232 Pages V « < 40 41 42 43 44 > »
> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
Cracker
post Dec 16 2017, 07:20 PM
Post #821
Your console has "levels"...cool!
Tony
tygaboy
post Dec 17 2017, 09:31 PM
Post #822
I mistakenly took my e-brake remnants to Cary's in OR, but he was kind enough to return them! So part of today was figuring where they'd go. The good news is that with a couple correctly angled holes in the lower cross brace, essentially straight below where they're sitting, these'll end up in the same locations as stock!
Love it...
tygaboy
post Dec 17 2017, 09:34 PM
Post #823
Here's the planned location for the e-brake handle. Forward of stock and with no "cut out" but it'll do just fine. And yes, it's rotated forward so once it's welded in, the handle won't touch the floor.
I'll have to lengthen the connection to reach the e-brake cables but that shouldn't be too big a deal.
tygaboy
post Dec 17 2017, 09:35 PM
Post #824
Oh, I also added a small access opening... (IMG:style_emoticons/default/happy11.gif)
Cracker
post Dec 17 2017, 10:15 PM
Post #825
It did to occur to me until peering through the access panel but I have had issues with those plastic manifold connectors leaking. I'd suggest moving to proper braided lines...sorry for the late notice. Here is mine...its not pretty but its as tidy as I pull off. Come to think of it...the picture below IS your engine! (IMG:style_emoticons/default/biggrin.gif)
Tony
Mueller
post Dec 17 2017, 10:18 PM
Post #826
914 Freak!
That is one plain looking water distribution block, it needs some 3D profiling or pockets or something to match the rest of the motor. (IMG:style_emoticons/default/smile.gif)
tygaboy
post Dec 17 2017, 10:45 PM
Post #827
QUOTE(Mueller @ Dec 17 2017, 08:18 PM) *
If only I knew someone with a CNC machine... (IMG:style_emoticons/default/poke.gif)
Andyrew
post Dec 18 2017, 09:35 AM
Post #828
Spooling.... Please wait
QUOTE(tygaboy @ Dec 17 2017, 07:34 PM) *
Will you be able to grab that with your back against the seat?
Andyrew
post Dec 18 2017, 09:37 AM
Post #829
QUOTE(tygaboy @ Dec 17 2017, 08:45 PM) *
Or laser etching (IMG:style_emoticons/default/biggrin.gif) (again, Mueller)
914forme
post Dec 18 2017, 08:28 PM
Post #830
(IMG:style_emoticons/default/poke.gif) stock hand brake (IMG:style_emoticons/default/confused24.gif) who authorized that (IMG:style_emoticons/default/lol-2.gif)
tygaboy
post Dec 19 2017, 08:38 PM
Post #831
More progress on the "unauthorized" stock e-brake set up... (IMG:style_emoticons/default/shades.gif)
Next step is to braze them in, just like factory.
tygaboy
post Dec 19 2017, 08:40 PM
Post #832
Then it was on to fab work related to the "inspection cover" area. The first step is to reinforce the area I removed.
So, out comes the roll bender and some 1/8 steel.
tygaboy
post Dec 19 2017, 08:41 PM
Post #833
In place with some holes for rosette welding to the lip of the rear part of the fire wall.
bbrock
post Dec 19 2017, 10:00 PM
Post #834
You have the coolest toys. (IMG:style_emoticons/default/aktion035.gif)
jd74914
post Dec 20 2017, 09:40 AM
Post #835
Its alive
QUOTE(tygaboy @ Dec 19 2017, 09:38 PM) *
Very cool!
Have you ever used the Blue Devil SILBRZ rod? It's a silicon bronze TIG brazing rod-not too expensive and works really well if you don't want to drag out the oxy torches and flux. (IMG:style_emoticons/default/smile.gif)
tygaboy
post Dec 20 2017, 10:18 AM
Post #836
QUOTE(jd74914 @ Dec 20 2017, 07:40 AM) *
Very cool!
Yep, just got some bronze rod so will give that a go. Pics soon!
tygaboy
post Dec 22 2017, 05:55 PM
Post #837
First reinforcement piece in place. Let's call this one the "inner" reinforcement...
tygaboy
post Dec 22 2017, 06:06 PM
Post #838
...because here comes the "outer" reinforcement. I want this outer piece to be angled at a particular angle so I can use it as a take off for the removable inspection panel.
So, I started with a paper template. The fun part is to make a flat plate end up at angle but have straight edges, the paper pattern needed to be a curve.
Plus this needs to be roll bent... More fiddly, fiddly.
There was only a little cursing when I screwed up my first attempt. (IMG:style_emoticons/default/headbang.gif)
But with more, um "experience", Attempt #2 worked!
tygaboy
post Dec 22 2017, 06:08 PM
Post #839
And the angle I was after?
The measuring/template making worked! (IMG:style_emoticons/default/aktion035.gif)
(the gap you see is because the vice grips pull it ever so slightly out of position...)
The angle matches the seat back. Silly, I know but there you go...
The real reason I need that angle, or something close to it, is to get the firewall forward enough to clear the fuel lines/fittings.
tygaboy
post Dec 22 2017, 06:12 PM
Post #840
And once this is all welded in, I'll redo the cross bar.
I ended up not liking how much the initial design protruded into the interior space.
This is much cleaner.
And I forgot to mention, I'll plate between the inner and outer reinforcement pieces to tie the whole deal together. In all, it'll be plenty strong for the RaceRod.
- Lo-Fi Version Time is now: 21st April 2025 - 12:13 AM
