My 73 Suby drivetrain conversion upgrade!, Added a quick video on page 25 |
JRust |
Sep 5 2019, 09:27 PM
914 Guru Group: Members Posts: 6,310 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Went to harbor freight & picked up a fuel pressure gauge. Put it after the pump between the pump & the motor. I still hear it when I turn the key but I get no pressure. Ordered a new pump finally. Should have just done it a week ago (IMG:style_emoticons/default/dry.gif)
Andyrew |
Sep 5 2019, 10:45 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Went to harbor freight & picked up a fuel pressure gauge. Put it after the pump between the pump & the motor. I still hear it when I turn the key but I get no pressure. Ordered a new pump finally. Should have just done it a week ago (IMG:style_emoticons/default/dry.gif) I knew that pump sounded weird... Also check your filters. I had some filters clog me up. |
Chris914n6 |
Sep 6 2019, 02:07 PM
Jackstands are my life. Group: Members Posts: 3,423 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Went to harbor freight & picked up a fuel pressure gauge. Put it after the pump between the pump & the motor. I still hear it when I turn the key but I get no pressure. Ordered a new pump finally. Should have just done it a week ago (IMG:style_emoticons/default/dry.gif) Connect the fuel rail backwards? I did that once... I also replaced my Walbro with a Bosch. The Walbro was LOUD, inconsistent pressure, kinda slow to build pressure, and got super hot. According to Walbro not a chinese fake. |
Chris H. |
Sep 6 2019, 03:34 PM
Senior Member Group: Members Posts: 4,049 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah that pump did not sound right. It's supposed to whine, not make that clicking chugging sound. Hopefully that's all it is.
I've had good luck with the Walbro so far. Never had any pressure problems, but if it's touching ANYTHING on the body directly it's loud as hell due to vibration. I put some insulation around mine and can't hear it when driving. What's the model # of the Bosch you used Chris? |
JRust |
Sep 8 2019, 02:48 PM
Hell yes it's alive although she is smoking quite a bit (IMG:style_emoticons/default/piratenanner.gif) Finally it's running video
Flipping hydraulic clutch cable spraying fluid everywhere. I've got no pedal I've just got to get my wife to come down & push the pedal so I can see where it is leaking from. SO I can't take it for a drive yet (IMG:style_emoticons/default/headbang.gif) |
dan10101 |
Sep 8 2019, 03:48 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Yes Sir!!
Let it run a bit and see if it clears up. It usually does. Most excellent! |
ClayPerrine |
Sep 9 2019, 06:06 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Jamie,
Congrats on the startup. It sounds good. I read your thread, and your trials and tribulations sound like mine. Trust me, when you take it for the first drive after the conversion, you will realize it has all been worth it. Again, congrats! Clay |
JRust |
Sep 9 2019, 07:13 PM
Got my clutch line fixed. Bled it but need to do it a bit more. Took it down to the gas station for some Non ethanol premium. Also have an oil leak above the header I need to find. It pops a fair amount. Next up is getting it to a DYNO for a tune. Hoping to do it this week
Andyrew |
Sep 9 2019, 08:14 PM
Magic number to beat is 288whp
(IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/wink.gif) |
Robarabian |
Sep 9 2019, 10:10 PM
914 A Roo Group: Members Posts: 653 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Got my clutch line fixed. Bled it but need to do it a bit more. Took it down to the gas station for some Non ethanol premium. Also have an oil leak above the header I need to find. It pops a fair amount. Next up is getting it to a DYNO for a tune. Hoping to do it this week Congrats!! Mine is scary at 220 hp. If you break 250 be real careful. |
76-914 |
Sep 10 2019, 06:26 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/piratenanner.gif) Fucking A Tweety. (IMG:style_emoticons/default/beerchug.gif) You made it. I had complete confidence in you all the way, Jamie. Good on ya. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif)
pploco |
Sep 10 2019, 10:11 AM
Chief Toilet Flusher Group: Members Posts: 105 Joined: 15-June 18 From: boise, idaho Member No.: 22,225 Region Association: Rocky Mountains |
Let me know your impressions of that Cobb 20G turbo - I've got the same one for my motor.
