18 Pages V « < 4 5 6 7 8 > »
> '73 2.0, a yellow storage unit find
arne
post May 20 2017, 05:47 PM
Post #101
Serial Rescuer of old vehicles...
QUOTE(Calvinator2016 @ May 20 2017, 04:41 PM) *
Looks Great!
Yes, and even better after cleaning. Moving to the scary side now.
arne
post May 20 2017, 06:09 PM
Post #102
Right side. Very nice as well.
ConeDodger
post May 20 2017, 07:31 PM
Post #103
Apex killer!
(IMG:style_emoticons/default/w00t.gif) one of those oh thank goodness moments!
arne
post May 20 2017, 07:46 PM
Post #104
QUOTE(ConeDodger @ May 20 2017, 06:31 PM) *
No kidding. It was really about what I had expected, based on crawling under the car prior to purchase, but in the back of my mind there have been these doubts....
bigkensteele
post May 20 2017, 08:05 PM
Post #105
Major Member
QUOTE(euro911 @ May 18 2017, 01:00 PM) *
It's always nice to have some help doing this, although it's not impossible to do alone.
My method for engine removal and installation never requires an assistant. Just two pieces of threaded rod and a floor jack. Piece of cake.
Search "threaded rod", and you will find it.
euro911
post May 20 2017, 09:30 PM
Post #106
QUOTE(bigkensteele @ May 20 2017, 07:05 PM) *
Well yeah, experienced guys can do it in their sleep ... but really, who likes drinking beer all by themselves (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/poke.gif)
arne
post May 24 2017, 03:15 PM
Post #107
Engine drop prep continues. Exhaust is out today.
Man, that is much heavier than I would have guessed.
Actual drop itself will be postponed a day or two. Another local 'teener (JB620) has contacted me, offering to loan me a brand new, never used Tangerine Racing Engine Lift Plate as soon as it arrives in the next day or two. I will gladly wait a bit for that kind of much appreciated help!
In the mean time, disconnecting all the other stuff will continue.
post May 24 2017, 04:36 PM
Post #108
914-6 GT in waiting
QUOTE(arne @ May 24 2017, 05:15 PM) *
I used the tangerine engine lift plate when I helped Zach - vacca rabbi, with his engine install. It's definitely worth waiting for.
euro911
post May 24 2017, 04:56 PM
Post #109
I always remove the muffler before the heat exchangers ... because, yeah, the whole enchilada will be unwieldy.
arne
post May 24 2017, 05:03 PM
Post #110
I will probably put them back on that way, but didn't want to fight the rusty bolts to pull the muffler off. Easier to cut those off out here in the open.
Which reminds me - one fear was unfounded, I didn't break any exhaust studs during the removal! 5 of the 8 studs came out of the heads, but I am totally fine with that.
arne
post May 24 2017, 07:30 PM
Post #111
Other observations -
The little thermostat bellows works fine (tested with heat gun), but the wire cable that it pulls on is either disconnected or broken, so the flaps are in the hot engine position all the time. Will need to address that while it is out.
Want to replace the taco plate o-ring and crush washers, but it doesn't seem to have slack in the wire to pull it down far enough to get at the o-ring. Will need to look at that while it is out also.
Most of the rest of things looks pretty good, aside from oil leaks. Was thinking that I might be ready to put it back in soon, but then I remembered that I need to look at the hell hole closely while I have easier access. That could delay things...
euro911
post May 24 2017, 11:43 PM
Post #112
QUOTE(arne @ May 24 2017, 06:30 PM) *
The wire has a push-on connector. You should be able to pull it off by hand, or reach in the hole with a pair of needle-nose pliers or hemostats to grab the connector.
post May 25 2017, 04:02 AM
Post #113
914-6 GT in waiting
The thermostat wire is a derailleur wire available at any bike shop.
arne
post May 25 2017, 08:29 AM
Post #114
QUOTE(mepstein @ May 25 2017, 03:02 AM) *
I wondered if that might not be so. I probably have some in the garage somewhere. Will get that connected while I have it out and easy to work on.
arne
post May 26 2017, 05:54 PM
Post #115
Engine down!
Thanks to the following, it was a relatively painless process, even solo.
  • McMark - for the great how-to drop article in the tech section.
  • Racer Chris (Tangerine Racing) - for designing the awesome Engine Lift Plate.
  • JB620 - for the gracious loan of the above mentioned TR Lift Plate.
That Lift Plate is a super tool, makes it a simple one man job with just a cheap floor jack. Well worth having if you have thoughts of dropping more than once in a blue moon.
No surprises yet, but the exploration is just beginning.
post May 26 2017, 06:05 PM
Post #116
914-6 GT in waiting
Get 12mm copper plated exhaust nuts. They are easier to install than 13's.
You might also want to replace the ss soft brake lines with new rubber ones. SS don't last forever - the rubber inside can still collapse. It might help your brake issue.
arne
post May 26 2017, 10:54 PM
Post #117
Roger that on the copper plated nuts, I've used those on previous projects.
Will consider the rear hoses while I'm under there. The SS hoses appear to be quite fresh, they lack all the road grime that covers the rest of the suspension and brakes, so I'm leaning towards leaving them be.
Separated the engine and trans, no unpleasant surprises so far. Clutch looks fresh, input shaft and rear main seals are both appear to be dry now, will know more once I get it farther apart. Will likely replace those now anyway, just due to age.
arne
post May 27 2017, 06:30 PM
Post #118
More progress today. The clutch is fine, does not need replaced. Input shaft seal is not leaking now, but looks a bit sketchy and will be replaced. Rear main seal was starting to leak, so this was well worth the time. Replaced pushrod tube seals on the right side today, will next tackle the oil cooler seals before moving to the left side.
Building a list of parts for little things I want to address prior to reinstalling the motor.
cary
post May 28 2017, 11:32 AM
Post #119
Looks like a great car and gifted owner. I too (Jamie) would like to find some time and come down and see it.
Keep the pedal down .................
iankarr
post May 28 2017, 12:58 PM
Post #120
QUOTE(arne @ May 26 2017, 07:54 PM) *
Engine down!
(IMG:style_emoticons/default/agree.gif) tangerine plate is essential
congrats on all the great progress!
- Lo-Fi Version Time is now: 9th April 2025 - 11:35 PM
