232 Pages V « < 155 156 157 158 159 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
Andyrew
post Nov 12 2020, 11:28 AM
Post #3121
Spooling.... Please wait
Get some honeycomb mesh, Larger openings. I think the thin mesh looks off.
tygaboy
post Nov 12 2020, 12:17 PM
Post #3122
QUOTE(Andyrew @ Nov 12 2020, 09:28 AM) *
@Andyrew - Hey, it's all I had laying around! Geez, tough crowd... (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/poke.gif)
AZBanks
post Nov 12 2020, 12:19 PM
Post #3123
It looks like too big of an opening for the mesh to me visually. What about making it similar to the vents with several smaller mesh openings. Excuse my poor/hasty editing skills.
914forme
post Nov 12 2020, 01:25 PM
Post #3124
I want to know if you are going to stamp the mesh to add another profile to the finished products.
Andyrew
post Nov 12 2020, 01:47 PM
Post #3125
QUOTE(AZBanks @ Nov 12 2020, 10:19 AM) *
What about.....
This same layout, But with the honeycomb pattern CNC cut out vs a straight hole? Chris could cut and weld in a blade if he wanted as well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.zcentre.co.uk-172-1605210549.1.jpg)
KELTY360
post Nov 12 2020, 01:53 PM
Post #3126
914 Neferati
QUOTE(Andyrew @ Nov 12 2020, 12:47 PM) *
What about.....
This is fun.
tygaboy
post Nov 12 2020, 02:53 PM
Post #3127
I texted Tony @RetroRacer this morning and attached this pic. My message was "OK, Tony, here you go. Proof that your design is possible."
A bit of slicing and dicing and the prototype panel can drop into place. I will say, it takes on a different look once it's down in the hood. I'm liking it! Especially that rear view.
In place, a couple things stand out as needing mods, IMO:
- the vents stick up a bit too much. Looking back at Tony's design, his pivot even with the upper edge.
- the upper edge of the frame seem in a bit of conflict with the trailing edge of the hood. Instead of what's there now (90 degrees to the center line of the hood), maybe add a bit of forward/inward sloping angle? Not a lot, just something that hints it's not 90.
And yes, I had to open things up past the fuel tank bulk head. But I'm confident I can work up a solution for that.
Onward to updating the design.
tygaboy
post Nov 12 2020, 03:05 PM
Post #3128
QUOTE(914forme @ Nov 12 2020, 11:25 AM) *
@914forme - Stephen, if I end up with mesh, yes, I'll make up a stamping die set and add that little "peek-a-boo" look that brings the mesh even with the surface of the hood.
mikey63
post Nov 12 2020, 03:14 PM
Post #3129
QUOTE(tygaboy @ Nov 12 2020, 01:05 PM) *
(IMG:style_emoticons/default/welder.gif) Looks good Chris!!
Andyrew
post Nov 12 2020, 03:16 PM
Post #3130
How does it interfere with the headlight mechanism? I can see it on the left in the second pic. Have you run the motor to check for interference?
I like what you have. I take back my honeycomb concept.
tygaboy
post Nov 12 2020, 03:29 PM
Post #3131
QUOTE(Andyrew @ Nov 12 2020, 01:16 PM) *
@Andyrew - No motors - GT headlights!
Cairo94507
post Nov 12 2020, 03:38 PM
Post #3132
Michael
This is looking a lot better. I agree with the back edge of the vent not flowing with the back end of the hood. I also wonder how the vents would look if they finished out flush with the hood surface- so the vents are not proud of the hood. Or is it just the picture that makes them look like they rise above the hood? But, all said, I am really liking the look. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Nov 12 2020, 04:22 PM
Post #3133
QUOTE(tygaboy @ Nov 12 2020, 01:29 PM) *
Thats right, I forgot your doing that!
djway
post Nov 12 2020, 05:17 PM
Post #3134
Have you considered a louvered panel ot louvers in the hood itself?
Narrow , not too tall.
dakotaewing
post Nov 12 2020, 06:02 PM
Post #3135
Here's an idea just to make things more difficult to execute. (IMG:style_emoticons/default/popcorn[1].gif) Cut the wire pattern to fit inside the opening between each angled metal slat, keeping the wire pattern even with the top of the hood. This process uses both components.
Retroracer
post Nov 12 2020, 06:49 PM
Post #3136
Chris - as discussed, the original intent was the edge of the cut out needs to follow the line of the headlight cutout as shown below in the two pics - with some really bad visual editing on the "fixed" pic:
Retroracer
post Nov 12 2020, 06:50 PM
Post #3137
...and I realize you may not be able to do this easily on the steel mock up.
Either way - looks completely awesome!
- Tony
tygaboy
post Nov 13 2020, 11:29 AM
Post #3138
A new day, a new design. V1 wasn't doing it for me - the "tab bend" approach requires some amount of gap in certain areas and the more I looked at it, the more it looked a bit too raw or crude. I think I can do better and come up with something that looks more "finished".
So this morning was an update to a simple cut line to define each vent. Note that the red line isn't a cut - it represents the bend line for each vent.
This approach results in a .375" flat at the front of each vent. The goal is something like the 2nd pic.
Today's effort will be to cut one of these and see how it works out.
tygaboy
post Nov 13 2020, 11:30 AM
Post #3139
Here's the look I'm after for this version...
tygaboy
post Nov 13 2020, 11:34 AM
Post #3140
Then maybe something like this to finish it off, but using a more open mesh.
- Lo-Fi Version Time is now: 23rd April 2025 - 03:05 PM
