New GB Tail light lenses US and Euro $195 a set with seals !, Who's in? |
Mikey914 |
Aug 10 2017, 12:14 AM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
US and Euro lenses $195 a set. Same price
These are multi port injected lenses. What does that mean? THEY ARE NOT GLUED TOGETHER !! Yes, they will not crack apart or have ridges like others we have seen. The price includes the right and left lenses with the lens to housing seals. The self adhesive housing to body seals will be 1/2 off if you wan them. The only drawback with this method of injection is that on the edges the hot resin melts the previously injected resin, so the edges are not a prefect line. You can see this on the edge of the clear easiest. The edges do stick out a little further we are reworking these right now to minimize this. Pictures to follow. Here's the ones Matt just fitted to his car. Attached thumbnail(s) |
falcor75 |
Aug 10 2017, 02:36 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Shut up and take my Money! (again for the 20th or so time) (IMG:style_emoticons/default/smile.gif)
I'm in for one pair of Euro style lenses, no seals needed as I've already changed those on my housings. |
mb911 |
Aug 10 2017, 05:38 AM
914 Guru Group: Members Posts: 7,385 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Euros please.
restore2seater |
Aug 10 2017, 07:10 AM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
Put me down for U. S. set.
914-300Hemi |
Aug 10 2017, 07:29 AM
Senior Member Group: Members Posts: 1,373 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Please put me down for a euro set.
DRPHIL914 |
Aug 10 2017, 07:31 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
one set for me please- euro set I think - I have euros on the front so might as well match.
jmitro |
Aug 10 2017, 08:08 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I'm in for a Euro set with housing to body seals.
Optimusglen |
Aug 10 2017, 08:21 AM
Senior Member Group: Members Posts: 921 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
Oh man, these look great. I wish I could justify the expense when I have two adequate sets of lenses already and a 6 engine that needs money and time.
Jett |
Aug 10 2017, 08:25 AM
Senior Member Group: Members Posts: 1,674 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Mark, can you make a French set?
markhoward |
Aug 10 2017, 09:42 AM
Member Group: Members Posts: 385 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
I'm down for a Euro set..
flmont |
Aug 10 2017, 10:01 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
1 Euro set pls...
Mikey914 |
Aug 10 2017, 10:11 AM
walterolin |
Aug 11 2017, 09:27 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
One set - US.
HIPPIEKILLER |
Aug 11 2017, 11:28 PM
Member Group: Members Posts: 84 Joined: 25-July 17 From: Huntington Beach, CA Member No.: 21,286 Region Association: Southern California |
Mikey914 |
Aug 11 2017, 11:34 PM
Mark, can you make a French set? Not real happy with the way the "fremch" turned out so for now no I'm in for European lenses also. What are the particularities of French ones?? Color is more grey, and not consistent |
Wyvern |
Aug 11 2017, 11:39 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
They look great.
I cant see the issue you talk about with the heating / melting ... Is this something that will be fixed and or is it something that can be "cleaned" up by a sharp knife or file ? |
colingreene |
Aug 11 2017, 11:41 PM
Senior Member Group: Members Posts: 732 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I actually think the seal material you use for the tail lights is to hard, mine dont seal because of it.
the factory seals are much softer. |
Mikey914 |
Aug 11 2017, 11:47 PM
It's actually an imperfection in design. Will require retooling. A section is slightly too large and makes it sit a little farther out. Honestly I think the AA ones do this too.
I'm just telling you. You can make the decision. If you are a CW and have OCD, I'd say wait another year when it's revisited. I can say they will be more expensive. You have a good daily driver to a driving restoration you'll benefit from lenses that will not break apart and are actually smooth. It's not lithe casual observer could tell. And with the extra seal we are including it will help Keep water out. Mark |
Mikey914 |
Aug 11 2017, 11:50 PM
I actually think the seal material you use for the tail lights is to hard, mine dont seal because of it. the factory seals are much softer. The material we used is closed cell foam instead of sponge. Yes harder, but not holding water in. It's a trade off. Ours are easier to install in that the self adhesive backing holds it on the housing. It's really easy to have it fold over on itself without (same with the OEM) Does help with installation. |
PanelBilly |
Aug 12 2017, 09:11 AM
914 Guru Group: Members Posts: 5,865 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Mark, can you make a French set? Not real happy with the way the "fremch" turned out so for now no I'm in for European lenses also. What are the particularities of French ones?? Color is more grey, and not consistent I thought they just smelled bad |
Lo-Fi Version | Time is now: 2nd January 2025 - 09:48 PM |
