Cairo's (Michael) 6 - Part 2, 3.2 coming out and '95 3.6 going in... |
Jul 16 2018, 08:58 PM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What are the bronze pipes?
If oil cooler runs, can you show the transition from the outer Long into the front trunk? Also, what are your thoughts on vibration and tubing cracking over time? |
billh1963 |
Jul 17 2018, 04:40 AM
Car Hoarder! Group: Members Posts: 3,404 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
I'm sure those are the brass oil cooler lines going to the front mounted oil cooler
Tdskip |
Jul 17 2018, 06:16 AM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Jul 17 2018, 06:22 AM
914-6 GT in waiting Group: Members Posts: 19,603 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm sure those are the brass oil cooler lines going to the front mounted oil cooler +1 These might Ben's lines, which if so are basically identical to the factory original ones which seem to last OK. Those lines came from PMB a while ago. 911's use similar brass lines up the long to feed the front cooler but 911 lines are longer with some 90 degree bends. The biggest issue with them is not cracking but guys or shops jacking up the car and crushing the line. |
sixnotfour |
Jul 17 2018, 06:50 AM
914 Wizard Group: Members Posts: 10,643 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
those brass lines are the 3rd to last set I made
mb911 |
Jul 17 2018, 10:38 AM
914 Guru Group: Members Posts: 7,258 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
those brass lines are the 3rd to last set I made (IMG:style_emoticons/default/agree.gif) Mine are stainless but some have plated them.. |
siverson |
Jul 18 2018, 12:05 AM
Advanced Member Group: Benefactors Posts: 2,451 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Just paint this thing already!!!
Cairo94507 |
Jul 18 2018, 07:09 AM
Michael Group: Members Posts: 10,095 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
XYZ
Valy |
Jul 18 2018, 07:27 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Man, that gold in the engine bay really pops out!
mb911 |
Jul 18 2018, 05:04 PM
Everyday I look to see what color it will be..
Chris H. |
Jul 18 2018, 05:41 PM
Senior Member Group: Members Posts: 4,048 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Jul 18 2018, 05:43 PM
I’ve known for a couple years. Sworn to secrecy. (IMG:style_emoticons/default/shades.gif)
76-914 |
Jul 18 2018, 05:47 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I like the pic of it in black! But then again I would say that. (IMG:style_emoticons/default/biggrin.gif)
mb911 |
Jul 18 2018, 07:15 PM
I knew at one time as Michael told me but I forget.. |
Blue6 |
Jul 18 2018, 07:34 PM
Senior Member Group: Members Posts: 1,050 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
I also know, or I used to. I’m old and probably forgot. Even if I remembered, I wouldnt say. Despite what Scotty says, Michael is a nice guy. He’s been through a lot and deserves the great unveil...Very soooooon...
Cairo94507 |
Jul 18 2018, 09:47 PM
Thanks guys. I appreciate the support. Though I may occasionally slip and make a negative comment, I try to keep it positive but still let others know to beware. Given the situation (IMG:style_emoticons/default/sheeplove.gif) I have had to deal with, I hope I am forgiven for occasionally getting upset.
