Flywheel for 6-conversion to 901 gearbox, Vendors disagree on part no. |
rwfms |
Mar 9 2017, 09:00 AM
Newbie Group: Members Posts: 17 Joined: 4-January 06 From: Wichita, KS Member No.: 5,365 |
(IMG:style_emoticons/default/agree.gif) the starter stock is more than enough,Bosch make great starters when I reconditioned them years ago most only needs a clean and lube,the worst I found needed commutator machined and new brushes and these were old starters back then,save the reduction high torque starters for high comp petrol motors and diesels (IMG:style_emoticons/default/dry.gif) . Sounds like the OP may have had a flywheel with no induction hardened teeth...easy to check with a hand file the tips should be bloody hard. Thanks for the tip. I'll let you know when I get the gearbox out. Ron Sorry to seem forgetful but did we work out what your engine was ,sorry but never googled your part number for the flywheel presume a 6 bolt ? '70 911 2.2E, 6bolt |
rwfms |
Mar 9 2017, 09:09 AM
(IMG:style_emoticons/default/agree.gif) the starter stock is more than enough,Bosch make great starters when I reconditioned them years ago most only needs a clean and lube,the worst I found needed commutator machined and new brushes and these were old starters back then,save the reduction high torque starters for high comp petrol motors and diesels (IMG:style_emoticons/default/dry.gif) . Sounds like the OP may have had a flywheel with no induction hardened teeth...easy to check with a hand file the tips should be bloody hard. Thanks for the tip. I'll let you know when I get the gearbox out. Ron Sorry to seem forgetful but did we work out what your engine was ,sorry but never googled your part number for the flywheel presume a 6 bolt ? I think Root Werks is right about the timing marks on the flywheel. I haven't confirmed that with the vendor but I will. |
larryM |
Mar 11 2017, 01:48 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
I prefer the 74- up 911 starter. The starter is 1.5 hp, almost twice the horsepower of the .8 stock starter. Plug and play. be aware - there was a run of those 1.5 starters that had a "thin" nose bushing - which tended to crack - resulting in chewed-up ring gear i trashed 2 new 914-6/901 flywheels with one of those 1.5 Bosch starters (that i b'ot new) before i found that cause on a pelican thread - i no longer know the link but it was circa April 2012 after i posted the message below: - you can just get the ring gear replaced by RIMCO - they do a nice job and understand our stepped flywheels http://forums.pelicanparts.com/porsche-911...ear-repair.html i now run a genuine IMI HiTorq on my 3.2 - and on my 454 chevy - both b'ot on eBay - if ya just want a good used higher torq oem 3.2 Bosch starter ('89) - i have one on shelf FS . |
Mar 11 2017, 01:56 PM
914-6 GT in waiting Group: Members Posts: 19,512 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I prefer the 74- up 911 starter. The starter is 1.5 hp, almost twice the horsepower of the .8 stock starter. Plug and play. be aware - there was a run of those 1.5 starters that had a "thin" nose bushing - which tended to crack - resulting in chewed-up ring gear i trashed 2 new 914-6/901 flywheels with one of those 1.5 Bosch starters (that i b'ot new) before i found that cause on a pelican thread - i no longer know the link but it was circa April 2012 after i posted the message below: - you can just get the ring gear replaced by RIMCO - they do a nice job and understand our stepped flywheels http://forums.pelicanparts.com/porsche-911...ear-repair.html i now run a genuine IMI HiTorq on my 3.2 - and on my 454 chevy - both b'ot on eBay - if ya just want a good used higher torq oem 3.2 Bosch starter ('89) - i have one on shelf FS . Great info! |
Lo-Fi Version | Time is now: 25th September 2024 - 06:58 AM |
