see how I could do trimming it to fit the recesses. I figured I could use the male component of the stamping die as a template.
I clamped the carbon to the die, trimmed it then used 80 grit sanding pad on an angle grinder to take it to the final size. That worked like a charm and took like 20 seconds!
This piece is about 2X thicker than I'd use so the "real" piece will sit better in the recess.
But a successful proof of concept, so I know I'm good to go on the dog house cover, and these main panels, should I opt to go this way.
One thing to remember is to cut and finish each piece of carbon so the weave sits at the same angle across all the pieces and looks like the metal was placed over a single piece. Shouldn't be hard to do, I just need to remember and do it! (IMG:style_emoticons/default/laugh.gif)
That looks good! Also should provide some sound deadening, I would assume you would use the same panel bonding stuff, which would give it the needed flex.
I cant wait!!! Im guessing were only a couple months away to seeing the car in primer/paint?
tygaboy
post Feb 14 2020, 01:40 PM
Post #2262
QUOTE(Andyrew @ Feb 14 2020, 09:16 AM) *
Thanks @Andyrew - I'm hoping things will happen that quickly. I need to finish ALL the fab work, which now looks like it's going to include a fixed roof. Hello @914forme !
I'm leaning toward a sheet metal/tubing frame and bonding on a carbon skin. I'm starting on the frame today to see if I can come up with something that will work.
tygaboy
post Feb 14 2020, 01:42 PM
Post #2263
I'm sure you're getting tired of seeing this fire wall stuff so let's call this the final one, because... it's done!
Presenting one custom fire wall, ready for the paint shop! (IMG:style_emoticons/default/piratenanner.gif)
djway
post Feb 14 2020, 02:56 PM
Post #2264
It's a Beauty Clark (IMG:style_emoticons/default/smile.gif)
Krieger
post Feb 14 2020, 04:05 PM
Post #2265
(IMG:style_emoticons/default/aktion035.gif) HOORAY! Looks really good!
FourBlades
post Feb 14 2020, 04:20 PM
Post #2266
From Wreck to Rockin
Was worth the effort! (IMG:style_emoticons/default/beer3.gif)
John
sixnotfour
post Feb 14 2020, 04:26 PM
Post #2267
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif) it also hides one out of character feature.........................a sqaure corner....I know you are testing us (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/wub.gif)
tygaboy
post Feb 14 2020, 07:14 PM
Post #2268
QUOTE(sixnotfour @ Feb 14 2020, 02:26 PM) *
Hey now, @sixnotfour , you'll have to talk to @ChrisFoley about that! (IMG:style_emoticons/default/poke.gif)
I just bought the thing and installed it! (IMG:style_emoticons/default/laugh.gif)
tygaboy
post Feb 14 2020, 07:17 PM
Post #2269
Thanks for the compliments, everyone. It certainly was a looooooooong time coming so my thanks to y'all for your patience while I worked through all that!
tygaboy
post Feb 14 2020, 07:21 PM
Post #2270
And now on to the next little project: a fixed roof! (IMG:style_emoticons/default/aktion035.gif)
I want to try building a steel frame and bonding on a carbon fiber skin. I want it to look stock, as though it could be removed, not like the 916 with the drip rails and being obviously fully integrated with the windshield frame.
So... today I started on two of the components: the mold for the skin and what I'm calling the window seal rails.
First the mold. Since I want it to look stock, I can use a stock top to make the mold. I plan to paint the roof (probably black) so I don't need to have everything all perfect with the mold.
I had a smoothed top and I hit it with 1500 wet sand, just to tidy it up a bit.
tygaboy
post Feb 14 2020, 07:28 PM
Post #2271
Once it was all dry, it's time for a few coats of mold release wax.
Once that's done, on goes a layer of PVA. Some folks spray this on but I've had just fine results wiping it on with a paper towel. I pour a bunch on and wipe it evenly over the entire surface.
Essentially, the PVA forms a very thin layer that prevents the layup from actually touching the part.
The only really critical part is that you don't touch it once it starts to dry, else you can peel it off.
tygaboy
post Feb 14 2020, 07:30 PM
Post #2272
Here's the top waxed and with the PVA dried. Shiny is what you want as this is what will determine the finish of the inside of the mold.
Again, not that critical for my project since the skin will end up being painted but the better things are at this point, the better the part that comes out of the mold.
tygaboy
post Feb 14 2020, 07:33 PM
Post #2273
And with the first layers of fiberglass. I use a really lightweight cloth for the first couple layers as it drapes more easily and better conforms to any of the fiddly compound shaped areas, like the front corner of the drip channel.
tygaboy
post Feb 14 2020, 07:41 PM
Post #2274
The other component I started on was the driver side window seal rail. I cut and bent up a length of 18ga and went to work with the stretcher.
Stretch, stretch, compare to the edge of the top, oops, too much. Shrink, shrink, compare again... you know the drill.
About 387 trips between the stretcher and the car later and I'm almost there!
Yes, I know I have to add material to the top of the targa bar to account for the dimension of the seals and other roof elements.
My plan is to get a set of window seals attached to these rails then position the assembly so the seals are in the correct location. Once that's done, I weld in the rails. I'll lay up the roof skin and once I have that, I can locate it on the car then "just" (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) connect things together.
Wish me luck!
Andyrew
post Feb 14 2020, 10:37 PM
Post #2275
Your skills, ingenuity, and dedication never ceases to amaze me Chris (IMG:style_emoticons/default/smile.gif)
Such a cool project!
Cairo94507
post Feb 15 2020, 10:42 AM
Post #2276
Michael
Amen brother. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Feb 17 2020, 02:51 PM
Post #2277
Working away on the window seal rails. Back and forth to the shrinker/stretcher and comparing to the targa top. The surfaces where the seals mount need to be level with each other. This is a good thing in that when I need to position the rails for install, I can simply clamp them to a couple of square tubes that span the width of the car and I'm guaranteed they'll be aligned.
tygaboy
post Feb 17 2020, 02:57 PM
Post #2278
Here's the "splash mold" for the roof skin, getting a bit of solar cure! You can see through it because it's only a few layers thick in most places. You can see I added a few pieces of core mat and layed up over some bent sheet metal to help stiffen things up.
This mold is only going to be used once and the part I'm making needn't be perfect so I did this about as quick and dirty as I could. If it turns out I need a higher quality mold, it's easy enough to make another.
sixnotfour
post Feb 18 2020, 12:18 AM
Post #2279
tygaboy
post Feb 18 2020, 02:48 PM
Post #2280
QUOTE(sixnotfour @ Feb 17 2020, 10:18 PM) *
@sixnotfour - Yes! Like that! Except I'm going to build my X brace to be welded directly to the windshield header and the targa bar.
- Lo-Fi Version Time is now: 26th April 2025 - 07:13 AM
