232 Pages V « < 185 186 187 188 189 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Oct 28 2021, 05:55 PM
Post #3721
With the various components fitted and things tacked in place, the entire contraption gets pulled to weld on the bench.
tygaboy
post Oct 28 2021, 05:58 PM
Post #3722
Leaving the mounts attached helps ensure the hanger brackets stay in plane to each other during welding. Yes, the melty parts get removed before any significant welding begins.
The welds you see on the edges of the hanger brackets are to close up the scoring cuts I made to force the bend to occur RIGHT where I wanted it. This approach means that from the other side, the side you'll see, it looks like one piece!
Plus, this allows for a crisper bend which, to my eye, makes the part look a bit lighter.
tygaboy
post Oct 28 2021, 06:08 PM
Post #3723
Next was to CAD up a small gusset that ties one hanger bracket to the other.
If you look at the factory trans mount, you'll see a similar design - just nowhere near as stylish. (IMG:style_emoticons/default/laugh.gif)
I added these on the outside only. I'm leaving the inside open to allow for getting the nut and a wrench in there to install/remove the mount.
tygaboy
post Oct 28 2021, 06:10 PM
Post #3724
All welded and back in for a test fit.
tygaboy
post Oct 28 2021, 06:14 PM
Post #3725
It's always a bit nerve-wracking when you weld something out of the car then "see" if it still fits...
With things only set in place, not even bolted down, everything lined up perfectly. Man, I love it when a plan comes together! (IMG:style_emoticons/default/piratenanner.gif)
Last step is to bolt the mounts to the hanger brackets and weld the spreader plates to the chassis.
And no, that's not a missed weld at the gusset-to-cross bar joint.
tazz9924
post Oct 28 2021, 07:42 PM
Post #3726
QUOTE(tygaboy @ Oct 28 2021, 04:14 PM) *
Did you tig weld them?
bkrantz
post Oct 28 2021, 08:41 PM
Post #3727
Sweet!
djway
post Oct 28 2021, 10:13 PM
Post #3728
Tingly (IMG:style_emoticons/default/smile.gif)
Krieger
post Oct 28 2021, 11:05 PM
Post #3729
WOW! That looks sooo good! (IMG:style_emoticons/default/piratenanner.gif)
cassmcentee
post Oct 29 2021, 04:21 AM
Post #3730
"A Thing of Beauty"!
tygaboy
post Oct 29 2021, 08:51 AM
Post #3731
QUOTE(Krieger @ Oct 28 2021, 10:05 PM) *
@Krieger - Credit where credit is due, Andy. As I mentioned when this mod started, it was your eye for design and derogatory comments (IMG:style_emoticons/default/lol-2.gif) helpful suggestion that prompted the effort. If not for you, it likely never would have happened.
When you're next here, you need to sign the cross bar!
rhodyguy
post Oct 29 2021, 02:14 PM
Post #3732
You dreamers/fabricators/welders never cease to amaze me.
Krieger
post Oct 29 2021, 10:59 PM
Post #3733
QUOTE(tygaboy @ Oct 29 2021, 07:51 AM) *
It would be an honor! (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Nov 2 2021, 02:15 PM
Post #3734
With all the dimensions verified, the transmission mount gets (mostly) welded in. I still have to get under the car and finish a could areas. But more than enough is done to allow me to remove the factory cross bar. And you know I've been chomping to get rid of it since @Krieger Andy first suggested I come up with a new mount.
I thought you might enjoy seeing it happen, so, here you go!
https://www.youtube.com/watch?v=ZR5kpPJnKXs
tygaboy
post Nov 2 2021, 02:18 PM
Post #3735
So here's the new look my engine compartment is sporting! I think it looks amazing.
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/wub.gif)
So much tidier and a way better match to the vibe of the build.
mikey63
post Nov 2 2021, 02:24 PM
Post #3736
NICE!!!!! (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif)
Cairo94507
post Nov 2 2021, 03:55 PM
Post #3737
Michael
Wow! Where did all the "stuff" go? Much cleaner look- me like. (IMG:style_emoticons/default/beerchug.gif)
tygaboy
post Nov 2 2021, 05:25 PM
Post #3738
"Mr. DeMille, I'm ready for my close up." (IMG:style_emoticons/default/laugh.gif)
I've been thinking about finishes so I figured it wouldn't hurt to give it a quick squirt of black, since that's part of a theme I'm considering: All the tubes in black, the body in non-black. Still not sure.
Something else that struck me was to have that big ol' main transmission mount cad plated, like the shifter bits you see there on the right side of the trans.
I think what's there now is too much black.
tygaboy
post Nov 2 2021, 05:27 PM
Post #3739
Here are the major parts that got removed. If anyone wants to move their Boxster trans and engine forward 1.5", let me know. I'll give you a good deal on some custom aluminum spacers... (IMG:style_emoticons/default/happy11.gif)
Krieger
post Nov 2 2021, 05:28 PM
Post #3740
Saweeet! That looks so dang clean! Excellent work! (IMG:style_emoticons/default/smilie_pokal.gif) I would have suggested it sooner if I knew you were going to mention me by name in a video! (IMG:style_emoticons/default/lol-2.gif)
- Lo-Fi Version Time is now: 21st April 2025 - 04:10 PM
