111 Pages V « < 47 48 49 50 51 > »
> Intro from Montana: '73 2.0L rustoration thread
BPic
post Mar 30 2019, 04:11 PM
Post #961
Looks awesome Brent. Your detail is remarkable. Like Tygaboy said about documentation, I have been following this build religiously and get a lot of info from it. Your ahead of me in your build and is fantastic because I have you doing exactly what I’ll be doing soon. Thank you for the great documentation. (IMG:style_emoticons/default/beerchug.gif)
bbrock
post Mar 30 2019, 05:16 PM
Post #962
QUOTE(BPic @ Mar 30 2019, 04:11 PM) *
Well, if anything, it is a good tutorial on what NOT to do (IMG:style_emoticons/default/lol-2.gif) Maybe that's why you do the same things only better. I have thought a lot about how much great information is buried in these build threads but can be hard to find unless you happen to be following along a step or two behind. I've done the same thing with other great builds. Lesson for do day is DON'T trust a cheapass Chinese pipe fitting!! Maybe more on that later after my blood pressure comes back down. (IMG:style_emoticons/default/beerchug.gif)
bbrock
post Apr 2 2019, 12:02 PM
Post #963
I'll try to catch up on a couple tasks done over the weekend, but the big news is that my car is now insured for the first time in over 30 years. I've been meaning to do this ever since spraying color on the interior last fall, but kept putting it off. Got a comprehensive only policy from Hagerty for quite reasonable I think. I'm covered if I trip and knock over a can of paint thinner into a pile of dirty rags and make a spark when the steel plate in my head hits the concrete floor.
altitude411
post Apr 2 2019, 01:52 PM
Post #964
I drove my 6 into a tree
QUOTE(bbrock @ Apr 2 2019, 12:02 PM) *
(IMG:style_emoticons/default/huh.gif) It's all now starting to make perfect sense...
post Apr 2 2019, 02:01 PM
Post #965
914-6 GT in waiting
Good move. Things happen in people's garages all the time. It's just stuff but for what it cost to insure, it's worth it.
bbrock
post Apr 4 2019, 12:33 PM
Post #966
I've been busy but nothing too exciting to report. I'll get us caught up anyway.
Last Saturday was wheel day. I wound up have to graduate to Simple Green and #0000 steel wool for the initial scrub to get all most of the caked on crap off. There is still staining that needs to be dealt with and a depressing amount of damage including pretty severe curb rash, anodizing failing, deep scratches, a couple really bad gouges, and a sizable chunk knocked out from one of the openings. About half of the lug holes show scratches from what looks like coarse steel wool or SOS pads probably used to try to remove stains from rusting bolts. In addition, they've gone through some restoration before that I hadn't noticed. Looks a number of scratches were ground and polished out and the wheels were re-anodized, but a close look shows two different finishes in the recesses. I've tried to figure out what they did but the best I can guess is they didn't completely strip the old anodizing before refinishing. Don't know if that is possible, but that's how it looks. Let's just say it wasn't top notch work but I'll give them credit that it took me 35 years to actually notice. Anyway, I'll finish this first post with a few shots of the carnage.
bbrock
post Apr 4 2019, 01:13 PM
Post #967
Now for a little restoration, but if you are expecting an inspirational post of how I miraculously brought these back to former glory, you won't find it here. This is way beyond my rudimentary skill. If I had access to a good anodizing service nearby, I would have considered stripping the anodizing and attacking some of these issues a bit more aggressively. I think with the coating gone, I could do a decent job of removing 75% of the damage, but would need to get them recoated. And after months of searching, I just within the last hour, found an anodizer not 30 miles away. It's too late though and for the best. Eventually, I'll send these off to one of the top guys for proper restoration. For now, I decided to put just enough lipstick on the pig to make her dateable.
Okay, the curb rash was what you noticed at a distance, so just getting rid of that made a huge difference and was pretty easy. Some was pretty bad so I started with 80g sandpaper on a random orbit palm sander and took the scratches out. It flattened out the outer rim profile a little but unless you know what the original was, you'd never know. Other than a nick in the rim that needs to be welded and reground, and a couple deep scratches that would require sanding deeper than they were worth, the rash was eliminated. I worked through the grades up to 320grit with the palm sander. Then I switched to wet sanding and worked up to 2000g. By the time I got there, the sheen on the rim was a dead match for the original so I stopped. I failed to take a good pic of the result, but you can see it in some later shots.
For the other damage, I decided to only address the two worst gouges and save the rest for later.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1554402454_thumb.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1554402496_thumb.jpg)
I just buffed those out with a coarse conditioning disc on a 2" grinder.
Then I masked all the shiny stuff and spot blasted the buffed areas with glass bead to try to match the surrounding finish as best I could. And yes, that's what a nice spring day at our house looks like.
