| Cal |
Feb 4 2017, 01:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I recently purchased an original exhaust for my '74 2.0L that's in excellent condition. I was thinking of using the VHT SP104 high heat flat grey paint to finish it off....any advise on other paints that I should consider?
I'm also going to repaint the heater control flaps, boxes and pipes in satin black.....do those need high heat paint as well? Attached thumbnail(s) |
| 914Next |
Feb 4 2017, 02:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 714 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest
I recently purchased an original exhaust for my '74 2.0L that's in excellent condition. I was thinking of using the VHT SP104 high heat flat grey paint to finish it off....any advise on other paints that I should consider? I'm also going to repaint the heater control flaps, boxes and pipes in satin black.....do those need high heat paint as well? Very nice. I wouldn't paint it if I were you. |
| Tom_T |
Feb 4 2017, 02:22 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Congratz on the find Jeff! Is it the Leistritz or Bischoff?
Try emailing to Bev & Tom Gould at TC's Garage & ask them to check if they've been able to find the "Porsche Exhaust Gray" which Wurth used to sell, since they're Wurth dealers, Tom is an ex-914er, & they're both some of our most experienced Concours judges in Zone 8. email Tom at tom@tcsgarage.com or call 760-891-8151 Their website is having some tech problems right now at: tcsgarage.com .... .... but their Facebook page is working at: https://www.facebook.com/TCsGarage/?ref=page_internal If they can't find the Wurth, then ask them what they used on BeeVee's 911 exhaust. You can say that I referred you for their expertise. Stoddard's used to sell it too. Otherwise, you may need to do a color match, cuz that Hi-Temp paint isn't really close to the gray Porsche has used on their 149-90's +/- exhaust systems. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| Tom_T |
Feb 4 2017, 02:57 PM
Jeff, see the PM I just sent you on this.
Stoddards/NLA, Sierra Madre Collection (see banner ad on here), & other Porsche parts suppliers who carry Wurth may also be sources. http://www.stoddard.com/ http://www.nlaparts.com/store/ > (Stoddard's 356 e-Store that used to carry Wurth' Porsche Exhaust Gray paint) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| 914Sixer |
Feb 4 2017, 03:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,389 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I ordered exhaust paint from Stoddard in November 2016. Still waiting. I guess I will try calling Monday.
| Tom_T |
Feb 9 2017, 06:44 PM
Jeff,
FYI - per my PM, here's a close-up pic of where the Bischoff name is on my older but low mile OEM 2.0 Banana muffler from 1980-ish - between the rivets on the inside facing forward when installed, & between the L & R exhaust inlets. I'd assume that the Bishoff, Leistritz or other mfgr name on your new/NOS one is in a similar location, or they may just use a simple logo by the 2010-11 date on yours. BTW - the 04 7 on there is not the date for mine, since I put it on the car in 1980-ish & still have a lifetime warranty from Midas on it! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| dcheek |
Feb 10 2017, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
I've used the VHT SP-104 for years. It doesn't last very long, especially after driving in the rain a couple of times. It will eventually show some rust.
They only thing that will last is to have it ceramic coated. Expensive but will last a very long time. Dave |
| Mark Henry |
Feb 10 2017, 10:14 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I've had the best luck with black BBQ/wood stove paint, but it doesn't stand to any road debris for much more than a couple years. Also some cheap ceramics (china T1 stuff for one example) also don't stand up to the real world for very long.
You gets what you pays for. |
| 914Sixer |
Feb 11 2017, 07:15 AM
Talked to Stoddard yesterday, they no longer have exhaust paint in the spray can. It is now only by the quart for $60. Not going to work for the average person.
| Cal |
Feb 11 2017, 08:44 AM
Talked to Stoddard yesterday, they no longer have exhaust paint in the spray can. It is now only by the quart for $60. Not going to work for the average person. Sierra Madra carries the Stoddard grey exhaust paint in a spray can. Has anyone used this before? http://www.sierramadrecollection.com/High-...rey-p28203.html Attached thumbnail(s) |
| Krieger |
Feb 11 2017, 08:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,834 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I used 3m Weld Through on my stock 911 muffler. I tried it because it is what I had and was tired of spending $ and making parts runs. It has held up extremely well with track use over 18 months. Three years total time. No used in wet conditions though. I would buy a can to do this again. I wire wheeled and cleaned before I sprayed.
