9 Pages V « < 3 4 5 6 7 > »
> 2017 Build-Off Challenge - OFFICIAL CONTEST THREAD, Race to "914 Day"
jasons
post Feb 6 2017, 11:01 AM
Post #81
Jackstand Extraordinaire
Sorry no updates from me for January. I've been distracted by another car for the time being. I have auto-hobby ADD or in other words, too many cars.
I am ordering parts from 914rubber.
trojanhorsepower
post Feb 18 2017, 04:55 PM
Post #82
Jan/Feb update:
Man how do I keep forgetting to update this..... I had really hoped for big news, but I just cant seem to get things together. I got some new parts, but like always cant seem to get them to sit properly.
Vendors: Restoration Designs door sills (no discount though)
No help.
No progress
3d914
post Feb 26 2017, 05:14 PM
Post #83
3d914 - 914 SHO Build / February Update
Build Thread: Challenge 2017 starts on page 25
Accomplishments:
Some progress on media blasting. I did pick up a 40lb media blaster and began remaining paint removal (via soda blasting):
  • Engine bay (90% done)
  • Wheel wells
  • Engine lid
  • Rear trunk & lid
  • Front trunk & lid
  • Remaining body panels
Also removed the muffler heat shield, cleaned it up. Cut reinforcement pieces so that it can be bolted on. Just need to fit and weld the dozen pieces.
Challenges:
Media blasting - it works well, but goes slow. Hood lens is constantly getting covered in powder making it hard to see and requires frequent stops.
Vendors: None this month.
Pictures:
Engine bay & under trunk blasting.
tygaboy
post Feb 27 2017, 10:34 AM
Post #84
February Update
Build thread: http://www.914world.com/bbs2/index.php?showtopic=296900
ACCOMPLISHMENTS - See build thread for the bonus details and photos!
1. Wasted time messing with console plates and rear transmission mounts. Both of which I'll likely not use.
2. Screwed around with fire wall embossing ideas. Doubt I'll use them.
3. Installed Tangerine Racing rear shock tower kit.
4. Final install of upper shock tower cross brace.
5. Removed tunnel and started initial work custom tunnel design/fab
6. Modified and installed rear floor panel
CHALLENGES
No real challenges this month, well OK, the aforementioned wasting time and screwing around items. While that stuff is fun, it's not really moving the build forward. I need to stop working on things that aren't required for getting the car on the road.
Overall, there's a bit of feeling overwhelmed by how much work I've created for myself with what I want to do with this build. It feels like I'm not making progress but then I look at the list of Accomplishments and, well, maybe it's not as bad as I think.
VENDORS
Tangerine Racing (all around awesomeness AND a side of chips!)
Van Bebber (my local metal supplier)
Summit Racing (Tilton Pedals, intake parts, other misc. goodies)
Garland
post Feb 27 2017, 02:33 PM
Post #85
Restoration Fanatic
Build-Off Part Deux
February Update: Michigan Build
Michigan Build 2017 Link
2017 Build progress :
Finally removed all the plasti-dip. Remove the rockers, weatherstrips, and other trim.
Did a little bit of initial sanding, in preparation for primer and paint. Want to get back to the interior but hard to do in cold weather.
Unexpected challenges:
Cold weather.
Vendors:
None
Progress Pictures:
See the Build link for more, and the whole story. Thanks for look.
Curbandgutter
post Feb 27 2017, 06:00 PM
Post #86
FEBRUARY UPDATE
BUILD THREAD : http://www.914world.com/bbs2/index.php?act...=2&t=206845
ACCOMPLISHMENTS:
1) Completed Tube Chassis
2) Bolted up 996 suspension
3) Purchased an Audi S4 donor
4) Purchased a Cayman S transaxle
5) Purchased 996 Twin Turbo hollow spoke alloy wheels
CHALLENGES:
Rainy weather and everything taking twice as long as you think.
VENDORS:
Local guy for the purchase of Audi donor, Cayman trans and rims.
GOALS FOR MARCH:
Install Engine and transaxle, install new floors, close up all of the holes and epoxy coat chassis.
PROJECT PICTURES:
CAMshaft
post Feb 28 2017, 07:58 AM
Post #87
February Update
Little work on the chassis. Working through refurbishing components at this time.
Challenges
Indecision on what to do next. It's a challenge to look at a bunch of parts knowing they all need something and trying to prioritize time and effort.
Progress
I took apart the tail lights to clean them up. red over spray all over the reflectors, missing bulbs.
Vendors
none
Dion
post Feb 28 2017, 10:34 AM
Post #88
RN
FEBRUARY UPDATE:
Slow but sure progress.
CHALLENGES:
Weather and time.
PROGRESS:
Sandblasted chassis areas that needed it. Ordered more necessary parts.
VENDORS:
Pelican. New e-brake cables, fuel lines for carbs.
More pics to be posted on my build thread.
Cheers,Dion
JmuRiz
post Feb 28 2017, 10:37 AM
Post #89
Feb Update:
Still buying up parts, and waiting on Scotty to find a new paint shop so I can finish painting the interior.
Transmission is back!
