15 Pages V « < 2 3 4 5 6 > »
> Bumpers, Stainless steel, Group buy, Gauging interest, $1200/set plus shipping
jet1
post Jan 22 2017, 12:50 PM
Post #61
put me down for a set please.
Option A/ Delete tit bolt holes. N/C
Option B/ Delete front plate bolt holes. N/C
Option D/ Delete rear tow hook hole. N/C
Mark Henry
post Jan 23 2017, 07:34 AM
Post #62
that's what I do!
Important!!!!
Please take note!!!
Sorry but I'm changing how we pick the options from "DELETE" holes to "ADD" holes
I'm doing this because how I labeled the instructions to the manufacturer. I have to switch all the options from delete to add and in doing this I just know there will be a fuchs up.
Again sorry about this, but it's best to change it right now at the source of the issue.
All bumpers have no holes for licence plate, bumperette (tit) or tow ring/hook holes.
You must pick your option holes or you get a bumper with no holes!
Please go to the buyers list at the bottom of the first post and confirm that your options are correct!!!!
http://www.914world.com/bbs2/index.php?act...=2&t=303138
Options
Note I have changed the options from "delete " to "ADD"
All bumpers have no holes licence plate, bumperette (tit) or tow ring/hook holes. (all bumpers will have the bumper top holes)
Please ADD the holes you wish to have.
Option A/ ADD bumperette (tit) bolt holes. N/C
Option B/ ADD front plate bolt holes. N/C
Option C/ ADD rear plate bolt holes. N/C
Option D/ ADD rear tow hook hole. N/C
Option E/ Front bumper cooler mod. $150 (guesstimate price at this point, final price and availability TBA)
All bumpers have no holes unless you chose an option above.
maf914
post Jan 23 2017, 07:57 AM
Post #63
Not a Guru!
Mark, Could you please verify that the rear license plate holes are for US/Canadian style plates as opposed to European style plates. Thanks.
billh1963
post Jan 23 2017, 07:59 AM
Post #64
Car Hoarder!
Mine is correct
Mark Henry
post Jan 23 2017, 08:08 AM
Post #65
that's what I do!
QUOTE(billh1963 @ Jan 23 2017, 08:59 AM) *
Mine is correct
Thanks for letting me know, could everyone confirm their options please.
Mark Henry
post Jan 23 2017, 08:12 AM
Post #66
that's what I do!
QUOTE(maf914 @ Jan 23 2017, 08:57 AM) *
I would say US/Canadian style I believe they are 8mm X 13mm square holes for the factory plugs and licence plate frame.
If you are not using the North American factory licence plate frame I'd order no holes and drill your own.
JmuRiz
post Jan 23 2017, 08:35 AM
Post #67
I updated mine, post #15.
I'll let you know ASAP what I decide on the front cooler hole.
maf914
post Jan 23 2017, 08:43 AM
Post #68
Not a Guru!
My option selection is correct. Thanks.
Bartlett 914
post Jan 23 2017, 09:01 AM
Post #69
Mine is correct. No holes (except bumper top holes).
Mark Henry
post Jan 23 2017, 09:09 AM
Post #70
that's what I do!
QUOTE(JmuRiz @ Jan 23 2017, 09:35 AM) *
I've drawn out the cooler mod, I did it 19.5" X 1.5" with a 18mm radius at the corners
The edges will have the same size radius as the bumpers bottom.
I want the recess to go all the way back to the body with about a 1/4" gap between the body and the bumper.
The bumper should not touch the body, if you want it sealed up I'd do it with foam weather strip tape.
They want to see the mod before they quote it, as soon as I get the price nailed down I will post it.
I'm thinking of getting the prototype with the cooler mod but then I don't see a finished standard bumper.
I might have to get two front prototypes.
Mark Henry
post Jan 23 2017, 09:19 AM
Post #71
that's what I do!
All GT cooler cut out mod, option E, will be notified by PM when we have a price and availability, to confirm if you still want the cooler cut out.
So if you see "option E" beside your name it isn't written in stone yet.
Ed_914
post Jan 23 2017, 01:28 PM
Post #72
Region Association: Europe
Can you change mine to only E as I will drill rear license plate hole to fit EU style plate.
If you can't do E , I will have to remove myself off the list. But I really want E!!!!!!!!!!!!
mb911
post Jan 23 2017, 03:16 PM
Post #73
Mark I would want c and d.. Guess I need to sell my good chrome rear and front that has the gt cut out to find this..
Mark Henry
post Jan 23 2017, 03:33 PM
Post #74
that's what I do!
QUOTE(mb911 @ Jan 23 2017, 04:16 PM) *
Ben just to be clear, do you want the GT cut out or not?
post Jan 23 2017, 03:42 PM
Post #75
914-6 GT in waiting
Mark - c & e please
zoedog
post Jan 23 2017, 06:14 PM
Post #76
Mark
Put me down for a set.
Option C and D
Walt
jet1
post Jan 23 2017, 06:34 PM
Post #77
Mark,
you missed me at the top of page 4.
thanks
lonewolfe
post Jan 23 2017, 08:49 PM
Post #78
I'd like a set with Options B,C,D & E.
I'M ONLY INTERESTED IF E OPTION IS A GO!
zoedog
post Jan 24 2017, 09:03 AM
Post #79
Hi Mark,
Just to be clear so there are no surprises later. Are the following statements true?
a) Bumpers come with mounting brackets
b) Front bumper comes with fog light openings
c) The finish is polished
d) Holes for attaching the rubber top strips are drilled
Thanks for doing this!
Walt
Norskpole
post Jan 24 2017, 10:45 AM
Post #80
Mine is correct (option C, E)
- Lo-Fi Version Time is now: 27th December 2024 - 03:06 PM
