234 Pages V « < 166 167 168 169 170 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Dec 9 2020, 06:27 PM
Post #3341
Since I'm nothing if not accommodating, and since Rand and AzBanks got to see their suggestions in metal, I figured it was only fair to take a swing at @Cracker Tony (not the vent designer Tony) and @914forme and Stephen's suggestions.
And thanks also, Dan @dan10101 ,for the link to Race Louvers. I read through the data and looked at their various designs. It was that additional info, on top of Tony and Stehpen's prodding that tipped things toward another iteration.
I'm calling these the "all business" version, vs the "form over function" RandAzBanks model.
Anyway, here's the initial go, unpainted so it's easier to see the details, and CAD of the 2nd version that fixes a couple of "oops, I shoulda seen that before making the part".
Key changes:
- a near vertical .75" wicker right at the front.
- all the vents run straight across, no more fancy, changing angles
- V2 CAD vanes: after bending, each subsequent vane is .05" shorter (from .6" down to .3")
- the 45 notch in the front corner is modified to allow the wicker to be as wide as possible while still not interfering with that hood rubber nubber thing.
It'll be interesting to see if there's any detectable difference when I yarn test this one.
914forme
post Dec 9 2020, 09:56 PM
Post #3342
(IMG:style_emoticons/default/aktion035.gif)
Cracker
post Dec 10 2020, 05:19 AM
Post #3343
Atta-boy... (IMG:style_emoticons/default/beerchug.gif)
Cairo94507
post Dec 10 2020, 07:22 AM
Post #3344
Michael
I think that is my favorite of all of them. It's clean and simple in appearance. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Dec 10 2020, 11:02 AM
Post #3345
I figured I may as well work out a possible next step: Adding the shop name!
My plasma table has an engraver attachment that can scribe the metal so why not? If I like it, I'll only add it on the driver side vent.
For the tool whores:
All that's needed is to establish the separate layers in CAD then set up the G-code to run the appropriate operation for each layer. I color-code each layer so it's easier for me to see:
- first run the engraver on the text (in blue)
- switch to the plasma torch to "drill" the holes (in red)
- cut the vent (in black)
Be sure to get the order right so you don't cut an outside shape then come back and try another operation on a "floating" part! Not that I've ever done that... (IMG:style_emoticons/default/headbang.gif)
The 2nd pic is a snip visual of the overall cut program. This is what generates the code that runs the plasma table. Note that it shows I'm cutting 16ga stainless. That's just the "tool" I use to cut .063 aluminum. The "tools" are just presets for voltage, cut height, travel speed, etc. It has nothing to do with the actual material being cut.
mikey63
post Dec 10 2020, 11:07 AM
Post #3346
Very cool feature! Adds a nice custom touch to your car. (IMG:style_emoticons/default/aktion035.gif)
burton73
post Dec 10 2020, 11:27 AM
Post #3347
Senior member, and old dude
Chris,
Your skill set is unreal. A true artist! No need to BS you, so many ideas from your build.
Thanks for sharing it with us.
Bob B
tygaboy
post Dec 10 2020, 12:01 PM
Post #3348
If you have ~ 1 minute to waste and you care to see how I spend part of my day, here's a quick video that shows how I preview the various operations ahead of cutting. Note this is sped up a bunch, just to shorten the video.
When I create the CAD drawings, I end up doing a ton of editing, copying, moving, rotating, snipping off end bits of line, etc. So before I cut the part, I use "single step" in this simulation mode (you can see the options on the right side) and preview each move and cut the torch will make to double check there are no straggler bits in the drawing that are asking to be cut.
Anyway, there you go.
https://www.youtube.com/watch?v=2LgCySbyspQ
tygaboy
post Dec 10 2020, 04:24 PM
Post #3349
This is getting way far away from anything 914 related so feel free to skip!
I haven't used the engraver for anything yet. And of course, it's adjustable for things like downward pressure, so I figured I'd better test it a bit first.
I'm not happy with the "punch" it leaves when it first drops onto the material so I'm still working on that. But it'll be pretty cool if I can get to look the way I want.
tygaboy
post Dec 10 2020, 04:44 PM
Post #3350
Max fail of the day: My engraver offset setting somehow got out of whack!
Man, I hate it when that happens... Oh well, a good reason to do a little maintenance on the table.
Note that this part looks messy because once I realized the engraving wasn't in the right place, I didn't bother cleaning it up.
tygaboy
post Dec 10 2020, 04:49 PM
Post #3351
Fail aside, this is the latest vent design and here you can see the "graduated" vanes going higher to lower as they move rearward.
Rand
post Dec 10 2020, 04:52 PM
Post #3352
Cross Member
Listening. Not to your engraver.
mikey63
post Dec 10 2020, 04:54 PM
Post #3353
I like how it mimics the fender top...high at the front fading out as it goes back.
AZBanks
post Dec 10 2020, 05:24 PM
Post #3354
You should combine the angled vanes with the graduated vane height.
It would be the ( R)and, (A)zBanks, ( C)racker, 914form(e) design or just RACe design for short. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
(IMG:style_emoticons/default/stirthepot.gif)
tygaboy
post Dec 10 2020, 05:35 PM
Post #3355
QUOTE(AZBanks @ Dec 10 2020, 03:24 PM) *
@AZBanks RACe! I like it! But here's the bad news on the angled vanes:
No matter which screening I use under them, it's impossible to have the screen pattern align with each vane. I test fitted the material I want to use and it looks like crap.
If it's angled vanes, it's no screen. And I really like the screen.
I'll post a pic of it but I suspect I can't live with it. Oh, I know! I could commission a custom, varying angle pattern screen... (IMG:style_emoticons/default/shades.gif)
bbrock
post Dec 10 2020, 05:41 PM
Post #3356
QUOTE(tygaboy @ Dec 10 2020, 04:35 PM) *
Or you could install lights that project a holographic hula girl dancing over each grill. Nobody will notice the screens. (IMG:style_emoticons/default/idea.gif)
Rand
post Dec 10 2020, 08:59 PM
Post #3357
Cross Member
OMG. the can too far open. Sorry Chris.
I think enough is enough from our gallery... Once it's out, it's this.
You got this.
Cracker
post Dec 10 2020, 09:04 PM
Post #3358
Well, I rarely occupy anything but first and certainly wouldn't finish third to Rand in anything automotive. I'm swapping orders...congrats on bronze, Rand. (IMG:style_emoticons/default/rolleyes.gif)
I suggest I have offered my opinion because I CARe. (IMG:style_emoticons/default/biggrin.gif)
Cracker
QUOTE(AZBanks @ Dec 10 2020, 07:24 PM) *
Rand
post Dec 10 2020, 10:20 PM
Post #3359
Cross Member
It's sofa frusraighting Tony cracker. So vein. Vane. Vaughn. Vince? Who next? Who who? Who are you?
What I know is Chris has it in the bag.
And now for something completely the same...
https://www.youtube.com/watch?v=oyR3TzIgi-U
AZBanks
post Dec 10 2020, 10:54 PM
Post #3360
QUOTE(Cracker @ Dec 10 2020, 08:04 PM) *
Cracker
LOL!!!!!!!!
- Lo-Fi Version Time is now: 14th December 2025 - 05:06 AM
