232 Pages V « < 35 36 37 38 39 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
bbrock
post Oct 23 2017, 03:03 PM
Post #721
QUOTE(Rand @ Oct 23 2017, 11:53 AM) *
Gotcha. Totally get it on the butt welds. Beautiful headers! Huge respect to the great welders.
The grinding comment just brought up the image of the "eagle crap" welds I've seen. (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/owned.gif) (IMG:style_emoticons/default/blush.gif)
tygaboy
post Oct 26 2017, 05:12 PM
Post #722
914 Rubber's GT Headlight Kit arrived today! (IMG:style_emoticons/default/aktion035.gif)
tygaboy
post Oct 26 2017, 05:29 PM
Post #723
As usual, I'm all over the place. This evening, it was narrowing the flip rear trunk hinge. The Buick it came from is a bit wider than a 914...
I cut the cross bar in the middle then clamped each hinge half to the underside of the trunk seal channel, where that part will eventually be bolted. Then I tied the now overlapping crossbars to each other and determined center, then cut equal amounts off each side.
I then used the lathe to turn down a suitable bolt to make a slug that I plug welded into the cross bars. I'm determined to doing everything I can with TIG vs MIG and this was a good little project for that. So...A little TIG-ity, TIG and... one narrowed flip trunk hinge!
mb911
post Oct 26 2017, 05:30 PM
Post #724
Love it.. Its on my short list but gotta spend 400 on a set of refurbished rockers..
Krieger
post Oct 26 2017, 10:57 PM
Post #725
I like it!
tygaboy
post Oct 28 2017, 09:08 AM
Post #726
The chassis stiffening is nearly completed. Got the seat belt retractor mounts welded in.
tygaboy
post Oct 28 2017, 09:09 AM
Post #727
Final rear suspension tower reinforcement.
tygaboy
post Oct 28 2017, 09:10 AM
Post #728
Locking down the rear suspension-to-fire wall support pad.
tygaboy
post Oct 28 2017, 09:11 AM
Post #729
Final front suspension support tube.
tygaboy
post Oct 28 2017, 03:10 PM
Post #730
Finished installing the MadDog Motorsports front sway bar reinforcement plates.
I decided to to tidy up the rosette welds. Once it's back from blasting and epoxy prime, I'll seam seal around the perimeter. That'll all but disappear the wonky weld lines.
And the Elephant sway bar has their magical misalignment bushings. The bar literally swings, there's so little stiction. Really impressive.
tygaboy
post Oct 28 2017, 03:11 PM
Post #731
Brake line brackets installed and a little primer to protect things for now...
tygaboy
post Oct 28 2017, 05:12 PM
Post #732
Back to the flip trunk hinge.
I worked out the hinge attachment location. (Andy/Krieger was kind enough to let me measure and photograph his installation. Thanks Andy!)
tygaboy
post Oct 28 2017, 05:14 PM
Post #733
I bolted the trunk lid to the stock hinges and adjusted the fit.
Then, with the flip hinge in place and the trunk shut, I can climb under and mark where to install the threaded bosses in the outer stiffener panel of the trunk lid.
I still have final trimming and finishing on that one part of the hinge so pardon the sharp edges!
Krieger
post Oct 28 2017, 05:27 PM
Post #734
(IMG:style_emoticons/default/aktion035.gif) The similar color and your attention to detail will helps it look OEM!
Mueller
post Oct 28 2017, 06:09 PM
Post #735
914 Freak!
That is going to be one impressive rear trunk lid. Cannot wait for videos of it in action.
Cracker
post Oct 28 2017, 07:03 PM
Post #736
Really slick Chris...the King of fabrication!!! (IMG:style_emoticons/default/beerchug.gif)
Tony
914forme
post Oct 28 2017, 07:24 PM
Post #737
Chris I would love to see the measurements, as I have the same setup in my shop, waiting.
tygaboy
post Oct 28 2017, 10:51 PM
Post #738
QUOTE(914forme @ Oct 28 2017, 06:24 PM) *
Stephen -
Sure thing! In fact, I was thinking about you as I was doing this work, knowing you'd be doing the same install at some point. Once everything is in place and I know there's adequate adjustability and it all works as planned, I'll post some pics with measurements.
I can already tell you that to get things where I wanted them, the location of the hinge on my car is measuring out about 1/4" - 3/8" forward of where Andy has his.
The good news is that, near as I can tell so far, the specific location of the hinge (within maybe around 1" - 1 1/2"), isn't that critical. It'll be easier to document once I get it hooked up to the trunk lid and verify my assumptions about the geometry of this contraption!
tygaboy
post Oct 29 2017, 11:59 AM
Post #739
This morning was fabrication of the flip trunk threaded bosses and reinforcement plates that I'll plug weld onto the underside of the trunk, along the outer stiffeners.
tygaboy
post Oct 29 2017, 12:01 PM
Post #740
Plenty of room for adjustment!
- Lo-Fi Version Time is now: 20th April 2025 - 06:25 PM
