Ford Solenoid Hot Start installation instructions, Mark Henry's method |
brainf18 |
Feb 22 2020, 08:06 PM
Newbie Group: Members Posts: 19 Joined: 12-May 19 From: Louisville KY Member No.: 23,116 Region Association: None |
Mark, I've been fighting hot start (i.e. no start) issues for some time and came across your thread. Followed your instructions and voilĂ problem solved for under $50! The only thing I wish I'd had is a custom bracket for mounting...but gently bending the tab and securing under the lower starter bolt works really well. Thanks so much for posting how to fix this! Much appreciated my friend!
Attached thumbnail(s) |
Montreal914 |
Feb 22 2020, 09:47 PM
Senior Member Group: Members Posts: 1,742 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Nice car! (IMG:style_emoticons/default/drooley.gif)
6" steel wheels? |
sixnotfour |
Feb 23 2020, 07:45 AM
914 Wizard Group: Members Posts: 10,704 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Mark Henry |
Feb 23 2020, 09:40 AM
Ford used different mount brackets for different cars and trucks, that's why there's several styles of mounts. I prefer the bracket style shown at the start of this thread, but they can all be made to work.
brainf18 |
Feb 25 2020, 07:39 AM
I get this question alot. I went for a low cost "vintage" look. Wheels are 5.5x15 from Sierra Madre ($60 each). Studs and lugs for mounting ($112). Tires are Achilles ATR 2's. Made by bridgestone they are great tires at a very low cost ($200 for a set of 4) Steel Wheels Wheel Studs Lug nuts Tires |
pcdarks |
Jan 6 2021, 11:13 AM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
Not to beat a dead horse but I found this solenoid. It's 12 volt and comes with a slide terminal to match the wire coming from the ignition switch.
https://www.oreillyauto.com/detail/b/standa...enoid&pos=6 |
rhodyguy |
Jan 6 2021, 11:32 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
This thread should be in the Classic Forum.
Mark Henry |
Jan 6 2021, 03:00 PM
rhodyguy |
Jan 6 2021, 03:16 PM
Not removed from here, shared in the classic.
black73 |
Jan 6 2021, 03:40 PM
Senior Member Group: Members Posts: 517 Joined: 23-March 05 From: Nashville,TN Member No.: 3,801 Region Association: South East States |
The Classic Forum should be a sticky at the top of the Garage, since that's where most of the traffic is. I forget the Classic forum exists sometimes.
barefoot |
Jan 7 2021, 12:26 PM
Senior Member Group: Members Posts: 1,337 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Not to beat a dead horse but I found this solenoid. It's 12 volt and comes with a slide terminal to match the wire coming from the ignition switch. https://www.oreillyauto.com/detail/b/standa...enoid&pos=6 You don't need the Ford or this rarther heavy duty solenoid, I used a such smaller one sourced from Amazon, works just fine as you're only carrying small amperage. |
Shivers |
Jan 29 2021, 09:49 AM
Senior Member Group: Members Posts: 2,877 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I got introduced to the hot start problem in 1982. In 92, ish, I got the hot start band aid sold at aa. And it worked. But I was concerned it would fail. But this is that on steroids. Had lots of old fords, never had to replace the relay. I started modifying my car in the 80's, so this would be a permanent fix to a poor design on a car driven in a warm/hot climate. I'm to old to be push starting a car by myself. And it had a habit of not starting when I was alone...On a hill...Parallel parked between two cars, parked too close. Thanks.
914Sixer |
Jan 29 2021, 10:03 AM
914 Guru Group: Members Posts: 9,044 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Another option is Bosch WR1 starter Kit. $27-$36 depending on where you shop
Mark Henry |
Jan 29 2021, 10:07 AM
Not to beat a dead horse but I found this solenoid. It's 12 volt and comes with a slide terminal to match the wire coming from the ignition switch. https://www.oreillyauto.com/detail/b/standa...enoid&pos=6 You don't need the Ford or this rarther heavy duty solenoid, I used a such smaller one sourced from Amazon, works just fine as you're only carrying small amperage. Guess you didn't read the first post. (IMG:style_emoticons/default/rolleyes.gif) I have literally hundreds of these running around from bugs, buses, 914, etc. so you won't be changing my mind on the value of this very simple and cheap fix. I got introduced to the hot start problem in 1982. In 92, ish, I got the hot start band aid sold at aa. And it worked. But I was concerned it would fail. But this is that on steroids. Had lots of old fords, never had to replace the relay. I started modifying my car in the 80's, so this would be a permanent fix to a poor design on a car driven in a warm/hot climate. I'm to old to be push starting a car by myself. And it had a habit of not starting when I was alone...On a hill...Parallel parked between two cars, parked too close. Thanks. Common story, I've replaced dozens of the Bosch relay fix with my Ford Solenoid fix. |
Mark Henry |
Jan 29 2021, 10:16 AM
Cool tool that every 914 owner should (at minimum) have in their toolbox, a Channellock 909 terminal crimping tool. made in the USA, $30 CAD or about $20 USD.
