Removing the air control slider mechanism, Is there a secret, or step-by-step? |
DRPHIL914 |
Aug 14 2017, 08:41 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
My airbox controller has not worked since I bought the car almost 8 year ago- has not ever been a priority but like a week ago when I got caught in the rain and the window fogged up, no air flow- its a pain-
- it shorts out and blows fuse when on any setting than the middle one- there is a bad spot on the board near slider connectors looks like it got hot and meldedthe surrounding plastic, found one that looks like new, yes ive tested the airbox its self in fact I have 3 of them and they all respond same to this mechanism- I want to get this pulled and replaced with another unit before Okteenerfest next month. - ssssoooo- I know partly how its connected, so thenext step I guess is to disconnect the cables from the boxes, then just pull them thru the wall? anyway if there is any other specifics please let me know. Dr. Phil. |
Matty900 |
Aug 14 2017, 11:27 AM
Senior Member Group: Members Posts: 1,284 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Unclip the wires from mixing boxes and blower housing
Attached thumbnail(s) |
Matty900 |
Aug 14 2017, 12:09 PM
Here
Matty900 |
Aug 14 2017, 12:15 PM
Had a hard time uploading pictures for you so here's a collage of them
Matty900 |
Aug 14 2017, 12:16 PM
Clean all of your contacts and make sure your wires are intact
DRPHIL914 |
Aug 14 2017, 12:50 PM
awesome thanks!
DRPHIL914 |
awesome thanks!
billh1963 |
Aug 14 2017, 01:11 PM
Car Hoarder! Group: Members Posts: 3,405 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
You buy that new valance, yet?
DRPHIL914 |
Aug 14 2017, 01:41 PM
billh1963 |
Aug 14 2017, 01:52 PM
Matty900 |
Aug 14 2017, 03:52 PM
This will be more helpful
Matty900 |
Aug 14 2017, 04:08 PM
rgalla9146 |
Aug 14 2017, 06:08 PM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
There is a 6mm bolt at the back of the control assembly that has to be removed.
Also gently pry the chrome bezel off first. Before reassembly, straighten each control wire and lube each thoroughly with light oil while working the wire back and forth. Check that the bulbs in the area all work. Each wire is adjustable for full travel. Be prepared, this is not a fun job. |
falcor75 |
Aug 14 2017, 11:34 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
It helps if you take the passenger seat out and put a few folded up towels or thin mattress on the car floor so you can lay on your back inside the car and work under the dash.
Lo-Fi Version | Time is now: 2nd January 2025 - 11:55 AM |
