stevegm |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States ![]() ![]() |
Hmmm, I could use a new welding jacket... I quit! (Kidding! (IMG:style_emoticons/default/lol-2.gif) ) I never did find out who gets the scarlet letter jacket. (IMG:style_emoticons/default/idea.gif) Who was the official winner, or should I ask who was the official loser. (IMG:style_emoticons/default/poke.gif) I thought I sent it to you. I'll PM when I get home. |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,841 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
October Update
Build thread: http://www.914world.com/bbs2/index.php?showtopic=227430 ACCOMPLISHMENTS 1. Took a picture of me and cleaned off the car (lame, I know and I still need a higher-quality one). It had ~ 2 years of storage on top of it which is all gone now 2. Added sway bar into suspension model. 3. Started engine disassembly. Removed and disassembled intake manifold. Started gutting TGVs (tumble generating valves). CHALLENGES Time! October/November are tough time months since most of the conference deadlines for me are in December. (IMG:style_emoticons/default/sad.gif) VENDORS None this month... ![]() |
stevegm |
Don't forget to post updates for October. Since it is halloween, and we just started the Challenge two weeks ago, we aren't going to hold anybody to having to post their first update before November 1st. But, let's get them posted this week, and we will start official update deadlines for November.
Mitox |
Member ![]() ![]() Group: Members Posts: 416 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States ![]() ![]() |
OK, an introduction is in order:
This is a 1976 914 that is/was originally ivory white. Link to build thread: http://www.914world.com/bbs2/index.php?s=&...t&p=2397587 My goals are: - complete the body prep, strip the underside, repaint and undercoat. - upgrade the front suspension to 911 5 lug - upgrade the rear to 5 lug and 911 parking brakes - install 3.2 from '88 911 - reinstall original interior; I'll tackle a new interior later - dream of other upgrades and make a very long list About me: Name- Michael Todd I live in Southwestern Virginia and am married with one daughter in college, and a son and daughter in high school. This is my first 914; I've been planning this project for the last 15 years after I sold my first Porsche, a 1969 912 ( wish I still had it). I've debated between an all original 2.0 and a GT tribute settling on the latter. I purchased the car late last year with metal flares installed, though they needed a lot of work to correct the installation before the real fun could start. I'm looking forward to the work to come, and especially to driving the GT next fall through the Virginia mountains. I'll post a few progress pics in a day or two; I'm expecting rapid change over the next few months. Attached thumbnail(s) ![]() ![]() |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
3d914 - 914 SHO Build / October Update
Build Thread: Challenge 2017 starts on page 25 Accomplishments: Working mostly in the Rear Trunk and Body Panel areas. The air box has been mocked up in cardboard and test fit. I now have the dimensions to begin the framework design that support the air box. I've decided to combine the hinge framework with the air box framework, and already started the design work. I have a metal supplier in Tucson who will cut the framework pieces for me from the CAD data - which will be faster than me attempting it by hand. Rear firewall section is welded in. It's now ready for primer and seam sealer. Just have to wait till I get design work done and pieces ordered. Started the cleanup in both rear quarters and flares to get the cut-out panels back in. Got the right side panel clamped in- ready for welding. The left side flare has been cleaned and just waiting for panel cement. I'll be fitting and cutting the left side patch panel this week. Challenges: Figuring out the modifications needed for the Mini hinges. Found a used set on ebay and was able to get dimensions off them. I can even retain the mounting bracket. Once I got the dimensions in CAD I was able to verify the movement of the trunk and the hinge to ensure no interference. Vendor support this month: None Pictures: (IMG:http://www.914world.com/bbs2/uploads/post-1191-1477964717.png) (IMG:http://www.914world.com/bbs2/uploads/post-1191-1476579017.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-1191-1477098332.jpg) |
stevegm |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
2017 Build-Off Challenge