Perfect crimp pliers for this project. Known by some as "The Tooth", it makes a perfect dimple for excellent strong connections. I've misplaced my trusty old Panduit crimp pliers, so I bought the 909 and so far I like the crimps better than my old pliers https://www.amazon.com/Channellock-909-Crim...uct_top?ie=UTF8 (IMG:style_emoticons/default/beer.gif) |
ClayPerrine |
Jan 29 2021, 10:52 AM
Life's been good to me so far..... Group: Admin Posts: 15,982 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I just use a IMI gear drive starter. No hot start problem since I put it on.
IMI High Torque Gear Drive Starter No, it is not cheap. But I have been running the same IMI starter, without replacement , on my red 914 for years now. I originally put it on the 2.0L 4 cylinder to cure the hot start issue. I moved it to the 2.4L 911ST engine when I did the six conversion, and that same starter still spins the 4.0L monster motor with no issues. I figure that starter will outlast the car. :cranky: |
Olympic 914 |
Jan 29 2021, 06:12 PM
Group: Members Posts: 1,712 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
(Deleted Irrelevant post... ) (IMG:style_emoticons/default/confused24.gif)
Mark Henry |
Mar 29 2021, 02:40 PM
Another option is Bosch WR1 starter Kit. $27-$36 depending on where you shop Right in my 1st post my opinion is this fix is CRAP. (IMG:style_emoticons/default/dry.gif) Also said it's not a debate if you don't like it then move along. It's not a "starter kit" it's a VW Ghia horn relay. Look at that jangle of wires you have to hack in! You have to install it in the engine bay ..are you going to use a self tapping screw. I just ripped one out today and I'll be doing my fix thank you. (IMG:style_emoticons/default/smile.gif) I just use a IMI gear drive starter. No hot start problem since I put it on. IMI High Torque Gear Drive Starter No, it is not cheap. But I have been running the same IMI starter, without replacement , on my red 914 for years now. I originally put it on the 2.0L 4 cylinder to cure the hot start issue. I moved it to the 2.4L 911ST engine when I did the six conversion, and that same starter still spins the 4.0L monster motor with no issues. I figure that starter will outlast the car. :cranky: I also have an Hi-Torque in my /6 (IMG:style_emoticons/default/shades.gif) Starts my /6 good!! I still have the Ford bit only because I didn't take it off when I put in the Hi-torque starter. I should try without, I bet the Hi-torque only needs 3-4 amps to kick in, much like what the Ford solenoid needs. The problem is with the Bosch solenoid that needs a full 9 amps to kick in. |
LefthandRev |
Sep 5 2021, 04:13 PM
Member Group: Members Posts: 82 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
Did this today. Used a $17 solenoid from O'Reilly. Here's the link to the part.
The 90 degree mounting plate makes it easy to attach to the starter mounting bolt. Ream out the 3 o'clock hole on the mounting plate. No need to bend anything. Wire yellow to the "S" lug on the new solenoid/relay. Female blade wire on the 9 o'clock lug, if "S" is noon. 14" wire. Eyelet terminal mounts to the 3 o'clock lug. 12" wire. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1630880008.1.png) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1630880009.2.png) |
Mark Henry |
Sep 6 2021, 06:29 AM
Just had my first no start in ages, had to get a push. (IMG:style_emoticons/default/huh.gif)
Tested my ford solenoid, no problem there, starter kicked right in. Cleaned a few grounds...nope. I was about to dive into my ignition switch, then decided to check my seat belt interlock under the passenger seat. I had disabled it years ago by just pulling one of the relays, which 20 years ago was SOP. I did a quick thread search (thanks Clay), pulled and connected the two big yellow wires and I was back in business. Moral is you still have to check all your connections...but get the easy stuff out of the way first. |
Lo-Fi Version | Time is now: 15th January 2025 - 07:05 AM |
