914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
always a fascinating discussion - must be 300 ideas about this on the internet with more permutations than my old brain can handle to further upset the cart - see the recent Pelican brakes advert for Part # 911-352-907-00-PMB set of the "M" style calipers showing 914 style e-brake levers - would be a helluva deal if true http://www.pelicanparts.com/More_Info/911-...SVSVSI=357.htm# I think it's just a mistake. Some of the pics have an ebrake, some don't. |
HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
always a fascinating discussion - must be 300 ideas about this on the internet with more permutations than my old brain can handle to further upset the cart - see the recent Pelican brakes advert for Part # 911-352-907-00-PMB set of the "M" style calipers showing 914 style e-brake levers - would be a helluva deal if true http://www.pelicanparts.com/More_Info/911-...SVSVSI=357.htm# Well fuch me, I'll be callin in the mornin bout that 4 shore lol |
HalfMoon |
always a fascinating discussion - must be 300 ideas about this on the internet with more permutations than my old brain can handle to further upset the cart - see the recent Pelican brakes advert for Part # 911-352-907-00-PMB set of the "M" style calipers showing 914 style e-brake levers - would be a helluva deal if true http://www.pelicanparts.com/More_Info/911-...SVSVSI=357.htm# I think it's just a mistake. Some of the pics have an ebrake, some don't. All the pix I saw had the e-brake? Addendum-AH, I see when I click to see the full image set that yes, some do not have the e-brake. Also, some appear not to have the spacer. Definitely be calling for clarification! |
HalfMoon |
Well crap.
I just realized the PO had converted the rears using a 4-lug to 5-lug spacer :-( This means if I want a vented 911SC rotor I have to change out the hub and the spacer as well as adding a spacer to the stock caliper and having the 911 rotor cut down (not to mention longer pins and caliper nut/bolts :-( I wonder how effective ducting from my Sheridan Standard Widebody would work for efficient rear brake cooling. Certainly easier and more cost effective to do that at this point. I'm bummed. |
Well crap. I just realized the PO had converted the rears using a 4-lug to 5-lug spacer :-( This means if I want a vented 911SC rotor I have to change out the hub and the spacer as well as adding a spacer to the stock caliper and having the 911 rotor cut down (not to mention longer pins and caliper nut/bolts :-( I wonder how effective ducting from my Sheridan Standard Widebody would work for efficient rear brake cooling. Certainly easier and more cost effective to do that at this point. I'm bummed. Do 911 5 lug hubs even bolt up to a 4 lug stub axle? I thought you had to change the whole assembly - trans stub, axle, cv's, etc to use a 911 hub. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Well crap. I just realized the PO had converted the rears using a 4-lug to 5-lug spacer :-( This means if I want a vented 911SC rotor I have to change out the hub and the spacer as well as adding a spacer to the stock caliper and having the 911 rotor cut down (not to mention longer pins and caliper nut/bolts :-( I wonder how effective ducting from my Sheridan Standard Widebody would work for efficient rear brake cooling. Certainly easier and more cost effective to do that at this point. I'm bummed. Do 911 5 lug hubs even bolt up to a 4 lug stub axle? I thought you had to change the whole assembly - trans stub, axle, cv's, etc to use a 911 hub. I think he means adapter, you can get 4-bolt to 5-bolt adapters from VW bug shops. |
HalfMoon |
Well the good news is that I was wrong!
Indeed it's a 914 hub, but it was re-drilled to a five lug so that means I can use the 911SC rotor AND the 5-lug spacer I have. Back on track this project! Woot woot. http://www.pelicanparts.com/techarticles/9...onversion_7.jpg |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
Where is Erc??
(IMG:style_emoticons/default/idea.gif) |
Mark Henry |
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
Tricky part about Summit Point (main) is the T1 entry. With my 911SC, I would just brush 120mph and have to brake to 45-50 ish for T1. Do that 15-20 times a session. A SBC could be pulling closer to 140mph (depending on aero and driver) but still need to brake down the same.. so scrubbing close to 100mph.
The related issue is that you then have T5 -entry to the carousel. While you might enter at 100 ish, you have to brake down again, to 40ish... and by the third hot lap, THIS will be where you really want effective brakes with large heat soak ability, or LOTS of cool air... imho, messing around with home made this and that vs a proven and supported product that, while giving up the E-Brake, allows you and a passenger / instructor to be confident of high speed stopping seems to be putting a cart before the horse... At minimum I would encourage you to run SC rotors and calipers front and rear along with ducting to get air on them. While the prices might be crazy, at least look at the Lots of general good brake info here.. http://www.vehiclecraft.com/Brakes/930_upgrade.htm |
HalfMoon |
Tricky part about Summit Point (main) is the T1 entry. With my 911SC, I would just brush 120mph and have to brake to 45-50 ish for T1. Do that 15-20 times a session. A SBC could be pulling closer to 140mph (depending on aero and driver) but still need to brake down the same.. so scrubbing close to 100mph. The related issue is that you then have T5 -entry to the carousel. While you might enter at 100 ish, you have to brake down again, to 40ish... and by the third hot lap, THIS will be where you really want effective brakes with large heat soak ability, or LOTS of cool air... imho, messing around with home made this and that vs a proven and supported product that, while giving up the E-Brake, allows you and a passenger / instructor to be confident of high speed stopping seems to be putting a cart before the horse... At minimum I would encourage you to run SC rotors and calipers front and rear along with ducting to get air on them. While the prices might be crazy, at least look at the Lots of general good brake info here.. http://www.vehiclecraft.com/Brakes/930_upgrade.htm Thank you for the valuable and obviously experienced based advice for SP. I already have front SC rotors and calipers. Billy over at Performance Automotive in Kearnesville recommended going to the vented SC rear rotor but my instructor Mark said I could probably get away with the stock 914 rear caliper for now as I'm at novice level and will be for some time I would think. I can say with real authority that while my teener could enter 1 at the speeds you've described, my ability to do so would preclude attempting that for quite some time. In fact I couldn't imagine anything over 100 at this point. At some point, adding the SC rear calipers would be a must, but I think the vented rear rotors (and yes, maybe even some ducting, we'll see) should suffice for now. Again, thanks for that bit of advice :-) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:34 PM |
