HELP! No spark, Replaced the Mallory module |
jeffdon |
May 15 2017, 02:46 PM
I figured I had fried my Mallory optical module with a battery charger, and so I just replaced it with brand new. Still no spark. With key on, I getting 12v at the neg side of the coil and on the primary. I had my fuel pump powered off the pos side of the coil, and was seeing a V drop down to just under 6 when that was on it. Moved the power source to the relay board. Now seeing 12v. Still no spark.
What the hell else should I check? Could I have fried the module on first power up? (IMG:style_emoticons/default/headbang.gif) |
May 15 2017, 03:18 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
What triggers your spark? Regular points? Pertronix? Other?
Try swapping in points and condenser (or a new set if you're using points) and see what happens. --DD |
jeffdon |
May 15 2017, 03:33 PM
What triggers your spark? Regular points? Pertronix? Other? Try swapping in points and condenser (or a new set if you're using points) and see what happens. --DD The mallory dizzy is the optical pickup kind. NEver had points. I was going to swap in my old pertronix equiped 009, but it appears one of the dizzy cap clips has gone missing. |
poorsche914 |
May 15 2017, 04:38 PM
T4 Supercharged Group: Members Posts: 3,121 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Have you tried the Unilite Test Procedure ?
I have fried a unit on first power up. Irritating to say the least! (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/driving.gif) |
jeffdon |
May 15 2017, 04:57 PM
Have you tried the Unilite Test Procedure ? I have fried a unit on first power up. Irritating to say the least! (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/driving.gif) Yeah, and it appears to be non-operative. Is Mallory also maybe shipping bad modules? For what its worth, my old 009 with pertronix aint working either. |
poorsche914 |
May 15 2017, 05:41 PM
Yeah, and it appears to be non-operative. Is Mallory also maybe shipping bad modules? For what its worth, my old 009 with pertronix aint working either. Last time I thought a module went bad it ended up being my coil (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/driving.gif) |
jeffdon |
May 15 2017, 08:53 PM
Got her running with the 009 and points. Looks like I may have mistaken the power wire to the dizzy with the tach wire. Old red and old purple look the same.
Are points availible for the mallory dizzy? I am kinda fed up with the optical pick ups. |
May 15 2017, 09:14 PM
Looks like I may have mistaken the power wire to the dizzy with the tach wire. Old red and old purple look the same. Ugh! Yeah, been there done that. I always remember that the wire that carries the power is thicker, and the one that carries the signal is thinner. --DD |
jeffdon |
May 15 2017, 09:23 PM
Looks like I may have mistaken the power wire to the dizzy with the tach wire. Old red and old purple look the same. Ugh! Yeah, been there done that. I always remember that the wire that carries the power is thicker, and the one that carries the signal is thinner. --DD Yeah, I should have realized that. Better marking of things is called for. Wonder if my mallory is NOT fried? |
MarkV |
May 15 2017, 10:23 PM
They make a Pertronix II for a Mallory distributor. They aren't as delicate and work with a hall effect magnet instead of an LED. The II version doesn't fry if you hook it up backwards or if you leave the key on without the engine running. Not positive but I think the Mallory YL 4 cyl distributor all takes this model: http://www.ebay.com/itm/Pertronix-9ML-141C...CjL&vxp=mtr |
jeffdon |
May 16 2017, 07:48 AM
They make a Pertronix II for a Mallory distributor. They aren't as delicate and work with a hall effect magnet instead of an LED. The II version doesn't fry if you hook it up backwards or if you leave the key on without the engine running. Not positive but I think the Mallory YL 4 cyl distributor all takes this model: http://www.ebay.com/itm/Pertronix-9ML-141C...CjL&vxp=mtr Thanks. This is quite interesting. I wonder if the variable dwell would give better performance than the mallory optical module. |
MarkV |
May 16 2017, 09:03 AM
I started with a dual point because you can't buy a unilite unless you can find one used. Used VW single point and dual points are cheap and easy to find. I also went with the Mallory low empedence coil and found a curve kit with the gray springs. I definitely performs better that the Bosch distributor that it replaced. It starts easier when cold and hold an idle faster. It also seems to work better at high rpm.
I think you might have to buy a rotor for a regular distributor to make it work unless that hat piece on the unilite is removable. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:30 PM |
