9 Pages V < 1 2 3 4 > »
> Taylors new project thanks to Wes, Rust, just not in the usual places.
cary
post Feb 27 2017, 08:24 PM
Post #21
Lookn good ..........................
Hope to cut out your gas tank/firewall portion this weekend.
Mikey914
post Mar 1 2017, 12:48 AM
Post #22
The rubber man
A few more
Mikey914
post Mar 1 2017, 12:50 AM
Post #23
The rubber man
more
cary
post Mar 4 2017, 10:28 PM
Post #24
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif)
Still need to pull the steering column and windshield frame.
Taylor.914
post Apr 29 2017, 09:31 PM
Post #25
Here is the up date. Had a bit of a sawzall party and made some custom turn signal lenses.Attached Image Attached Image
Taylor.914
post Apr 29 2017, 09:32 PM
Post #26
porschetub
post Apr 30 2017, 04:09 PM
Post #27
Wow clean looking tub,dam those rats that's a hard area to repair,but I know you guys will get there with a bit of (IMG:style_emoticons/default/sawzall-smiley.gif) and a (IMG:style_emoticons/default/welder.gif) keep up the good work (IMG:style_emoticons/default/beerchug.gif) .
wes
post Apr 30 2017, 10:08 PM
Post #28
wes
Looking good really glad to see her coming back to life, looks like this will be a good one in the end.
cary
post Jun 16 2017, 10:16 PM
Post #29
Taylor's project arrived at MiddleMotors this am. It came in style, on a flatbed tow truck. Here's some close ups of the areas that will need some work. It's a shame this really is a pretty good tub. It will need a right suspension ear (early battery acid). It will need a patch in the right engine firewall right behind the passenger (soggy engine sound mat). Doesn't seem to be any cosmetic body damage. But the rat damage is pretty severe.
This is going to be a tag team effort with Taylor and I. By the time we get this thing ready for paint he'll an accomplished welder and spot weld remover. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
Project starts tomorrow at 10am. I plan to arrive around 9am and get the center field section of the front firewall and dash marked out so Taylor can saw away.
Super In Law is going to take and mark down all the X Y Z measurements that might come into play. We discussed welding in a brace between the longs. I'm thinking maybe one between the front shock towers.
Here's right suspension ear. SOP.
It is on a rotisserie so that makes things a little easier.
I can hear the nay sayers already. Crush It.
I'm up for the challenge. Taylor's eager to learn. Lets see how things look after we get the majority on the field sawed out tomorrow. What does it look like behind the spot welds?
Larmo63
post Jun 16 2017, 10:25 PM
Post #30
Keep at it, that looks like a good body/chassis from the outside (at least)
Taylor.914
post Jun 17 2017, 07:22 PM
Post #31
Back at it cutting out the rust and drilling spot welds. Also took some time to clean up the engine and replaced the leaky oil cooler seals with new ones from 914 Rubber.Attached Image Attached Image
Taylor.914
post Jun 17 2017, 07:25 PM
Post #32
cary
post Jun 18 2017, 06:34 AM
Post #33
A couple more shots from yesterday. Taylor had a great day. Got him lined out and and away he went. Gave him a couple coaching sessions on using Rick's grind and peeling spot weld removal technique. He's getting a good feel on what the metal is telling him.
Garland
post Jun 18 2017, 06:57 AM
Post #34
Restoration Fanatic
Taylor,
Welcome to the path that leads to the road of 914 freedom, and the day of its first drive.
Good looking project, and Light Ivory is a great color!
cary
post Jun 30 2017, 10:27 PM
Post #35
Back to work on Taylor's project.
1st. Cut off the nose ................
Pretty much junk ............. You can see the wrinkle on the right side.
When time allows we'll trim some other pieces off. The seal channels are nice.
#2. Off came the needed section. As Taylor is drilling out spot welds on the car tomorrow. I'll ponder how much we're going to use.
#3. Drilled out the center tunnel so it can be saved in it entirety. (IMG:style_emoticons/default/biggrin.gif)
914Sixer
post Jul 1 2017, 06:51 AM
Post #36
I have never seen rust in half those places.
cary
post Jul 1 2017, 07:58 AM
Post #37
Today I'll get Taylor set up removing the trimmed off spot weld flanges inside the project car. Slow tedious work .......................
Looking at it again yesterday it looks like we'll replace the lower 1/2 of the fuel tank/strut support wall.
Still pondering the upper inner fender portion. Will the remaining portion of the dash have to come out to get it in ?
Mikey914
post Jul 1 2017, 11:12 AM
Post #38
The rubber man
QUOTE(914Sixer @ Jul 1 2017, 05:51 AM) *
Rats made a nest in the air box and over time the urine ate the metal. Fortunately, as you mentioned most cars do not have rust here so lots of options for donor parts.
Way to go Taylor keep plugging away!
I know you'll have 150 hours + into this, but I hope we can paint it this late summer so you can assemble this winter. Who knows WCR next year???
cary
post Jul 1 2017, 08:52 PM
Post #39
Taylor had a very productive day. He got most of the spot welds cut out side to side under the dash on the project car. (IMG:style_emoticons/default/biggrin.gif)
Very impressed. He has a good handle on the Rotabroach spot weld cutter.
Taylor.914
post Jul 8 2017, 07:55 PM
Post #40
Weekend update. Finished drilling the welds and removing metal on my car for now. Moved in to scraping the seam sealer cleaning the meatal and began to drill away on the donor.Attached Image Attached Image
- Lo-Fi Version Time is now: 17th January 2025 - 03:14 PM
