232 Pages V « < 139 140 141 142 143 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
914forme
post Aug 1 2020, 07:57 PM
Post #2801
Uh Chris, your relays are so old school.
Here to help Try these
db9146
post Aug 1 2020, 08:49 PM
Post #2802
I used that set-up when I added FI to the engine in my -6. They work great, are small, and easily wired.
tygaboy
post Aug 1 2020, 09:33 PM
Post #2803
QUOTE(914forme @ Aug 1 2020, 06:57 PM) *
@914forme - Stephen, I'm a total newbie when it comes to all this electronics stuff and the guy helping me with the Arduino took care of ordering all the parts, incl. the relays. I'm quickly coming up to speed, but certainly have a way to go. So:
For my application, I need 8 relays. The only "nice" relay panels I seem to be able to find, like the one you pointed me to, all have spots for fuses, which I don't need or want, given I'm trying to conserve space.
Do you know of an 8 or 10 relay panel that's JUST for relays? I've searched the best I can but so far, all I find are the relay/fuse combos.
Continued help appreciated.
jd74914
post Aug 2 2020, 06:14 AM
Post #2804
Its alive
Hey Chris! Didn’t mean to be the bearer of doom...busy weekend though, I’ll give you a ring Monday.
This think can fit 10 micro relays. I’ve used them a few times and been happy.
https://www.waytekwire.com/item/46357/EATON...-2-0-1-0A-RFRM/
914forme
post Aug 2 2020, 06:53 PM
Post #2805
@Tygaboy Chris, Yes that would be the one.
ssuperflyoldguy
post Aug 2 2020, 10:31 PM
Post #2806
"and any other tool whores looking for a neat item:
Here's the kit I went with. Note I am a total wiring novice so there may be better/more appropriate items available...
[/quote]
This Certified xxxx-whore has been pushing PowerProbe for years, wish I got commission on every sale
tygaboy
post Aug 8 2020, 09:10 AM
Post #2807
Mess 'o wires got you down? No problem - just hide them!
I worked up an initial version of a fuse panel cover. Only took three tries to get the bends to work out and have all the mounting holes align! (IMG:style_emoticons/default/laugh.gif)
One plane on the left side (out of view in this pic) couldn't be formed as part of the main panel so I'll fab that and weld it in. Pics once that's done. Then it's on to making a foot rest that ties from the floor up to the lower mounts of this cover.
sb914
post Aug 8 2020, 09:28 AM
Post #2808
Surf Guru
I get to see this car next weekend... (IMG:style_emoticons/default/piratenanner.gif)
tygaboy
post Aug 8 2020, 01:56 PM
Post #2809
And here's the whole contraption in place. I need to get back to focusing on things that'll make it run.
I'm targeting Sept for its maiden voyage under its own power. (IMG:style_emoticons/default/driving.gif) Wish me luck!
BillC
post Aug 8 2020, 02:27 PM
Post #2810
QUOTE(tygaboy @ Aug 8 2020, 03:56 PM) *
Wow, very slick!
wysri9
post Aug 10 2020, 12:26 AM
Post #2811
Region Association: England
QUOTE(tygaboy @ Aug 1 2020, 07:33 PM) *
I used this range
https://www.12voltplanet.co.uk/mounting-bra...lar-system.html
Not sure if it is available in the states.
Here is a pic of my install in progress....
The electrics are centred underneath a hinged passenger side footplate.
You can see more in my Scottish Reincarnation thread.
Loving your build - oh for those fab skills......
tygaboy
post Aug 10 2020, 09:09 AM
Post #2812
@wysri9 @914forme @jd74914 - Thanks for the info, guys. As mentioned, I'm still early in my electrical learning curve. My requirement is for a panel that supports 8 - 10 relays while being as small as possible - and I don't need add'l fuses. After a bit of searching, it seems I'm best off building what I want from a base starting point.
I found the Bussman 15310. It's a 60 position panel that can be configured to support just what I need, with room to expand, should that need arise.
I happily confess I wasn't aware of the Micro and Ultra Micro relays and what they mean to the overall size of the final unit. It seems I can get what I need in a ~ 5" x 3.5" x 2.75" box. Yes, it'll sit taller once mounted with space for the harness, but it looks like my best option.
Critiques and guidance appreciated, as always.
tygaboy
post Aug 10 2020, 12:19 PM
Post #2813
More progress. Maybe not exciting to some of you, but VERY exciting to me as my build shows additional signs of life after all this time.
And ignore my comment about what the oil pressure gauge does. I had neglected to plug it into the harness. Once plugged in, it doesn't jump to full reading when first powered up.
https://www.youtube.com/watch?v=_6bDw49JNjw
djway
post Aug 10 2020, 09:32 PM
Post #2814
All those wires make my head hurt (IMG:style_emoticons/default/wink.gif)
That Power Probe really saved me a ton of headache, THANK YOU for the information.
Looking Good.
Krieger
post Aug 10 2020, 10:06 PM
Post #2815
Nice! Keep crossing all those little details off your list!
Cairo94507
post Aug 11 2020, 06:50 AM
Post #2816
Michael
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Aug 11 2020, 08:22 AM
Post #2817
Spooling.... Please wait
Love the progress!!
FL000
post Aug 11 2020, 11:24 AM
Post #2818
That is some high tech stuff you got going on there! The steering wheel controls will be slick.
post Aug 11 2020, 03:01 PM
Post #2819
(IMG:style_emoticons/default/poke.gif) You're having entirely too much fun. (IMG:style_emoticons/default/beerchug.gif)
KELTY360
post Aug 11 2020, 09:49 PM
Post #2820
914 Neferati
Are you going to compile an owner's manual so you'll know what's what when you're old and feeble? (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 24th April 2025 - 07:37 PM
