Wild 6 |
See you at the next autocross. ![]() ![]() Group: Members Posts: 212 Joined: 16-November 04 From: Phoenix, AZ Member No.: 3,128 ![]() |
To solve the problem, I purchased the Weltmeister tranny mounts and drilled out the mounting holes. WEVO claims their mounts are already slotted.
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
yes the wevo mounts have the holes slotted... ask me how i know. if you lose a bolt on the front body side it will allow them to slip far enough to come off the ear
TMorr |
Tracey of Windrush ![]() ![]() Group: Members Posts: 85 Joined: 28-January 03 From: San Carlos, CA USA Member No.: 205 ![]() |
Joe, The WEVO 915 SideShift kit is designed so the center of the mount hole on the ear is the same dimension from the RFOB (Rear Face Of Block - nee crankcase) as the 901 transmission. If you have misalignment with a 915 and our kit installed, you would also have misalignment with a 901 attached to the same motor in that same chassis. The 901 uses the slot for the M12 bolt - a solution we do not like, for reasons experienced by Scott Thatcher. The slot allows the transmission mount to accommodate some misalignment, but at the risk of transmission mount security - especially if you unwittingly mount the bolt at the edge of the slot in an effort to compensate for incorrect engine mount locations. I would suggest the following; 1) Loosen your front engine mounts - at all possible locations - and determine if they wil allow you to move the engine to a position where the bolt will go through the ear without pre-load. 2) If 1 does not work - question the front engine mount installation? is it O.E.? Is it aftermarket? what is the possibility that it is not accurately installed relative to the original transmission mount feature on the chassis? 3) If 1 did not work and 2 reveals some lattitude for error, evaluate your options. One option is the WEVO 914 SS Transmission mounts. This has some adjustment via the slotted holes. Whether or not it would be enough for the error on your car is something you need to measure. Another option, as Andy used, is to file slotted holes in 911 engine mounts. These require slots just to have the correct hole spacing for the 914 transmission mount bolt pattern, so extra slotting would be required to allow the trasnmission to be located in a non-standard location. 4) Call me and I will try and help you resolve the issue - regardless of the root cause. The language used in the installation instructions regarding misalignment is intended to prevent people from levering the transmission into a position where the bolt "can" be "installed". The #1 unit installed in Andy's car was levered into the car so badly (installer to remain nameless) that it damaged the car and the casting and lead to a cracked casting. We can help customers avoid this self inflicted failure by sharing that information. The speculation that it is linked to a dimensional error on the SideShift casting is without foundation. Regards Hayden PTB Tracey. |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
I finished mounting the WEVO tranny in the car today. I slotted the hell out of some Weltmeister solid mounts and now it fits fine, with no 'preload'.
Now I need to sort out the shifting. To all who have done this: I would like to see pictures of your shift linkage between the firewall and tranny. |
Series9 |
Yes, I took too long on this project. Liz's car and my GTI have kept me very busy over the last month.
However, I drove the RS today for the first time with the WEVO tranny! What can I say....WAY, WAY, WAY better. I fabbed up the linkage and performed the initial set-up. I got all six (w/reverse) gears the first time. Very nice. It needs a little fine tuning, but I'm already 98% there. Someone said it would shift like a 993. Not that good, but way north of acceptable. I'm very pleased. Pictures folllow. #1: The front of the linkage as I received it from Patrick for the former Vellios conversion. #2: The rear of the linkage after I stole Liz's steering linkage and modified it for this application. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) #3: Another view of #2. Attached image(s) ![]() |
Series9 |
two:
Series9 |
three:
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Series9 |
Made one more adjustment on the shift linkage today.
The RS is 100%! Despite my complaints about mounting the tranny, I was really only concerned about the way it would shift. I am extremely pleased. The RS is back in service. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) the "U" joints. Have you ever thought about using a liniar bearing inplace of the firewall bushing? I have a couple and some persision 3/4 " shaft. I'll send you one just to play with. Even if you never use it they make a great conversation piece.
I'm traveling all week for my job. The box is taped and dry sitting in my garage. I'll try to get it shipped on Friday. (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Series9 |
Send the bearing, I'm interested. |
914Timo |
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe ![]() |
I have. I have a spherical bearing inplace of the bushing. Much better. Tighter. I wish I have a good pic of it...... |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Definately bookmarking this for when I get the 915 in my car.. Wevo is what I want to go with!
nocones |
Sportscar lunatic ![]() ![]() Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 ![]() |
Joe,
Congats on a successful install and a smooth shifting RS! I've been interested to hear your results. I've got the 915 behind my V8 and will be doing the WEVO once funds allow. It's nice to hear from an another unbiased owner. Enjoy the ride and let us know how the bearing works out. |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
Damn that is a clean car. I would venture to guess that your tranny alone is worth more than my entire car.
Looks good! |
Lo-Fi Version | Time is now: 26th June 2024 - 07:11 AM |