Engine is being sent out in pieces to be redone. Heads out for full re-freshening and either a new custom valve guide or else I'll need to find a single head. Case will be split and sent out to check out ($$), order pistons and send cyls out for refinishing, crank re-polished, etc etc
ACCOMPLISHMENTS:
- Got my transmission back and put together with the CMS goodies (side cover, intermediate plate, bearing retainer).
Kudos again to Eric Wills at WillsWerks for all his transmission and engine work thus far.
- Got a used set of DC40 cams from member bob, to use with my new hotter spec engine build.
- Ordered new door pockets from 914Rubber via the FaceBook likes discount!
- Started putting up artwork in the garage to get the space cleared on the floor of my garage for parts sorting.
CHALLENGES
Accumulating parts and waiting on engine work to happen...since I'm not skilled enough to build one that won't blow up (IMG:style_emoticons/default/biggrin.gif)
VENDORS
MB911 - (IMG:style_emoticons/default/biggrin.gif)
bob - (IMG:style_emoticons/default/aktion035.gif)
CMS Transmission - (IMG:style_emoticons/default/drooley.gif)
tygaboy
post Feb 28 2017, 11:14 AM
Post #90
Can I just say how cool it is to watch what each of you guys is doing. So much variety! Some highlights for me:
- Dion has 1/2 the side off his car
- Rudy has a one-liner Accomplishment that says "Completed Tube Chassis" (!)
- JmuRiz builds one the prettiest/functional transaxles ever
Simply amazing. Thanks for letting me play along with you.
Chris
Dion
post Feb 28 2017, 11:19 AM
Post #91
RN
Chris, (IMG:style_emoticons/default/agree.gif) .
A lot of talented folks here.
Always learning from you lot. (IMG:style_emoticons/default/beerchug.gif)
Carry on!
Dion
jd74914
post Mar 1 2017, 01:01 PM
Post #92
Its alive
February Update
Build thread: http://www.914world.com/bbs2/index.php?showtopic=227430
ACCOMPLISHMENTS
1. Pulled apart broken center diff to build locker.
2. Sold some stuff/bought some stuff. (IMG:style_emoticons/default/biggrin.gif)
3. Thought a lot about ABS systems...more to come on that.
Really didn't have time to get much stuff done. Hopefully in the coming weeks I'll get the transmission buttoned up and make some headway on other parts.
CHALLENGES
Time as always!
VENDORS
Members only:
914forme - Sweet deal on some Tilton MCs.
jd74914
Post #93
Its alive
QUOTE(tygaboy @ Feb 28 2017, 12:14 PM) *
QUOTE(Dion @ Feb 28 2017, 12:19 PM) *
(IMG:style_emoticons/default/agree.gif) Couldn't say it better. Awesome builds!!
Mitox
post Mar 1 2017, 10:17 PM
Post #94
February 2017 Update
http://www.914world.com/bbs2/index.php?s=&...t&p=2397587
Accomplishments:
Learned to weld this month
Almost completed the rotisserie build/modification
Challenges:
Learning to weld
The rotisserie started life as an assembly tool for aircraft landing gear doors, and doesn't need much modification to be used on the 914. I still need to move the primary casters to balance each end. Then I will make the attachments for connecting to the car. I'll also need to decide how to keep the car in place, since the trunnion brake will not be enough.
JmuRiz
post Mar 2 2017, 08:15 AM
Post #95
Very cool rotisserie project!
Gotta love when you need to do a project to start on another one huh?
Dion
post Mar 21 2017, 09:40 PM
Post #96
RN
MARCH UPDATE:
Challenges: as always, time & weather.
Progress: Cleaned up trunk & floors will be coating with Eastwoods "afterblast"
Painted oil tank.
Vendors: None this month. Wow actually saved $. Heheh
Dion
post Mar 21 2017, 09:41 PM
Post #97
RN
Oil tank
tygaboy
post Mar 22 2017, 06:02 AM
Post #98
March Update
OK folks, this marks the 1/2 way point of the Challenge. Six months down, six to go.
Vegas isn't liking my odds, especially given I did no work on the car this month. (IMG:style_emoticons/default/dry.gif)
None, zero, zilch, nada! Well, that's not completely true. I did decide on and order my wiring harnesses and front swaybar area stiffeners...
But the build was/is on hold while I get the '74 road worthy.
CHALLENGES
One too many cars...
VENDORS
Current Performance: LS stand-alone engine harness
InfinityBox: 20 circuit main harness and some other electonimagic goodies
Maddog Motorsports
Tangerine Racing: I'm sure I bothered Chris about something! (IMG:style_emoticons/default/lol-2.gif)
Curbandgutter
post Mar 23 2017, 09:54 PM
Post #99
MARCH UPDATE
Build thread: http://www.914world.com/bbs2/index.php?showtopic=206845
ACCOMPLISHEMENTS:
1) Set engine and transaxle in place.
2) Purchased headers
CHALLENGES:
Not enough time since we are preparing to go to Europe.
VENDORS:
Header manufacturer
Tube clamp fabricator
GOALS FOR APRIL:
Almost the same as March, Install new floors, close up all of the access holes and epoxy coat chassis
Garland
post Mar 23 2017, 10:22 PM
Post #100
Restoration Fanatic
Curbandgutter
Looking great!
- Lo-Fi Version Time is now: 18th April 2025 - 04:41 AM