| Tom_T |
Feb 11 2017, 12:06 PM
Talked to Stoddard yesterday, they no longer have exhaust paint in the spray can. It is now only by the quart for $60. Not going to work for the average person. Sierra Madra carries the Stoddard grey exhaust paint in a spray can. Has anyone used this before? http://www.sierramadrecollection.com/High-...rey-p28203.html Jeff, Double check back with Stoddard to verify that this at SMC is the same paint as their quarts, & that they're both the same color as the former Wurth Exhaust Grey Paint. If it is, then it will be a good match to the 1950's - 70's Porsche exhaust grey color, but may show up a bit lighter than the paint currently on your muffler. I'm not sure it it was a tad darker grey originally, or if it's darkened with age & oxidation. I've judged several 356s & 911/912s with their exhausts done in the Wurth/Stoddard Porsche Exhaust Grey, & they look really good. I'd suggest that you can paint both your muffler, & your SS HEs that you had an earlier topic about (if you're still planning to do so), at the same time with this exhaust paint, so that everything is in the same grey & same age for oxidation/color fade/change over time. So try to buy all of your paint at the same time from the same case(s)/batch, so that they're all in the same color mix batch - rather getting some now & more later. Also get a can or two extra at the same time/batch in case you need to do any future touch-ups. Thanx for doig the research on the current supplier on this. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| Tom_T |
Feb 11 2017, 12:12 PM
I used 3m Weld Through on my stock 911 muffler. I tried it because it is what I had and was tired of spending $ and making parts runs. It has held up extremely well with track use over 18 months. Three years total time. No used in wet conditions though. I would buy a can to do this again. I wire wheeled and cleaned before I sprayed. Wurth also makes a high-zinc (98% IIRC) weld-through primer which dries to a similar grey to the Porsche Exhaust Grey color - which I've used to prime areas on my 914 after wire-wheeling off surface rust as a rust preventative holding measure as I slowly work on my 914. But I don't know if theirs, 3M's nor Eastwood's zind-rich weld-through primers are high temp for use on exhaust systems. If so, then I would still use them as the primer coat to prevent more rust, then top coat with something like the Stoddard Porsche Exhaust Grey Hi-temp paint as the top coat, since the primer is more porous, while the paint will seal out the moisture better. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| Cal |
Apr 3 2017, 08:15 PM
Update.....I ended up using the VHT SP100 primer and the VHT SP104 flat grey finish paint. It turned out very close to the factory grey color and very easy to work with. I just need to cure it per the manufacture specs.
| Tom_T |
Apr 3 2017, 08:25 PM
| Jett |
Apr 3 2017, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,694 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest
| Lucky9146 |
May 4 2017, 03:21 PM
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,694 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California
| Tom_T |
May 4 2017, 03:52 PM
For those looking for a PC or Ceramic option close to OEM gray -
There are both a Ceramic & a Hi-Temp PC Gray which is very close to the original Porsche "Exhaust Gray" paint shade, but you have to really go thru the color chips books to find the right one, & then compare it with the actual paint on an NOS exhaust part or the OEM paint in the sunlight for a proper match. While it looks like a beautiful PC job on your -6 Banana - that's way too much "butt-bling" on a 914 for me! (IMG:style_emoticons/default/biggrin.gif) .... ergo I'm considering painting or Ceramic or HT PC coating gray on my SSI SS HEs, to match the Leistritz Sport Banana 2L muffler for my 73 2L. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| horizontally-opposed |
May 4 2017, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
You might try West Coast Powder at 925 682-4828. I spoke with Kelly.
They have a light gray and a white that interested me, but while the light gray is close it has some sheen to it. If you want true factory looks that will last, I was told one way to get there is to ceramic coat it, then etch the coating, then apply another coat (primer) in a ceramic setup, and then finally hit it with light gray VHT. I have tried the VHT route and it peeled quickly. It's a non-starter for me. Jet Hot Coatings offers a nice light gray as well. It has a very small amount of sheen to it, as well, but I may go that way. Let us know how it goes if you beat me to it, will you? (IMG:style_emoticons/default/beerchug.gif) pete |
| mb911 |
May 5 2017, 05:25 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,711 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Look up cerakote. Its a ceramic paint and is high temp. Either oven bake or air cure. I use air cure for my 911 fan and fan housings restorations.
Lo-Fi Version | Time is now: 15th January 2026 - 08:25 AM |
