rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,925 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Haven't looked at my car but are you sure that it is not installed up side down? (IMG:style_emoticons/default/idea.gif)
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,735 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Haven't looked at my car but are you sure that it is not installed up side down? (IMG:style_emoticons/default/idea.gif) Yes, please check your car. Does it have an OEM seal ? please post a pic My third picture picture shows the lip seal angled up toward the hood. (IMG:style_emoticons/default/smile.gif) |
rick 918-S |
I have 4 cars here and wouldn't you know it. None of them have the seal installed. The 5th one is outside on a trailer with a tarp over it under 3' of snow.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,117 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Late speedometer, tach and combo gauge coming. Pictures later
Attached thumbnail(s) ![]() ![]() |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,753 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Haven't looked at my car but are you sure that it is not installed up side down? (IMG:style_emoticons/default/idea.gif) Yes, please check your car. Does it have an OEM seal ? please post a pic My third picture picture shows the lip seal angled up toward the hood. (IMG:style_emoticons/default/smile.gif) your front trunk seal is installed correctly. pic is of mine. original factory seal not a replacement. R is on the left hand side (driver side). the convention for the trunk seal must be as you face the trunk from the front? Attached image(s) ![]() |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,842 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Haven't looked at my car but are you sure that it is not installed up side down? (IMG:style_emoticons/default/idea.gif) Yes, please check your car. Does it have an OEM seal ? please post a pic My third picture picture shows the lip seal angled up toward the hood. (IMG:style_emoticons/default/smile.gif) your front trunk seal is installed correctly. pic is of mine. original factory seal not a replacement. R is on the left hand side (driver side). the convention for the trunk seal must be as you face the trunk from the front? That sound strange. Direction is always sitting in the car. Could it be that someone used a factory seal but installed it wrong, while replacing the first factory seal. |
wonkipop |
Haven't looked at my car but are you sure that it is not installed up side down? (IMG:style_emoticons/default/idea.gif) Yes, please check your car. Does it have an OEM seal ? please post a pic My third picture picture shows the lip seal angled up toward the hood. (IMG:style_emoticons/default/smile.gif) your front trunk seal is installed correctly. pic is of mine. original factory seal not a replacement. R is on the left hand side (driver side). the convention for the trunk seal must be as you face the trunk from the front? That sound strange. Direction is always sitting in the car. Could it be that someone used a factory seal but installed it wrong, while replacing the first factory seal. the convention i agree most certainly applies when talking about separate parts that are on opposite sides of car. ie where there is a L and R version of the part. i wouldn't go so far as to say that logic applies to the trunk seal. its a one piece part, not a left and right version part. the trunk seal i can assure you has never been out of my car since 89. i can't vouch for it 1974 to 1989 and first owner. but the car is highly original. there is a factory build sticker and stamp up near the latch on the lid to go with seal. and the car has never been repainted. there are other members who have not meddled with their cars. they could take a look at their seals. @StarBear has a very original 74. see what his seal is like. EDIT i don't want to meddle with the seal on mine too much. but rolling a piece that is loose at the front, i can't really see how it can go on the other way. its an asymmetric profile and it would tend to want to poke out along the edges of the trunk lid. it seems to be designed to fill the body channel and to come out to edge of panel gap on trunk lid. |
wonkipop |
@mepstein
i got curious to take a look at factory manual. i could not find anything in there easily. but PET shows this. ![]() assuming that is an up and down orientation shown in PET. and it appears to be. seal in my car agrees. ![]() the only outcome is L is on the right of the car and R is on the left of the car (in the direction of driving). to get it the other way around this asymmetrical seal will not agree with PET and if its an OEM one i believe its edge will be sticking out from underside of front lid when closed. so think the L and R mean as you look down on the seal installing it with the front trunk open. would not be the first time we have found inductive logic does not work when it comes to 914s. for instance a 1974 EC-A engine is california. But in 1975 an EC-b engine is california. |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
NOS Wiring Snorkel
rgalla9146 |