Build-Off Part Deux October Update: Michigan Build Michigan Build 2017 Link (takes you to pg:6) 2017 Build progress : Starting with the interior. The goal here is, improve the sound system, and add some comfort, plus a few small things along the way like the new fuse panel, sound padding, and dash layout. In addition I have never taken care of the floor pan. I removed the tar padding, and worked on the dash a bit. Overall I want to keep it "clean" less is more. I have loved the simple dash design from the first time I saw it. That was a '70 basic, not even a fog lamp switch. Removed some Plasti-dip, peel off paint. Unexpected challenges: Removing Plasti-Dip from primed parts of the body work, little bit at a time. I have removed this material before, and a heat gun works best. warm it up, and scrape it off. In some spots it will lift off like a sheet. In others it may pop up due to rust. I found that this time it took a lot of effort to remove. It get tougher with age, the tar not me. : ) Some rust spots, and seems to repair. More surface rust then I thought would be there. This will pay off on my satisfaction meter when done. I also found that with the radio, and glove box removed, theres a lot of space there. I would like to keep the sub, but not the center console. Built a trail foam board box. More to come on this. Vendors: Not this month, but carpet from 914 rubber is on my mind. Progress Pictures: Heres a few shots. See the Build link for more, and the whole story. Thanks for the look. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Michigan Build 2016 Link pg: 1-5 |
CAMshaft |
Newbie ![]() Group: Members Posts: 25 Joined: 26-September 16 From: Charlotte NC Member No.: 20,433 Region Association: South East States ![]() |
Build Thread: http://www.914world.com/bbs2/index.php?showtopic=297659
The theme for October was to inventory my new purchase, familiarize myself with the breed and make a loose plan. I wasn't initially going to do the build challenge thinking that I didn't want to rush or make hasty decisions based on a contest. Giving it more thought I figured I'm going to be doing the work anyway and since there will be a captive audience I'm bound to get more input and it just sounds like fun. Challenges So far has been educating myself on all aspects of the car and motor which has been rewarding but mentally strenuous bordering on information overload. Another challenge is space. I needed to be more efficient with storage of bikes, sports equipment etc. in a single car garage. Progress Take motor down to short block Begin tear down to body-in-white Build a 8'X2' workbench with a lower shelf to hold 914 related stuff Organize the shop Learn about the car Identify vendors Start a shopping list Get everything in order for the challenge (picture folder, 914-world login) Vendors Lowes ![]() ![]() ![]() The craftsmanship of this job is just impeccable. ![]() ![]() Attached thumbnail(s) ![]() |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,554 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
October Update
Challenges Sick Sick Sick: Biggest challenge thus far is me and my family have been sick as dogs for the past 4+ weeks. I'm starting week 3 and my wife and 2YO have been sick for 4-5 week. Makes working on a car project take a back seat for a bit. But we were able to do a little engine work to get it ready to take to my builder friend. Progress - I was able to get the CIS system off the donor motor, with the help of my little one. - I got the following over to my engine/trans builder friend to give it a once over and start assessing the damage ($$$). o - 2.7 Engine o - 901 side-shift transmission - to asses the condition if it can handle a /6 o - Webber 40 cabs, manifolds, airbox o - 3-bearing SC grind cams from Elgin o - stock /6 oil cooler to be cleaned and pressure tested o - early /6 flywheel for conversion - Basically I sent some stuff off to have done and hope it won't break the budget already (IMG:style_emoticons/default/biggrin.gif) - Bought some stuff....I'm really good at that o - Bought new door cards from 914 rubber o - Put my deposit on the new 914/6 heat exchangers being made by mb911 o - Much more buying and sorting of stuff already bought to come (IMG:style_emoticons/default/biggrin.gif) Vendors - 914 rubber has been great as always - mb911 has been great thus far, his progress on the heater boxes is great! Attached image(s) ![]() ![]() ![]() ![]() |
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,838 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Ok. So a tardy pic from October & a current one. Work and family
duty didn't give me much time in garage this past weekend. Started removing welds on sail and left rear quarter panel. I did receive parts from Restoration Design last week as I posted in my "2.4 project thread" Removed boot lid for better access. It needs a respray anyway. Fair warning if ya still have torsion bars connected and you remove that rear boot lid. Those hinges have plenty of force to move without weight on them. And can do bodily harm. Don't ask how I found out. Don't do things when your tired. I zip tied them in closed position. Attached thumbnail(s) ![]() ![]() |
Dion |
Everything's out. Battery tray area & hell hole are just fine.
Darren C |
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England ![]() |
Some great work taking place already on this 2017 Challenge. I'll certainly watch with anticipation of who'll be next years winner.
