AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,064 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
I think you are on the right track. I can't wait to see the results.
dan10101 |
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest ![]() |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,552 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
After messing about with the design, I cut one ( (IMG:style_emoticons/default/lol-2.gif) geez, how old am I?) and went after bending the vents. It immediately apparent it doesn't need those little arcs in the corners at the bend. I thought they'd add some style points but they actually detract.
Anyway, here's how I ended up bending the vents. I didn't have this clamping model totally worked out on that first little vent so its bend radius isn't as crisp as it should be. Won't happen again, I promise! Attached thumbnail(s) ![]() |
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,609 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
Here's the look I'm after for this version... I think a rounded edge similar to these can really add some much needed sex appeal to these boxy little cars just like the softer curves of the steel flares add it to the whole car. Some interesting ideas floating around your garage! |
tygaboy |
You can see I also updated the notch area. I couldn't resolve that top angle to my liking so decided to try this look.
Note that I just snipped the lower edge of any vents that interfered with the panel sitting down in the hood. I'll work all that out and see if I can account for it in the design. Overall, I do like it better than V1. That said, there are a couple angles where it reminds me of a home heater floor vent! Maybe with the vent sides and mesh added, I'll un-see that... One potential update I think I will do is to narrow the frame dimension. Keep the same outer dimension and widen the vents. In the full frontal shot, the frame seems a bit too much. In any case, I need to look at it on the car for a couple days and see what I think. In the meantime, I welcome your constructive criticism. Attached thumbnail(s) ![]() ![]() ![]() ![]() |
tygaboy |
Speaking of that full frontal shot, with the fog light delete grills I plan to run, the vents are practically begging to run directly side to side. I think I'll make one with horizontal vents and see with that looks like.
djway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California ![]() |
Another possible idea is have them drop down less, shorten up the slat part, say to an inch. You could then consider more slats. This would also get rid of the interference problem with the wheel well.
I dig watching all this. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,795 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Try bending over a bigger radius....air rollout
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
I like it,
I just wonder about making it line up with the headlight bucket as was previously mentioned. |
tygaboy |
Here's tomorrow's "horizontal" test version. Plain as this may be, I think it's going to look pretty cohesive. Maybe not as dramatic, but still pretty cool. We'll soon see.
tygaboy |
Try bending over a bigger radius....air rollout @sixnotfour - I'll give that a go on the next version. Thanks! |
tygaboy |
Another possible idea is have them drop down less, shorten up the slat part, say to an inch. You could then consider more slats. This would also get rid of the interference problem with the wheel well. I dig watching all this. @djway - Glad you're enjoying it. The most recent "horizontal" design uses more and there for less deep vent blades. Once I get an overall design I like, I can tweak to address the niggly things like interference. Thanks! |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,410 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Loving this. If it moves enough air to cool well, it's a winner. Be careful, you'll have orders! (IMG:style_emoticons/default/smile.gif)
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
You need to decide if you want form or function - it is possible to have both but there is a reason I have never seen a race car with hood venting set outside. This tells us something, ehh?
You have the skills to execute something I have always wanted to do but have not - a chambered/funneled closure from the radiator through the hood. Tony |
tygaboy |
You need to decide if you want form or function - it is possible to have both but there is a reason I have never seen a race car with hood venting set outside. This tells us something, ehh? You have the skills to execute something I have always wanted to do but have not - a chambered/funneled closure from the radiator through the hood. Tony @Cracker - Tony, so far, my car is "over-cooling" and not getting up to temp. Granted, I'm not on track but indications are that I have room to sacrifice some functional design for form. And you know me! (IMG:style_emoticons/default/shades.gif) I'll be reporting back as this does/doesn't work out as hoped. |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Have you given any thought to what color the vents would be painted? I think way back in the original rendering they were done in black. It looked really cool from the front! In looking at your pictures you see a lot inside the trunk. How you paint the inside of the trunk will make a difference with those large openings between the vents. Depending on the angle your viewing, the contrast between black vents and body color inside the trunk may be unappealing. Maybe some large black mesh under vents? Maybe paint front trunk area black? Maybe body colored vents and trunk. Anyway some more thoughts. Looking good!
andrewb |
Member ![]() ![]() Group: Members Posts: 114 Joined: 25-May 10 From: UK Member No.: 11,762 Region Association: None ![]() |
How long before you decide you want them motorised to vary the amount of airflow ? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
Seriously though I think they are a little 'chunky'. Particularly in the head on shot - there's too much contrast with the size of the foglight grills ? Just IMO - whatever you do it's incredible. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
How long before you decide you want them motorised to vary the amount of airflow ? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ^^^^^ THIS! (IMG:style_emoticons/default/piratenanner.gif) |
tygaboy |
@andrewb @bbrock - Probably no motorized actuation. Well, at least not until I get a working design for a fixed vent.
Speaking of which - I'm not liking the look of a vent that's made up of a a single layer of sheet metal. So it's on to the next revision. This one is a first go at a "frame with vent slat positioners" approach. Once the crossmembers are bent into position, they serve as the mounting surface for the slats, which I can now make from something thicker to get the look I want. Here's the old vs new look. The new one is wider (same width as the headlight cut out) and a bit shorter. I also moved it up the hood to make it simpler to deal with the hood's support structure. I'm still doing some head-scratching about that. With the vents in the hood, I really don't need to worry about the hood seal, at least not from the fuel tank bulkhead forward. Attached thumbnail(s) ![]() |
tygaboy |
Another of the current design size and location.
Lo-Fi Version | Time is now: 23rd April 2025 - 02:25 PM |
