Price Check on Early Dash Pad |
Mike Fitton |
Oct 18 2016, 12:46 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Searched here and on Ebay to try and find one of these for sale and couldn't find anything. What are these early ('70-'71) dash pads worth, I want to sell it but not sure of its value. Has a few flaws as seen in the pictures. The 2 little cracks are not visible when mounted and all mounting studs are there. This is the pad with the larger opening over the glove box for early cars.
[attachmentid=578 374] Attached image(s) |
Mikey914 |
Oct 18 2016, 04:11 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'd imagine they are in line with the current cap prices. Depends on if it's going into a 6 and if theirs is worse.
sixaddict |
Oct 18 2016, 07:04 PM
Senior Member Group: Members Posts: 869 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Personally when the words "nice except" are used it goes from mega $$ to why buy it and go through hassle of changing
Hard to rationalize much unless you have a rat to start with restoring is the same bad or just a few issues |
pbanders |
Oct 18 2016, 07:12 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
You could probably get a local pro at fixing vinyl upholstery to repair those minor flaws and make this top worth more.
altitude411 |
Oct 18 2016, 07:49 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
It has the dreaded sag...otherwise looks good. I still think Marks repop would be an easy adjust to fit early. I know you'll get someone to cash you out. GLWTS
Mikey914 |
Oct 18 2016, 09:56 PM
It has the dreaded sag...otherwise looks good. I still think Marks repop would be an easy adjust to fit early. I know you'll get someone to cash you out. GLWTS The late I make actually does bolt directly on the early frame. In fact the glove box can open fully, as it's mechanically limited before the relief on the bottom. The only way you can tell is to look up from under the dash. |
Lo-Fi Version | Time is now: 26th December 2024 - 12:16 PM |
