nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
sure, that fuel leak probably fixed itself. go for a drive.
AND BRING SOME FREAKIN' MARSHMALLOWS!! |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
so where was it leaking from? if you actually saw it dripping while you car was idling in the driveway, did you have a chance to trace the leak anywhere more specific?
ferg. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Yeah, replace the hoses. It's not hard work or rocket science. You will learn to hate gas though... (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) |
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
it was dripping down on the passenger side under the HE, but i could not locate the source. The mechanic has not been able to re-create the leak, and he left it idling for about a total of 35 minute (in intervals). we have both tugged on all of the hoses, and no more leak.
Gint |
Replace all of the rubber fuel lines anyway.
TROJANMAN |
when Pat put the engine back together, he said he only had to replace one bad hose, and all of the others were in good shape.
TROJANMAN |
it's funny you say that, the mechanic has a fire victim 914 in his lot. |
nebreitling |
which 'other ones'? the ones that had sat for 2 1/2 years, or the ones which are 30 years old?
bro: either you had a fuel leak or you didn't. if you were not on psychotropic drugs and feel that the fuel leak was, in fact, real, then you need to replace some fuel lines. period. sorry if i'm being an ass but these things REALLY DON'T fix themselves, and i'd hate for you to lose the car over something as easy and relatively inexpensive as fuel lines. n |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
My 914 leaked a significant amount of gas from the bodies of a couple of the fuel injectors that would go away when they got hot. The seals in the casings went bad.
Fuel pumps can probably do similar things also. Don't drive the car until you isolate this. |
TROJANMAN |
that's funny, because i feel like i was on drugs, since i was the only one to see it. but i agree with you. |
DJsRepS |
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 ![]() |
Do change all the rubber gas lines over and under the motor and replace the fuel filter for good measure. There is no one fix on old lines. Then check all the clamps every oil change. Fuel pump leaks are common leaker too and can be rebuilt/resealed. Also check fuel pump pressure clogged return can 4x the presure.
TROJANMAN |
found the leak. fifth time he let it run for the day, and it started leaking profusely right after it started. makes me feel better knowing i wasn't on drugs. strange though,that the leak would come and go like that. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Ferg |
good deal (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
914MF |
Member ![]() ![]() Group: Benefactors Posts: 176 Joined: 4-September 03 From: Denver, CO Member No.: 1,112 ![]() ![]() |
Did he tell you where it was leaking from?
TROJANMAN |
one of the hoses running the topside of the engine. can't figure out why it leaked sporadically though. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Lo-Fi Version | Time is now: 30th June 2024 - 06:37 AM |