I have easily over 100 photos of my car as it was when I picked it up at Scott's, before Kent did a thing to it except put it on a rotisserie. As everyone now knows, I have been trying to get some kind of refund from Scott and consequently have been reluctant to show all of the damage to my chassis as I try to resolve that situation. However, as it seems that train has likely left the station, I may end up posting those pictures so all can see how bad the work actually was. I would have rather posted those comments and ultimately the pictures I have in the other thread I started that was locked in short order, but that is now not possible. I understand why the thread was locked, but I have seen threads where others have complained about other vendors non-stop and those threads do not get locked. I understand the responses to my comments were out there and frankly unprofessional, but I hoped they would address that person directly and not foreclose my ability to air this issue and alert others to the practices I suffered. BTW, I thought the rapid replies were proof in and of themselves that there were issues. (IMG:style_emoticons/default/beerchug.gif) |
Lucky9146 |
Jul 18 2018, 11:32 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,663 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Thanks guys. I appreciate the support. Though I may occasionally slip and make a negative comment, I try to keep it positive but still let others know to beware. Given the situation (IMG:style_emoticons/default/sheeplove.gif) I have had to deal with, I hope I am forgiven for occasionally getting upset. I have easily over 100 photos of my car as it was when I picked it up at Scott's, before Kent did a thing to it except put it on a rotisserie. As everyone now knows, I have been trying to get some kind of refund from Scott and consequently have been reluctant to show all of the damage to my chassis as I try to resolve that situation. However, as it seems that train has likely left the station, I may end up posting those pictures so all can see how bad the work actually was. I would have rather posted those comments and ultimately the pictures I have in the other thread I started that was locked in short order, but that is now not possible. I understand why the thread was locked, but I have seen threads where others have complained about other vendors non-stop and those threads do not get locked. I understand the responses to my comments were out there and frankly unprofessional, but I hoped they would address that person directly and not foreclose my ability to air this issue and alert others to the practices I suffered. BTW, I thought the rapid replies were proof in and of themselves that there were issues. (IMG:style_emoticons/default/beerchug.gif) Have read it all, please let it go. Don't let it get you down, move on. I think you believe you are trying to warn others, which sounds noble, but it is not coming across that way, unfortunately. Others have said it, it is not your job to save the world, no matter how well meaning you are. Let it go. You have the car where it will ultimately be what you wanted. Enjoy and I hope to see it and meet you one day. It is a lot more fun to watch everyone tease you about the color. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
porschetub |
Jul 19 2018, 12:47 AM
Advanced Member Group: Members Posts: 4,729 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
So Scott has now commented on my Dorkiphus thread, https://dorkiphus.net/porsche/showthread.php?t=38913 and accused me of libel, slander and defamation..... By the way, the truth is an absolute defense to all 3. Oh dear,I could see this was going to happen,not interested as it should really not be on here,keep it within yourselves guys,have issues with the PO on my car but lifes too short and can't be bothered viewing it. |
porschetub |
Jul 19 2018, 12:53 AM
Thanks guys. I appreciate the support. Though I may occasionally slip and make a negative comment, I try to keep it positive but still let others know to beware. Given the situation (IMG:style_emoticons/default/sheeplove.gif) I have had to deal with, I hope I am forgiven for occasionally getting upset. I have easily over 100 photos of my car as it was when I picked it up at Scott's, before Kent did a thing to it except put it on a rotisserie. As everyone now knows, I have been trying to get some kind of refund from Scott and consequently have been reluctant to show all of the damage to my chassis as I try to resolve that situation. However, as it seems that train has likely left the station, I may end up posting those pictures so all can see how bad the work actually was. I would have rather posted those comments and ultimately the pictures I have in the other thread I started that was locked in short order, but that is now not possible. I understand why the thread was locked, but I have seen threads where others have complained about other vendors non-stop and those threads do not get locked. I understand the responses to my comments were out there and frankly unprofessional, but I hoped they would address that person directly and not foreclose my ability to air this issue and alert others to the practices I suffered. BTW, I thought the rapid replies were proof in and of themselves that there were issues. (IMG:style_emoticons/default/beerchug.gif) Have read it all, please let it go. Don't let it get you down, move on. I think you believe you are trying to warn others, which sounds noble, but it is not coming across that way, unfortunately. Others have said it, it is not your job to save the world, no matter how well meaning you are. Let it go. You have the car where it will ultimately be what you wanted. Enjoy and I hope to see it and meet you one day. It is a lot more fun to watch everyone tease you about the color. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) Well done Jim ,golden reply (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
EdwardBlume |
Jul 19 2018, 01:33 AM
Get the car finished and enjoy it!
Your car's progression has been glorious to watch. I hope the time, efforts, and cost will have been worth it in the end. |
Lo-Fi Version | Time is now: 27th November 2024 - 06:33 AM |
