6 Pages V « < 2 3 4 5 6 >
> LEDs and housings in stock see post 48----GB ENDS 8/1/17, Got more back in for those that need them
LEd headlight options
How would you prefer to buy (if you would) LEDs to install in your 914
Option 1 Not DOT 2600 Lumens $32 each (H4 not included) [ 2 ] ** [3.03%]
Optiom 2 DOT Approved 3000 Lumens $48 each (H$ not included) [ 44 ] ** [66.67%]
Option 3 Jeep Serries DOT approved 3000 Lumens $98 each [ 20 ] ** [30.30%]
If I bought the bulb only I would probably want the H4 housings too
Yes - Please make it all new and shinny [ 32 ] ** [48.48%]
No - don't need 'em [ 34 ] ** [51.52%]
Total Votes: 132
Guests cannot vote
ConeDodger
post Jul 14 2017, 11:49 AM
Post #61
Apex killer!
QUOTE(7TPorsh @ Jul 14 2017, 02:21 PM) *
Can you still get the headlight covers on with these?
Yes...
Everything is on there. Fully reassembled.
Mikey914
post Jul 14 2017, 11:58 AM
Post #62
The rubber man
QUOTE(7TPorsh @ Jul 14 2017, 10:21 AM) *
The terminaology is a little off, but we do have the housings for the LEDs you can get if you do not already have them. If that is what you mean yes.
-Mark
PotterPorsche
post Jul 14 2017, 12:34 PM
Post #63
Can you let me know once you have more bulbs in stock.
Mikey914
post Jul 15 2017, 01:19 PM
Post #64
The rubber man
Will contact all that have bumped the thread once in.
brownaar
post Jul 15 2017, 08:43 PM
Post #65
Any suggestions on where/how to mount/secure this on the 914 install? Plus, it's a shame Mark doesn't make a modified boot for these for the back of the bulb housing. That thing was a pain.
Thanks,
Aaron
Mikey914
post Jul 16 2017, 12:15 PM
Post #66
The rubber man
I zip tied these to the housing, pics to follow
Mikey914
post Jul 16 2017, 12:22 PM
Post #67
The rubber man
Being a little OCD I also wrapped the connection with a a piece of rubber inter tube and zip tied it also. Wanted to make sure that connections were protected. You can see what I did here
brownaar
post Jul 16 2017, 01:54 PM
Post #68
QUOTE(Mikey914 @ Jul 16 2017, 10:22 AM) *
Thx!
jim_hoyland
post Jul 18 2017, 05:07 PM
Post #69
Get that VIN ?
Got my LEDs today, I see the pictures of the zip tied part; since it has screw holes on the corners, shouldn't it be screwed down ? What's the issue with the rubber cap ? I'm going to do thee install Friday.....
Mikey914
post Jul 18 2017, 11:21 PM
Post #70
The rubber man
I elected to leave the rubber cap off as it really doesn't keep the water out the way it's set up. I've had no issues thus far. I was more concerned with water on the connections. Mostly as the HID units I had on my 951 showed some signs of corrosion. This is a different set up but figured I'd protect it.
For Jim, yes it could be screwed down, but I was able to secure nicely with the zip ties.
ConeDodger
post Jul 19 2017, 12:34 AM
Post #71
Apex killer!
The rubber cap is intended for the H4 bulb. You could use it but it tends to push the socket off the connection. I simply don't ever drive my car in the rain. (IMG:style_emoticons/default/smile.gif)
Mikey914
post Jul 25 2017, 12:25 AM
Post #72
The rubber man
I apologize if I hit a few of you up that already bought these, I just wanted to make sure I did get everyone notified we have these back in stock.
Thanks for your participation on the GB, these took awhile, but I think you will find them worth the wait.
Also just a heads up I have a few GB item going (and of course there will be more coming)
We couldn't make the parts we do without your help!
Mikey914
post Jul 30 2017, 09:51 AM
Post #73
The rubber man
GB ends 8/1/17
MartyYeoman
post Jul 30 2017, 10:20 AM
Post #74
Please add my name for option #2. DOT LED bulbs only. I have H4 housings already.
PayPal sent.
Thanks, Marty
drem914
post Jul 30 2017, 04:42 PM
Post #75
QUOTE(Mikey914 @ Jul 30 2017, 08:51 AM) *
GB ends 8/1/17
Any code needed for the GB?
DRPHIL914
post Jul 30 2017, 08:54 PM
Post #76
Dr. Phil
i installed these in some HID housings that also have halos! couple pictures of them - i did install the rubber caps-
DRPHIL914
post Jul 30 2017, 09:06 PM
Post #77
Dr. Phil
how do i get the headlight housings to stay up?
Nogoodwithusernames
post Jul 31 2017, 04:33 PM
Post #78
QUOTE(drem914 @ Jul 30 2017, 03:42 PM) *
GB ends 8/1/17
Ditto, would like to get a set and have never done one of the GB's before so not sure how they work.
pete000
post Jul 31 2017, 04:51 PM
Post #79
I am in for option 2.
What's the ordering process?
Also is there a reduction of amp draw on the electrical system?
I am having some issues with my voltage dropping during long stops at idle. Might be a tired charging system.
Wyvern
post Jul 31 2017, 05:01 PM
Post #80
QUOTE(Philip W. @ Jul 30 2017, 08:06 PM) *
Turn your key ON
Turn on your headlights
Remove plastic cover in trunk next to the headlight motor ( 2 screws)
Remove the round relay.
Turn off the key and headlights
Your headlight will stay up.
When you put the relay back in it will close (watch where your fingers are as it will really hurt (IMG:style_emoticons/default/headbang.gif) )
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 11:57 PM
