Headlamp switch wiring |
JFG |
Feb 3 2017, 11:59 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I couldn't find a detailed colour coded guide for refitting this switch.
Luckily I found 2 pictures of full / part wiring taken at strip down. Most of my tear down pictures were in the great PC crash of 2016. My switch has 11 connections and is from a 1974 2.0 model. There may be variations. As this was taken from the car pre wired I do not know if it 100% correct as I could not test prior to stripping and right now I can't test to confirm. If it is wrong I would be grateful if someone can advise on corrections. The connections and wire colours are as follows 58R grey with red stripe 30 single red 58L grey with black stripe twin wires 15 red with red and white stripe twin wires K grey with yellow stripe 57 white with green band 56 red with white stripe and black twin wires 56K grey 58b black with blue stripe single wire 58a black with blue stripe multiple wires 30b green *****Edited to correct positions 58a & b as per diagram below |
JeffBowlsby |
Feb 3 2017, 12:25 PM
914 Wiring Harnesses Group: Members Posts: 8,818 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Headlight Switch 74-76
JFG |
Feb 3 2017, 01:56 PM
Thanks for the diagram. I checked your site but couldn't find that.
Looks like I have my black/blues back to front |
Lo-Fi Version | Time is now: 2nd February 2025 - 12:59 AM |