Definitely needs a tune. What map are you running now? |
JRust |
Sep 10 2019, 05:33 PM
I'm dropping it by the Dyno shop tomorrow. They are going to work it in over the next 2 days (IMG:style_emoticons/default/biggrin.gif)
JRust |
Sep 11 2019, 03:16 PM
Let me know your impressions of that Cobb 20G turbo - I've got the same one for my motor. Definitely needs a tune. What map are you running now? No idea the map I have I got from Outfront motorsports. They gave me a map to get it started basically. I gave them the specs of my build & they made a map for me. He made it clear I would need to get it to a Dyno for a real tune though. Dropped it off this morning. Am going to run by there before I head home today. They said they would give me a ring when they were ready to put it on the Dyno. Which now that it is after 2. I would assume will happen tomorrow. Update will come when I get one |
JRust |
Oct 4 2019, 09:52 AM
Holy cow it's still at the shop. Every time he'd go to put it on the dyno they would find another problem. Car was getting to hot. I had made the mistake earlier when they were chasing leaks. It was leaking from around the water pump. It was leaking where the thermostat goes. In pulling that they noticed no thermostat & put one in. I said that was fine without remembering the thermostat just causing problems with the long lines we have to run. Got that taken back out & it stays under 210 with no problem. Fans kick on around 195 I think. Then stays around 200. Which I am great with. So they go to put it on the dyno again yesterday & I am having a super lean fuel issue in random spots. Looks like my fuel pump wires were loose. The other possibility is the fuel pump itself might be a problem. It was a new one I bought on amazon that was fairly cheap but had the right specs. Really I just bought it to rule out my original pump had failed. Apparently the one I bought has some reviews with the same symptoms it was having going lean. I'll find out today if he get's it back on the dyno & I still have a lean issue. Seems like I am have been right on the verge of having my car back running & driving for like 2 months (IMG:style_emoticons/default/headbang.gif) .
I do still need to get a new cable from the gas pedal to the throttle. I have a stock cable but it isn't long enough with my new setup. It works but isn't great. Is there a stock cable that is longer than your standard 4 cyclinder? Does the six have a longer cable? |
Andyrew |
Oct 4 2019, 11:42 AM
Holy cow it's still at the shop. Every time he'd go to put it on the dyno they would find another problem. Car was getting to hot. I had made the mistake earlier when they were chasing leaks. It was leaking from around the water pump. It was leaking where the thermostat goes. In pulling that they noticed no thermostat & put one in. I said that was fine without remembering the thermostat just causing problems with the long lines we have to run. Got that taken back out & it stays under 210 with no problem. Fans kick on around 195 I think. Then stays around 200. Which I am great with. So they go to put it on the dyno again yesterday & I am having a super lean fuel issue in random spots. Looks like my fuel pump wires were loose. The other possibility is the fuel pump itself might be a problem. It was a new one I bought on amazon that was fairly cheap but had the right specs. Really I just bought it to rule out my original pump had failed. Apparently the one I bought has some reviews with the same symptoms it was having going lean. I'll find out today if he get's it back on the dyno & I still have a lean issue. Seems like I am have been right on the verge of having my car back running & driving for like 2 months (IMG:style_emoticons/default/headbang.gif) . I do still need to get a new cable from the gas pedal to the throttle. I have a stock cable but it isn't long enough with my new setup. It works but isn't great. Is there a stock cable that is longer than your standard 4 cyclinder? Does the six have a longer cable? Fuel delivery issues are no fun while tuning... (IMG:style_emoticons/default/sad.gif) Make sure your filters are not clogged. Plumb in a fuel pressure gauge. |
Oct 4 2019, 01:02 PM
914-6 GT in waiting Group: Members Posts: 19,643 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The six uses a bellcrank. Terry cable can make a custom length cable.
Chris914n6 |
Oct 4 2019, 02:26 PM
IIRC 914rubber makes their own, if so they could likely build a one off to your specs, or to Suby swap specs if it's a pretty common problem.
Chris H. |
Oct 4 2019, 02:47 PM
JRust |
Oct 4 2019, 07:41 PM
Yeah fuel pump I bought was a piece of crap. It is cutting out just like a few of the comments on it. Which I didn't bother to read when I bought it. I really did consider it a temporary pump so no biggie. So have a Walbro coming
Lo-Fi Version | Time is now: 23rd December 2024 - 06:50 AM |