Man am I impressed with the hardness of that anodizing! Glass just bounces off it without leaving a mark. That's good from a protection standpoint, but also prevented me from feathering out the blasting to try to blend my repair into the surrounding finish. It's not great, but an improvement I think. This wheel will be the spare. These pics also show the result of the curb rash repair. Also note that I just eased the edges of that missing chunk by the opening with the conditioning disc. It needs more polishing, but it's a little less noticeable. On the blasted areas, I might experiment with some clear wheel paint to see if that helps blend the edges a little. They'll never be showroom quality until proper resto though.
The final thing for Saturday was to give all the rims an additional cleaning. First I had a little repair to make. This is what happens when the plumbers don't slope a frost-free hose bib correctly and you run out of propane in minus 26 weather.
After only 30 minutes, I had the replacement installed with proper slope. I knew something was amiss though because the entire task was accomplished without a single curse word. That's when I noticed the cheap-ass Chinese POS PEX adapter that came with the bib had already split. THAT's when the cussing started and boy was it a hum-dinger of a fit! Glad I noticed the split then though. That could have been really bad, but there is no way that shitty fitting is designed to handle household water pressure.
Anyway, with outside water restored, it was on to wheel cleaning. I tried Chemical Guys wheel cleaner but it wasn't up to the task. I think it would be good for maintaining regularly cleaned wheels, but not up to the task here. I'm going to try some Jay Leno's Garage cleaner as reviews say it it good at pulling out iron stains. No pics, just reporting the result of that. I had accomplished my main objective of prepping the wheels for tires. Any additional cleaning and repair can be done with tires on now that the curb rash is gone.
bbrock
post Apr 4 2019, 01:17 PM
Post #968
Sunday I knocked off a little task I had been dreading. Remember that rear quarter brace I had to cut to install the trailing arm? I fixed that. I really limited my grinding in there to avoid really F'ing something up. That meant I got some contamination in the weld which I don't care about, and I didn't grind the weld completely off which I also don't care about.
bbrock
post Apr 4 2019, 01:25 PM
Post #969
Last one. Yesterday I got a few goodies via Mr. Shea.
I finally got to use this wheel bearing driver set I bought on sale for a different project but never used. Ironically, the large HF "Front Wheel Bearing Set" I have works great for the rear bearings but doesn't have the right sizes for the front.
Anyway, Less than an hour to drive out the old front bearing races and drive in the new, pack with the fancy red grease, and install.
Let's get the cap on to see how it looks.
And how about those nice, new rear rotors? (IMG:style_emoticons/default/piratenanner.gif)
Tomorrow is a big day for the car... (IMG:style_emoticons/default/popcorn[1].gif)
bbrock
post Apr 5 2019, 08:08 PM
Post #970
Safe Sex
So this happened today.
These are 195/65R15 Firehawk AS. To be honest, I would have prefered a 185 tire but I couldn't find any all season tires available. Summer tires where I live wouldn't make much sense. Similar poor selection in 165 and I always thought those were just a tad too skinny anyway. I like the way they look on the car. Hopefully they won't rub.
I already have a significant regret though.
I bought 5 tires and now which I hadn't. It's a little hard to see in the above pic, but these tires are way too fat for the spare tire area. I grabbed the trunk board to test.
The tire pushes the board up about six inches. That's about 2.25 cubic feet of lost cargo space and a front trunk compartment that looks like ass. I've never tried to return a tire. I wonder what the policy is. I'd rather have a skinny dedicated spare than this.
I received these yesterday. They should stop these tires when the need arises.
Finally, I found a very simple way to make my wheels look like new. Keep 'em spinning. (IMG:style_emoticons/default/aktion035.gif)
jim911E
post Apr 5 2019, 08:48 PM
Post #971
great work man i have enjoyed reading your blog...won't be long now and you will be back on the road again... enjoy.....jimAttached Image
914_7T3
post Apr 5 2019, 11:20 PM
Post #972
QUOTE(bbrock @ Apr 5 2019, 07:08 PM) *
Safe Sex
I made the same mistake once I mounted the 195 for the spare. Ended up dismounting the tire to keep in the garage as a replacement and bought a 165 Michelin XZX with vintage tread pattern from Lucas Tire to live in the frunk. Gives me an "Originalist" warm and fuzzy feeling! (IMG:style_emoticons/default/smile.gif)
raynekat
post Apr 6 2019, 12:33 AM
Post #973
I've got a 185/70VR15 tire for a spare on my car, and it fits like a champ. Sorry to hear you've lost so much luggage space. Less room for kegs or moose I guess....
bbrock
post Apr 6 2019, 08:06 AM
Post #974
Good to know that a 185 will fit. I looked at that Michelin and like it. Funny thing is it is almost 2X what I paid for my main tires. Walmart has a couple 165/80R15 tires for 50 bucks. Not the cool vintage look but I like the price for a spare.
I'm hoping Firestone will work with me on this. Their policy is you can return full sets of 4 or more tires within 90 of purchase for a full refund, but they specifically state that returns of less than the full set are not accepted. I'm hoping they'll see how stupid it would be for me to return 5 tires and then turn around and buy a set of 4.
SteveL
post Apr 6 2019, 08:29 AM
Post #975
Brent - what tires did you go with? Are those Firestones?
