29 Pages V « < 8 9 10 11 12 > »
> Tony's Subaru Conversion Thread
lapuwali
post Nov 2 2005, 06:01 PM
Post #181
Not another one!
The hardest part about a dry sump is the tank, and you can buy those. The rest is simply a matter of adding a second oil pump (can be a belt-driven external unit) that pulls oil out of the much-shortened "sump" and pumps it into the tank. The drain for the tank then feeds into the pressure pump. There are external pump assemblies available that supply both the scavenge and pressure pumps in one housing, and you simply remove the stock oil pump.
TonyAKAVW
post Nov 4 2005, 01:45 AM
Post #182
That's my ride.
I decided to use the messed up radiator for making measurements and building a frame.
TonyAKAVW
post Nov 4 2005, 01:47 AM
Post #183
That's my ride.
Here's the frame. Its made from 1 inch wide angle stock, held together for now with screws. Eventually it will be welded together.
TonyAKAVW
post Nov 4 2005, 01:53 AM
Post #184
That's my ride.
Here are the side pieces taped into place for fitting. The top piece is a much more challenging part and I still need to figure out a way to cut it to the correct shape.
jsteele22
post Nov 4 2005, 11:22 AM
Post #185
QUOTE (TonyAKAVW @ Nov 2 2005, 04:32 PM)
Here's the bottom of the engine looking inside. The crank is above the top of the oil pan considerably.
Wow, great shot. I nominate you for the 914club Annie Liebowitz prize.
I had been trying to picture what that area looked like, and I was sure that something would protrude down into the sump (besides the pickup tube.)
Tony, is that windage tray you show a stock part of the Suby engine ? (If a little piece of stamped sheet metal makes that big a difference, WTH doesn't every car come with one ?)
So, I know its crazy, but Mike's other thread has gotten me all worked up about a dry sump system. Sort of a hypochondriac's version of DWD.
TonyAKAVW
post Nov 4 2005, 12:39 PM
Post #186
That's my ride.
Thanks!
Yes, the windage tray is part of the stock Subaru engine. The type IV has a similar plate, so I don't know which engines have them and don't. Seems like a pretty inexpensive item.
And yes, that dry sump idea sounds really cool. I'm definitely interested in that, but I think for the time being I will go with a modified oil pan. If I start taking on new projects like that I'm never going to get this car on the road.
Something interesting I found out when placing the radiator is that if you mount the radiator to one side of the engine bay, there would be plenty of room on the other side for one of those large oil sump tanks!
-Tony
Goge
post Nov 4 2005, 01:04 PM
Post #187
Hey Tony-
I decided I'd quit lurking and finally post something...
Would that rad fit in there if the lower sheet metal weren't cut away? It doesn't really look like it but I can't quite tell. Just curious.
I'd like to do this dance eventually myself, but would like to keep cutting to a min... I don't think I could carve up my car very much and still sleep at night. But if i could get away with a few mounting holes for the motor mount and the rad, I might be able to catch a few winks without too much guilt.
Thanks for answering a couple questions via e-mail the other day, too!!
Keep up the good work there, I'm living vicariously through you! (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
-Todd
airsix
post Nov 4 2005, 05:06 PM
Post #188
I have bees in my epiglotis
QUOTE (Goge @ Nov 4 2005, 11:04 AM)
Todd, I used to feel that way too, but you get numb to it eventually. I can dive in with an air-chisel or other instrument of mass destruction now without even giving it a second thought. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
-Ben M.
Goge
post Nov 5 2005, 12:35 AM
Post #189
Ben-
You're certainly correct. I could maintain my (unperfect, underpowered) '72 in all it's debatably stock glory, and get hit by a Hyundai next week. Or, I could do a little choppin' and multiply horses by about 2 (holy crap!!!!) and work on putting in a Soob motor. And I think that would be more fun to drive (even if the Hyundai still mowed me down later on, at least I'd have had the fun).
I had better quit posting, because I'm at least a year away from undertaking this... and it's Tony's thread.
