Replacing front Upper Strut Bushing, What's the trick? |
BeatNavy |
Sep 17 2017, 10:45 AM
So, how does one remove and then reinstall the rubber bushing from the supporting mount? I have a press, but I'm scratching my head about how best to tackle this. Can't seem to find any relevant threads on this topic...
BeatNavy |
Sep 17 2017, 11:59 AM
Well, my teenage daughter figured out that the new bushings split apart. So that's at least a clue. But need to figger' out best way to get old out.
BeatNavy |
Sep 17 2017, 01:13 PM
Press. Made short work out of the original bushing. Pressed down from the top and it eventually shot out of there. The original bushing is one solid piece of rubber.
Geez, where is everybody. Must be an event going on somewhere... (IMG:style_emoticons/default/confused24.gif) |
mlindner |
Sep 18 2017, 06:04 AM
Senior Member Group: Members Posts: 1,512 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Good morning BeatNavy, Yup your press did the job....I cut the top rubber off then popped it out. And you daughter is correct, new ones come in two parts. Congrats. Best, Mark
Mikey914 |
Oct 11 2017, 11:51 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Any pics?
BeatNavy |
Oct 12 2017, 06:56 AM
Any pics? Why yes, I'm glad you asked. Allow me to share: Arrived in package from some very reputable vendor. Comparison of old and new. The new one does not have the cup for (or formed from) the strut lock washer: After pressing out the old, the new ones were easily installed as they are actually two pieces and fit very nicely. A press helps, but removal and installation could probably be done with a vice. After cleaning up the mounts a bit, they look like so: These came off my project car. I have not installed yet on my daily driver, as I am pretty sure the suspension geometry is going to change as a result of installing these. Last weekend I installed turbo tie rods, and so an alignment is in order anyway. May be a good time to road test these then. I did fit them over my old struts, and they do fit like a glove (IMG:style_emoticons/default/beer.gif) |
MikeM |
Oct 12 2017, 08:45 AM
Senior Member Group: Members Posts: 558 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi...are those from 914 Rubber?
I don't see them on the website. Thanks. |
BeatNavy |
Oct 12 2017, 09:10 AM
Hi...are those from 914 Rubber? I don't see them on the website. Thanks. I believe these are in pre-production. The yellow ones you see here are a prototype, but they will be black. Before I let cat out of proverbial bag any further or say something that's not correct, I'll defer to Mark when he has a chance. |
Mikey914 |
Oct 12 2017, 02:13 PM
Yes these are our pre production ones. Matt fitted on his car, but because they were yellow didn't leave on. These are polygraphite and the only material i could get to do a trial run quickly was yellow. Decided to sent the other set out to solicit some response. And double check part.
These are a part that many people need and we will be able to provide to the market at a very reasonable price. Most cars do need these, but they can be a pain to replace, until now. |
Mikey914 |
Oct 12 2017, 02:18 PM
As far as design, we basically split the bushing and made a very tight tolerance for between the parts. It will function as one once assembled.
The polygraphite was another way for us to up the density of the part while maintaining the qualities desired form the rubber. These should produce a notable improvement over the old ones. |
MikeM |
Oct 12 2017, 03:56 PM
OK thanks!! I'll stand by until they are ready to go...
HalfMoon |
Oct 13 2017, 07:58 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I'm ready to buy em!
Please post a note when they are ready for shipment? David |
HalfMoon |
Oct 13 2017, 07:59 AM
Oh, and for those who don't have a press (and I'm going Dr. Evil here), burn em out?
Oct 13 2017, 08:06 AM
BeatNavy |
Oct 13 2017, 08:19 AM
Oh, and for those who don't have a press (and I'm going Dr. Evil here), burn em out? Go to someone who has one. Takes 2 minutes. A vice MIGHT work, but you'd probably need a cheater bar. With the press it was out PDQ and with some velocity, too. Mark, I actually like the yellow. Kind of makes the suspension, you know, "pop." (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
Oct 13 2017, 10:43 PM
Large bench vide and a socket can work, if you are really ghetto you can drill the rubber out around the center sleeve and tap it through with a hammer, it will pop out....not that I ever had to do it once this way .... (IMG:style_emoticons/default/sunglasses.gif)
somd914 |
Oct 14 2017, 05:40 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Torch does the trick, just make sure you do it when your neighbors are out back grilling - burned rubber always trumps a grilling steak (IMG:style_emoticons/default/biggrin.gif)
worn |
Oct 14 2017, 09:49 AM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So, how does one remove and then reinstall the rubber bushing from the supporting mount? I have a press, but I'm scratching my head about how best to tackle this. Can't seem to find any relevant threads on this topic... Another way of getting them out is using soap and a big screw driver. The screw driver is pushed in between the rubber and the metal and used to lever the rubber out. The press is a much better idea, and for those without a press the assembly will fit in a vise in lieu of the press. |
Oct 14 2017, 01:14 PM
I’m ready to buy the kit. Front and back. (IMG:style_emoticons/default/biggrin.gif)
Actually will need a couple kits. Thanks! |
jmitro |
Oct 15 2017, 08:21 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I bought the polygraphite upper strut mounts from another vendor last week before I knew 914 rubber was offering them.
Inner half seems to seat completely; outer (top) half doesn't completely seat up against the steel cup. I wonder if it's supposed to be this way? There is about 3-4mm of space between the mount and the steel cup. are you getting complete seating of this mount from 914 rubber? |
Lo-Fi Version | Time is now: 26th April 2024 - 03:33 AM |