Asking because I have to get a new set this spring, looking for recommendations.
David Billo
post Apr 6 2019, 08:41 AM
Post #976
I'm honestly a bit mystified why a 185 would "fit like a champ", but a 195, which is only one centimeter wider, would look that bad.
bbrock
post Apr 6 2019, 08:47 AM
Post #977
QUOTE(jim911E @ Apr 5 2019, 08:48 PM) *
That is one sweet ride! (IMG:style_emoticons/default/beerchug.gif)
bbrock
post Apr 6 2019, 09:11 AM
Post #978
QUOTE(SteveL @ Apr 6 2019, 08:29 AM) *
I went with Firestone Firehawk AS tires. I needed an all season tire which pretty much dictated the size. These are considered "performance all season" tires. Tire Rack has some good videos comparing them with a few other performance all season tires. Based on those, these seemed to fit my particular needs a little better than the others but YMMV. Also, I found one online review and also a recent review here of them on 914s and both were very positive. It will be some time before I can test them out of course.
QUOTE(David Billo @ Apr 6 2019, 08:41 AM) *
I was curious about that too but after looking, seems possible. First, I said it sits about 6 inches high before but I meant 6 cm. I just measured and it is actually 5cm. I suspect most of the difference is in the sidewall bulge. It looks to me that the bulge is contributing about 2 cm to the board height. It's a little harder to tell how changing the shape might allow the tire to settle farther down in the front profile of the trunk. This tire rides high on the front lip and doesn't touch the rubber bumpers on the trunk floor. I wonder if a 185 settles a little lower in the compartment.
bbrock
post Apr 8 2019, 07:15 PM
Post #979
(IMG:http://www.914world.com/bbs2/uploads_offsite/spainvskorearecipes.files.wordpress.com-20845-1554772535.1.png)
Well, the car is ready to become a roller but I would like to get brakes and rear axles on before I do that. I'm stuck until I figure out how to get hardware plated, so I turned m attention to the engine.
First, a quick recap on the engine. I tore it down in 1989 and rebuilt the short block. I bought new OEM Mahle 8:1 euro spec P&Cs, a new Sachs clutch package, and had the cam ground for the Weber 40IDF carbs I bought at the time (the good Italian jobbies). The crank journals were turned 1 under and the flywheel was resurfaced. The reciprocating and rotating masses were balanced. I reassembled the case and sealed it up before the project stalled when I started grad school. At the time, the EFI was a deteriorating pile of shit that made the car unreliable. Carb conversion was the solution of choice back then as it was pre-Internet so DIY info for D-Jet wasn't readily available. So if anyone is wondering why I'm putting carbs on the car, that's why. I don't want to tear the case apart and it would take probably another year to go through my EFI parts and refurbish.
I'm really looking forward to trying these carbs but once this tub is back on the road, I'll start restoring the EFI, then I'll decide if I want to split the case and swap the cam.
My first task was to re-check the axial play. I set it with a feeler gauge when I first built the engine but wanted to check my work. I wound up yanking the flywheel seal and O-ring and replacing with new in the process. Axial play was right at 0.004. Perfect.
The shop that resurfaced my flywheel ignored my instructions to remove the same thickness from the center to maintain clearance for the flywheel bolts. Even so, the friction plate cleared the bolts but to be safe, I ground off most of the ridges from the bolts.
Flywheel was installed with new lock washer and then the clutch. Important to make sure the pressure plate is aligned with the balancing marks.
Maybe it's because a clutch replacement was the first major repair I did on a Porsche or any car, but I think clutches, particularly Sachs clutches, look really cool.
I got talked into buying a Mehling oil pump when I first rebuilt the engine but decided to switch back to the OEM pump. I know there is a lot of controversy over oil pump choices. This is my decision and I'm sticking to it. I'm glad I made the swap because it let me solve my mystery of what my cam grind. Elgin 8408
I also measured the deck height. Three of the cylinders were within .0025 of each other but the register on #3 had sunk about 0.01". The correct thing to do would be tear everything apart an have the case decked but that isn't going to happen. I'll probably be shunned by the master rebuilders, but I'm just going to add an extra 0.01" shim to #3 which will bring the cylinder top up for a 0.013" which is spot on with the other slugs. I also cc'd the heads and got exactly 60cc which is right on for a stock 2L head.
I also cc'd the very subtle dish in the euro piston tops but they only hold six drops so insignificant. I ordered a set of 0.03" shims to bring total deck height to 0.043 which will yield about 8.3:1 compression ratio. That doesn't seem too bad. I'm going to just lap the slugs into the heads and skip the gaskets.
The rest of the weekend was spent prepping engine parts for paint. Nothing picture worthy.
Dave_Darling
post Apr 8 2019, 09:14 PM
Post #980
914 Idiot
QUOTE(bbrock @ Apr 8 2019, 06:15 PM) *
Did it sink evenly, or at an angle? You probably want to correct any angle present so that the cylinder really is perpendicular to the crank.
--DD
- Lo-Fi Version Time is now: 22nd April 2025 - 01:48 PM
