brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I know the first thing people are going to tell me is to buy the aluminum AN wrench.
I will, but I don't think it will fit due to the width of those wrenches. So the question is.... what size of wrench fits a AN-16 fitting? I need to go buy one to facilitate easier oil changes on my project. I measure it out at 1.5 inches or 38mm... but wanted to confirm this with someone before calling a tools shop and spending the money.. anyone know? brant |
xsboost90 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 ![]() |
make one!
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
#3 AN (1/2" hex)
#4 AN (9/16" hex) #6 AN (11/16" hex) #8 AN (7/8" hex) #10 AN (1" hex) #12 AN (1-1/4" hex) #16 AN (1-1/2" hex |
brant |
Cool..
thanks a ton mike! so my rough measurement was pretty close. and it looks like I should buy an american size instead of metric then (might be cheaper anyways?) brant |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Brant,
come by tonight, and look at the one I use for my car. Our AN fittings may be different but i think mine is 36mm. I use a headset tool for my bike, it's super thin and cheep, works ok... ferg. Attached image(s) ![]() |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
just get Summit's complete set - they're much less expensive than some of the ones, especially purchased individually. eventually, you'll need the AN-3 and AN-4 fpr brake and clutch lines, and AN-6 for fuel lines, and...
also - there's two sizes to every fitting... there's the B-nut, which is the standard fitting size, and there's the size of the hose end (the "hose clamp" part - i've forgotten the terminology...) that screws down onto the cutter. that part's bigger. when you're assembling hose ends, it's really nice to have soft wrenches for both parts. |
Lo-Fi Version | Time is now: 30th June 2024 - 07:38 AM |
