> Plastic Inner Long Plugs, Does anybody report these?
amfab
post Jun 12 2017, 07:28 PM
Does anyone make reproductions of the oval plastic plugs for the inner longs?
TIA
-Andrew
Jett
post Jun 12 2017, 09:01 PM
I need some as well...
914Rubber? Mark can you build these?
IronHillRestorations
post Jun 13 2017, 05:50 AM
I. I. R. C.
They are a tar mat, not plastic
amfab
post Jun 13 2017, 12:15 PM
QUOTE(Perry Kiehl @ Jun 13 2017, 04:50 AM) *
AHA! so I can just get a little spice of dynamite or sumfin and trim it?
post Jun 13 2017, 12:23 PM
I. I. R. C.
QUOTE(amfab @ Jun 13 2017, 10:15 AM) *
Yep, and Bob's your uncle!
mbseto
post Jun 13 2017, 12:41 PM
Cut one out of a shingle? Not really a recommendation, but when I pulled mine off I remember thinking, man, that's just like a piece of shingle.
Mikey914
post Jun 13 2017, 01:50 PM
The rubber man
Shoot me a pic. We can mass produce these pretty inexpensively.
gcrotvik
post Jun 13 2017, 02:01 PM
QUOTE(Mikey914 @ Jun 13 2017, 12:50 PM) *
Mark,
I have one. I will drop it by your shop. I could use a few sets myself.
If I could make a suggestion/recommendation on these. I believe they are 3MM thick but the actual inset in the long is about 5MM deep. If you could find the correct thickness of material that would be great. That way the surface of the plug is level with the outer surface of the long.
Greg
amfab
post Jun 13 2017, 02:11 PM
QUOTE(gcrotvik @ Jun 13 2017, 01:01 PM) *
Mark,
Greg
Great!
This place is awesome BTW
Mikey914
post Jun 13 2017, 02:16 PM
The rubber man
Thanks that would be great, I know the part now. Had to think about it. Pretty sure we can do something that will be equivalent to OEM.
Mark
914werke
post Jun 13 2017, 09:12 PM
I made some of these, not sure but I may have a set or two left over.
They are a OE Porsche material even (IMG:style_emoticons/default/smile.gif)
I took the sound deadening pad from behind the back pad made an oval punch the correct size and cut them from the flat section of the pad.
Could have been the same material originally. (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 15th January 2025 - 03:36 AM