Good luck guy's Regards Darren Steve, just a quick bump....it's November now and I still haven't had my 2016 Challengers Tee shirt, despite asking numerous times now???? |
DavidSweden |
Member ![]() ![]() Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
Well nothing has happened and no recent pictures of the car I will post later, sorry I have been in England visiting me mum so have had no time
What am I going to do when I finally get my act together? Install 2,2 six Electrics for engine convertion Make oil tank. Make engine tins Make steel roof Make body reinforcements Make heat exchanger boxes around headers Install flares if I can afford it So far got Mad dog engine mount and MSN headers, also a TIG welder but I need to practice. I plan to make the oil tank from aluminium so the TIG is ACDC its second hand unit without too many frills but it works good I am trying to sell my engine its still in the car so I can show and start it if I ever get a buyer. This is holding me up a bit. The roof is a big job, if anyone has some good pics or advice on making the roof then please get in touch. I have looked at Chris Foleys steel roof pics on FB, like I said its a big job for someone with my skill level but I am going to do (attempt) it. This will mean investing in an English wheel? I will start on the roof as I can do this with the engine in. I should mention that I have already done a 5 lug and 911 handbrake conversion, backdated bumpers the car is a 76, Installed GT6 front calipers and 911 rear callipers vented discs and 19mm MS. I dont think there's to much rust as I have allready done repairs and the car was in good condition, but time will tell. Wish me luck |
Curbandgutter |
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California ![]() ![]() |
Ocotober 2016 Update:
Link to my build: http://www.914world.com/bbs2/index.php?showtopic=206845 Accomplishments: Well I finished reinforcing the longs with my truss design. I also added the rear firewall truss connecting the two truss longs at the rear firewall. This will give me greatly increased torsional rigidity. Goal for November: Complete tube frame and install 996 suspension. Extending the wheelbase BTW. Attached thumbnail(s) ![]() ![]() ![]() |
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Ok. Finally an intro
![]() Here is the crew. Many of you know Hugh from Okteenerfest. Gretta is my girl. She likes to help on the car also, but we have not done much lately. Amy (wife) took the picture. My car is a 74 2l 4 cylinder. Marathon Blue Metallic We live in Marion NC not far from Banner Elk where Okteenerfest was for the last two years. Unfortunately I was unable to finish in the last challenge, but if I can only get past this quarter panel problem, I feel like I can make some real progress. I have just about everything to do to my car. I have already done a lot of the metal work, but I still have to finish the seat mount install, fix a small rust hole, trunk lid hinge points and pass rear quarter panel. Then all I have left is everything else! I plan to get the car stripped, then paint it myself, recondition/replace everything and install it. The motor has been mostly built for about 10 years and on an engine stand. I still need to sort out a transmission, all the suspension bits, brakes.... October update: I have not done anything this month, at least nothing that you can see. But Have already started for November! |
Dion |
November update:
As I posted on my build thread, I've removed the rear quarter. Well the hits keep coming... removed some of the undercoat on susp. console. Surprise! A hole (IMG:style_emoticons/default/dry.gif) It is very satisfying however to know that once all this bodywork is addressed there are never anymore questions about its integrity. I always knew the left side of the car was questionable. As a novice to this car hobby I dropped some serious $ having the right long. & battery tray,etc. taken care of. It was done correctly by a pro resto shop. No worries on that side. So it's up to me to shore up this left side. So basically not to bore any more most of the next weeks is cutting and grinding. Nothing glamorous or innovative. I did however receive some pretty trinkets from PMB! Thanks Eric & co.! Attached thumbnail(s) ![]() ![]() |
Dion |
Console
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
Ok, so I'm a late entrant to the build off...
About Me This is my 4th 914, its a 1975, I also currently own a 73 2.0 that's a great driver. The 75 has been a project for too long. A lot of the hard stuff is done and it's pretty far along, but I need to get it over the hump. Since I'm getting a late start I haven't worked on the car since the build off launched. But, my first order of business will be finishing the Engman long kit I've started to install. Build thread coming.... About my car Whats done Rust repair is done. This includes the rear trunk, hell hole, firewall, some small patches in the longs. PO, cut a big hole in the front bulkhead for a fuel cell. I welded in a bulkhead cut from a donor car. Repaired an AC hole in the front trunk. Left partially open for the front oil cooler. Cleaned up a dirty cut for the front oil cooler from PO. Fiberglass flares fit to be bolted on. Fiberglass lids fit Front Fiberglass bumper fit Fiberglass rockers fit Cibie Iode 45 fogs/custom brackets bolted on. 2270 motor built Trans rebuilt Engman long kit partially installed To be done Finish Engman kit install Fix fit on rear fiberglass bumper Get body work ready for paint Get car to paint and body Install 5 lug conversion and Fuchs A whole bunch of assembly Drive it. The project (try to look past the ride height) ![]() The project with the driver ![]() |
Garland |
Build-Off Part Deux November Update: Michigan Build Michigan Build 2017 Link 2017 Build progress : Well on the floor got all the tar off, and found more decay. Imagine that! The pedals were functioning fine, but was sure there could be a concern under there. After removing the under panel to access the pedal mount nuts, and the linkages, and two interior floor mount nuts. Surprise, rust and junk. Ill rebuild the pedal cluster later, but finished the floor, and patched or repaired the damaged spots. Also rust inhibitor on the surface spots. Primer done, and the proper sealer, and Im ready for some sound deadining material next. Unexpected challenges: Still removing Plasti-Dip from primed parts of the body work, little bit at a time. Vendors: Local hardware, and off my shelf. Progress Pictures: Heres a few shots. See the Build link for more, and the whole story. Thanks for the look. ![]() ![]() ![]() ![]() ![]() ![]() |
trojanhorsepower |
November update:
Welding the pass rear quarter on. (IMG:style_emoticons/default/confused24.gif) ![]() Also started to clean up the suspension.... Found a few issues: ![]() ![]() No professional help (God knows I need it) No vendors yet, but getting close! |
Lo-Fi Version | Time is now: 10th April 2025 - 04:22 PM |
