Saying hello |
Saying hello |
Jun 19 2017, 05:16 PM
914 Idiot Group: Members Posts: 15,075 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Has an oil leak that is dripping onto the exhaust (it smells great after I drive it) and leaves drips on the garage floor, I'll have to climb under and take a look. Good chance it's the valve cover gasket, or the pushrod tube seals. Both can be done with the engine in the car. QUOTE Pretty sure this is not factory, looks a home depot fix, lol. Do you guys know if this is still made and where to get it? If you're talking the corrugated-hose-looking part, that does not look factory. It's a little tough to tell from the photo, but it looks like the Home Depot part now connects the air cleaner to the throttle body. Stock would be a formed rubber piece (that has fittings in it for at least one vacuum hose). It has been NLA for years--but the good news is that 914rubber is starting to make them!! Visit their website or ping Mikey on here to order one. --DD |
76-914 |
Jun 19 2017, 05:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Welcome to the madness. The 1.7 is bullet proof and runs cooler. The ultimate momentum machine. (IMG:style_emoticons/default/welcome.png)
mxkinn01 |
Jun 19 2017, 06:01 PM
Member Group: Members Posts: 250 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
BENBRO02 |
Jun 19 2017, 07:53 PM
Member Group: Members Posts: 484 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Love that color!
steuspeed |
Jun 19 2017, 08:13 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/smash.gif) My doorhandle broke the day I bought my car too. This is very common. They are made of pot metal. A used replacement is what you need. Check ebay. $60-$100 is a good price. Passenger R side is easier to find. It's marked on the back. Look for both arms to be intact. Also the original white plastic actuator part is better than the black replacements imo. The cause is gummed up mechanism/latch. Once it gets stiff then the handle eventually breaks. Clean and lube, so your next handle won't die the same death. I used PB blaster on mine.
banananose914 |
Jun 19 2017, 08:45 PM
Member Group: Members Posts: 235 Joined: 20-November 13 From: california Member No.: 16,681 Region Association: None |
Addiction? You almost make it sound like a bad thing. Just because I have 20 or more yet to be installed parts purchased over the past nine years and work on my car most everyday and buy parts before food I wouldn't call it an addiction. It's my hobby. And since the car is 44 years old and will never really be "perfect" since I drive it so much and it deteriorates each mile I drive it and I will never ever be finished "working on it" and need to keep learning everything about it so I can continually "improve it" and eventually learn how to fix every single thing on it leading up to a 100% ground up rotisserie restoration which will no doubt cost more money than I have and take way longer than I have time for.....is that really the definition of an addiction? Well maybe.....but no one is making me do it. I like it. Same as drinking beer. I could stop anytime but then what would I do? Both with the car and the beer. Anyway....enjoy your new car and welcome to our "club". gg Very well stated! I like it! |
mxkinn01 |
Jun 20 2017, 05:49 AM
After further inspection.
It turns out someone swapped the outer door handles, after all they are marked R and L, lol. I'm surprised the passenger handle on the driver door still works, I never did try the lock though. I will swap it to the correct side today and make sure it works properly. The hunt has now moved to the driver side door handle. |
EdwardBlume |
Jun 20 2017, 07:21 AM
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png)
You're discovering the joys of working on your car. Keep it up! |
Jun 20 2017, 05:01 PM
They work fine when swapped; the only real difference is the curve of the back part of the flapper. They are functionally identical.
--DD |
mxkinn01 |
Jun 22 2017, 01:41 PM
mxkinn01 |
Jun 22 2017, 01:45 PM
mxkinn01 |
Jun 22 2017, 01:48 PM
PanelBilly |
Jun 22 2017, 02:20 PM
914 Guru Group: Members Posts: 5,866 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Hello
mxkinn01 |
Jun 22 2017, 02:50 PM
After hunting around here and viewing pics of factory 1.7s, I see they just slide into each other. Just needed to loosen the bottom elbow clamp and adjust it until they slide into each other.
I will be getting a hold of 914 Rubber to order a new elbow, door handle and other misc stuff. Thanks for everyone's responses. |
bbrock |
Jun 22 2017, 03:38 PM
After hunting around here and viewing pics of factory 1.7s, I see they just slide into each other. Just needed to loosen the bottom elbow clamp and adjust it until they slide into each other. I will be getting a hold of 914 Rubber to order a new elbow, door handle and other misc stuff. Thanks for everyone's responses. You might be able to fix that booger on the air cleaner opening with the careful use of a heat gun and a wooden spatula or similar to work that crease back out to round. I've had good luck doing that with other plastic parts. But there is a fine line between getting the plastic soft enough to shape, and having a worthless pile of goo. So be careful if you attempt it! It's easiest if you can find a tapered cylinder of some sort the right size to slip in as the plastic softens. Clay flower pots work great for this. (IMG:style_emoticons/default/beerchug.gif) |
banananose914 |
Jun 22 2017, 08:19 PM
After hunting around here and viewing pics of factory 1.7s, I see they just slide into each other. Just needed to loosen the bottom elbow clamp and adjust it until they slide into each other. I will be getting a hold of 914 Rubber to order a new elbow, door handle and other misc stuff. Thanks for everyone's responses. You might be able to fix that booger on the air cleaner opening with the careful use of a heat gun and a wooden spatula or similar to work that crease back out to round. I've had good luck doing that with other plastic parts. But there is a fine line between getting the plastic soft enough to shape, and having a worthless pile of goo. So be careful if you attempt it! It's easiest if you can find a tapered cylinder of some sort the right size to slip in as the plastic softens. Clay flower pots work great for this. (IMG:style_emoticons/default/beerchug.gif) Wow! Who would have thought you could use a slinky on a 914. As a kid I used to just let them roll down the stairs. Who knew? |
Lo-Fi Version | Time is now: 15th January 2025 - 04:23 AM |
