6 Pages V « < 4 5 6
> LEDs and housings in stock see post 48----GB ENDS 8/1/17, Got more back in for those that need them
LEd headlight options
How would you prefer to buy (if you would) LEDs to install in your 914
Option 1 Not DOT 2600 Lumens $32 each (H4 not included) [ 2 ] ** [3.03%]
Optiom 2 DOT Approved 3000 Lumens $48 each (H$ not included) [ 44 ] ** [66.67%]
Option 3 Jeep Serries DOT approved 3000 Lumens $98 each [ 20 ] ** [30.30%]
If I bought the bulb only I would probably want the H4 housings too
Yes - Please make it all new and shinny [ 32 ] ** [48.48%]
No - don't need 'em [ 34 ] ** [51.52%]
Total Votes: 132
Guests cannot vote
porschetub
post Aug 21 2017, 04:13 PM
Post #101
QUOTE(Spoke @ Aug 21 2017, 03:08 PM) *
QUOTE(porschetub @ Aug 20 2017, 08:33 PM) *
what is the function of the square box I did notice similar units don't use them,is it a ballast or transformer ??? I really don't , (IMG:style_emoticons/default/beer.gif)
You're close with the transformer. Most likely it's a dc-dc converter to convert the constant 12-14Vdc input power to a constant output current to the LEDs. LEDs are controlled by current, not voltage. A dc-dc converter is usually very efficient and doesn't get too hot.
Thanks Spoke never too old to learn eh (IMG:style_emoticons/default/biggrin.gif) ....ok here I go again bear with me,so why do some not have this box ,mine don't,just plug straight into the 3 pin headlight circuit plug.
Didn't buy the 914rubber ones because found the ones I have locally from a friend that has a auto electrical shop,he mentioned the had sold a lot of them with no issues,just hoping they are ok....reason I asked.
I really would like to improve my lighting as I have rather poor night vision and always have had.
913B
post Oct 7 2017, 08:16 PM
Post #102
Hi Mark, did I miss something, was I supposed to add new wiring for the LEDs. I went to test fit one side and turned it on, there was hum from the internal fan in the bulb, as soon as I went to look at the headlamp. It turned off and I found the the low beam fuse blown.
Did I get a defect bulb or I need to add new wiring for the LED bulb ?
Thanks
Ted
michael7810
post Oct 8 2017, 08:01 AM
Post #103
Must be a defective bulb and/or transformer as long as the wires didn't get pinched somehow in the mechanism. I just installed mine with stock wiring and they work great.
913B
post Oct 8 2017, 12:21 PM
Post #104
No pinched wiring, the headlight assy was not buttoned up yet, everything was not put back together.
That's good to know no new extra wiring is needed.
I am going to plug in the other bulb and see.
My wiring is very unmolested original, plus the headlight was working fine before the install. I even took a before video to look at the improvement when I am done.
Is the fan supposed to be ON as soon as the headlights are turned on.
I didn't realized there was a fan until I heard the humming sound.
Mikey914
post Oct 8 2017, 02:21 PM
Post #105
The rubber man
Been off the board for a few days at work.
Ours are warrantied so no problem dropping you a new one out. We will also test it so it's a known good.
My guess is you got a dud.
PM me your email so I can look up and drop out.
Mark
Mikey914
post Oct 8 2017, 02:25 PM
Post #106
The rubber man
QUOTE(porsche913b_sp @ Oct 8 2017, 11:21 AM) *
Yes fan is on when under power.
6 Pages V « < 4 5 6
- Lo-Fi Version Time is now: 27th December 2024 - 07:25 AM