But I'm taking baby steps, fixing rusty areas over the winter. I was pleasantly surprised when I finally took off the outer rocker after owning this thing for 10 years! Not bad! This was taken just after I took it off, only a little surface rust. And a lotta dirt. And a hazelnut fell out, too (a 'filbert' if you live around here....)
Have at it, Tony. We're watching...
CptTripps
post Nov 6 2005, 07:57 AM
Post #190
:: Punch and Pie ::
I've got a Vespa to do this winter, but I'm thinking *NEXT* year I'm going to drop a Soob in mine too...
Something about 200hp, and getting to keep both trunks. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
TonyAKAVW
post Nov 6 2005, 10:41 PM
Post #191
That's my ride.
Made a little progress this weekend... My main project this weekend was replacing the front pads and rotors, as well as an oil change on my wife's TT.
The remaining piece of radiator shroud was cut today and installed. All that is left now for the radiator frame is some bracketry for suspending the radiator itself. This too will be made from angle-stock. Once this is all complete I should have measurements and drawings up for others to duplicate.
Another bit of good news, is that the infamous alternator bracket I made is out for reproduction, so hopefully there will be some even slicker custom alternator brackets coming out soon.
-Tony
Aaron Cox
post Nov 6 2005, 10:43 PM
Post #192
Professional Lawn Dart
tony. your sheet metal work rocks!
can i pay you to make an oil cooler shroud for me? (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
TonyAKAVW
post Nov 6 2005, 10:45 PM
Post #193
That's my ride.
The top piece was made in an interesting way...I needed the shape of the tin to conform to the indent on the firewall between the two seats. I put the radiator frame in place and then applied masking tape to the wall and then sprayed some expanding foam into the gap. This provided a pretty good template for tracing out the top piece. Unfortunately it wasn't perfect and I had a bit of filing to do to get it right. Its pretty decent but there are some small gaps still.
This picture is of the foam block (ecased in masking tape) ready to trace out onto the aluminum sheet.
-Tonyi
TonyAKAVW
post Nov 6 2005, 10:49 PM
Post #194
That's my ride.
My sheetmetal work is only awesome in the 640 by 480 resolution (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I did this with a $12 nibbling tool from Radio Shack, a pair of tin snips, and a fairly small bench vice. If you want a shroud, bring your car by some weekend and we can make one. Should be pretty easy.
-Tony
Aaron Cox
post Nov 6 2005, 10:59 PM
Post #195
QUOTE (TonyAKAVW @ Nov 6 2005, 09:49 PM)
-Tony
you got it man. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
phantom914
post Nov 6 2005, 11:01 PM
Post #196
non-914-owner non-club member
QUOTE (Aaron Cox @ Nov 6 2005, 08:59 PM)
-Tony
Tony accepts only frozen pizzas as payment. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Andrew
Aaron Cox
post Nov 6 2005, 11:06 PM
Post #197
i thought you had to have a 914 to post here (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
hey andrew (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)
bondo
post Nov 6 2005, 11:44 PM
Post #198
QUOTE (phantom914 @ Nov 6 2005, 10:01 PM)
Andrew
Hahahaha! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif)
TonyAKAVW
post Nov 14 2005, 01:26 AM
Post #199
That's my ride.
Okay, some progress on the radiator shroud. Lots of minor improvements and little tricks to this...
Here's what it looks like now. On the sides are adjustable angle pieces that keep the air from shooting out to the side of the radiator. They are adjustable so that I can tighten them to whatever radiator goes in (the replacement for my crappy ne may be very slightly different) and I can account for any skew as well...
There are also mounts now for the top and bottom of the radiator to hold it in place.
More details below...
-Tony
TonyAKAVW
post Nov 14 2005, 01:29 AM
Post #200
That's my ride.
At the bottom of the frame are two legs that stick out, and they have holes drilled in them to accept the peg that sticks out from the bottom of the radiator. I bought some rubber grommets and some foam rubber gaskets at Industrial Liquidators for isolation dampening.
- Lo-Fi Version Time is now: 19th April 2025 - 05:45 PM