@mepstein i got curious to take a look at factory manual. i could not find anything in there easily. but PET shows this. ![]() assuming that is an up and down orientation shown in PET. and it appears to be. seal in my car agrees. ![]() the only outcome is L is on the right of the car and R is on the left of the car (in the direction of driving). to get it the other way around this asymmetrical seal will not agree with PET and if its an OEM one i believe its edge will be sticking out from underside of front lid when closed. so think the L and R mean as you look down on the seal installing it with the front trunk open. would not be the first time we have found inductive logic does not work when it comes to 914s. for instance a 1974 EC-A engine is california. But in 1975 an EC-b engine is california. I've got three OEM seals all are the same. The R can only go on the drivers side and the L on the passenger side. The designers probably had their first beer at 9am just like the assembly line workers. (IMG:style_emoticons/default/biggrin.gif) |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,114 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
@wonkipop
I replaced my front trunk seals a few years ago with 914Rubber ones. I might (?) still have my old ones hanging around (I'm retentive like that); will check. |
wonkipop |
@mepstein i got curious to take a look at factory manual. i could not find anything in there easily. but PET shows this. ![]() assuming that is an up and down orientation shown in PET. and it appears to be. seal in my car agrees. ![]() the only outcome is L is on the right of the car and R is on the left of the car (in the direction of driving). to get it the other way around this asymmetrical seal will not agree with PET and if its an OEM one i believe its edge will be sticking out from underside of front lid when closed. so think the L and R mean as you look down on the seal installing it with the front trunk open. would not be the first time we have found inductive logic does not work when it comes to 914s. for instance a 1974 EC-A engine is california. But in 1975 an EC-b engine is california. I've got three OEM seals all are the same. The R can only go on the drivers side and the L on the passenger side. The designers probably had their first beer at 9am just like the assembly line workers. (IMG:style_emoticons/default/biggrin.gif) yep. you are absolutely right.........about being left - and right. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) the designers would have been drinking all night long burning the midnight oil with f. piech applying the blow torch. (IMG:style_emoticons/default/beerchug.gif) the factory workers only went to bed drunk. (IMG:style_emoticons/default/beer.gif) |
914Sixer |
NOS Volt gauge
Attached image(s) ![]() ![]() |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
@mepstein i got curious to take a look at factory manual. i could not find anything in there easily. but PET shows this. ![]() assuming that is an up and down orientation shown in PET. and it appears to be. seal in my car agrees. ![]() the only outcome is L is on the right of the car and R is on the left of the car (in the direction of driving). to get it the other way around this asymmetrical seal will not agree with PET and if its an OEM one i believe its edge will be sticking out from underside of front lid when closed. so think the L and R mean as you look down on the seal installing it with the front trunk open. would not be the first time we have found inductive logic does not work when it comes to 914s. for instance a 1974 EC-A engine is california. But in 1975 an EC-b engine is california. I've got three OEM seals all are the same. The R can only go on the drivers side and the L on the passenger side. The designers probably had their first beer at 9am just like the assembly line workers. (IMG:style_emoticons/default/biggrin.gif) Maybe they installed the seal with the car upside down. Or L and R make sense for the installer when facing into the frunk. |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,407 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
A few more to add to the stash.
I have a few more things in the works. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) ![]() Attached image(s) ![]() |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,044 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
where in the world do you guys come up with this stuff? very cool (IMG:style_emoticons/default/beerchug.gif)
930cabman |
In my search of some NOS sheet metal parts for my 914-6 I came across these... I've never seen these around so I couldn't pass it up. I'll reach out to RD about these as some have wanted these reproduced in the past. did someone mention our pals at RD does make these? I cannot find them on their website? TIA |
NOS chassis harness for my early GT car. It’s a 914-4 harness that I will modify for 914-6 style ignition. Bought it on German eBay for $850 a couple years ago.
Attached thumbnail(s) ![]() |
StarBear |
![]() NOS (?) AFM for 1.8L. Does the label (“exchange”) indicate it’s been rebuilt or that it can be used in alternate FI systems? Hadn’t seen one with a “C” at the end; 3rd generation version? |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,523 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Rebuilt!
Still a killer find! I'd prefer old school Bosch rebuilt over anything else. That is if I was staying stock... Mepstein's harness is what I consider a "Holy Grail" type of part, just beautiful! (IMG:style_emoticons/default/first.gif) |
Lo-Fi Version | Time is now: 19th April 2025 - 07:48 AM |
