does anyone have a roller in northern va?, i need to test fit an engine cradle. |
jimkelly |
Jun 21 2017, 06:48 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i need to text fit this suby engine/trans cradle so i can determine where to place the trans hanger sections and orient it properly.
Attached thumbnail(s) |
BeatNavy |
Jun 21 2017, 06:59 AM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Jim, I've got a '75 body up on a cart in my garage you're welcome to use as a guide. I'm missing one piece of engine shelving, as I haven't got around to that body section yet, but I would think it would work for your purposes.
If you're over at Rod's, I'm just down the road (if you remember). |
jimkelly |
Jun 21 2017, 08:05 AM
rob, of course, thanks.
all the crazy avatars and screen names mixes the hell out of me and the region of my brain responsible for membering stuff : ) does your car have engine and trans mounts installed? Attached image(s) |
BeatNavy |
Jun 21 2017, 09:18 AM
does your car have engine and trans mounts installed? Ach! I have 3/4 of what you need. I have both trans mounts installed, but one of the engine mounts has yet to be installed as I replaced that upper wheelhouse (but have not yet put the mount back on). I DO have the mount I'm going to use (lying around somewhere), so if you think we can clamp it in place for this purpose we can try that. |
jimkelly |
Jun 21 2017, 11:37 AM
hum, should be still doable.
sample pic from under engine bay. Attached image(s) |
jimkelly |
Jun 21 2017, 08:41 PM
working on a jig.
jimkelly |
Jun 22 2017, 11:26 AM
got wooden jig set up for get rear mount points in place.
once i get this tacked up, i will take over to rob's to see how it fits to car. i did have to hog out the front mount holes about a 1/4 inch outward on both, this is because my cross bar was a bit short and i had to weld a decent gap which must have pulled the whole cradle tight inward. Attached thumbnail(s) |
jimkelly |
Jun 22 2017, 05:17 PM
pic
BeatNavy |
Jun 22 2017, 06:42 PM
Looks good, Jim. My tub will be excited to be useful for something other than being a place for me to throw my crap (IMG:style_emoticons/default/smile.gif)
jimkelly |
Jun 22 2017, 06:55 PM
looks good though i wish it were DEAD NUTS/SPOT ON measurement wise (IMG:style_emoticons/default/smile.gif)
if i did not spend the past hour with rod drinking RONIN at crooked run brewery, i'd be at your house fitting my cradle (IMG:style_emoticons/default/beer.gif) Attached image(s) |
BeatNavy |
Jun 22 2017, 07:05 PM
looks good though i wish it were DEAD NUTS/SPOT ON measurement wise (IMG:style_emoticons/default/smile.gif) if i did not spend the past hour with rod drinking RONIN at crooked run brewery, i'd be at your house fitting my cradle (IMG:style_emoticons/default/beer.gif) I like crooked run (IMG:style_emoticons/default/beerchug.gif) Especially with live music and tacos. |
Lo-Fi Version | Time is now: 2nd January 2025 - 03:05 PM |
