| Lucky9146 |
Sep 26 2017, 03:27 PM
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California
Stock 914 4 and 6 CV bolts are 12 point triple square allen, so you need to clean them off and get a close look. If you use a 6 point allen you'll strip them. I clean them really good and tap them in the socket before leaning on them. If you don't seat it in the socket, you can strip it. This is what came with mine. Trans was out so assuming these are correct? ![]() |
| Lucky9146 |
Sep 26 2017, 03:29 PM
8mm =31 ft/lb 10mm =55 ft/lb It's a special hardness bolt. High tensile 12.9 from memory,I snuck mine up to 32ft/lbs ,they can take it no problem. Make sure the joining faces are nice and clean,I didn't use gaskets as I didn't have them ...ok so far. I don't have gaskets and was suppose to get them today but have not heard from the guy. Anybody else run without gaskets? Essential or not? |
| IronHillRestorations |
Sep 26 2017, 04:19 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,897 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
8mm =31 ft/lb 10mm =55 ft/lb It's a special hardness bolt. High tensile 12.9 from memory,I snuck mine up to 32ft/lbs ,they can take it no problem. Make sure the joining faces are nice and clean,I didn't use gaskets as I didn't have them ...ok so far. I don't have gaskets and was suppose to get them today but have not heard from the guy. Anybody else run without gaskets? Essential or not? by request here's my .02 You definitely need gaskets. No gasket will mean grease everywhere. I"ve never put them in without, ever. Make sure that the gasket is seated in it's recess before you start tightening the bolts. The bolts you've shown look serviceable, but the pic is slightly blurry, just make sure the points are nice and crisp and nothing is rounded out. Always use new schnoor washers, they are a one and done piece, so always get at least twice what you need in the event you've got to take them off. There is a high quality re-useable locking fastener that later 911 guys are using, but they are over $10 each, but I've never had one in my hand. Stage8 makes some with a retainer and snap ring, but I'd only go to that trouble or safety wiring for a race car. What I do is put it all together finger tight, without the schnoor washers, and then individually take off each bolt, clean it and the threaded holes, put the washer on and barely snug it until I get all 4 done that way. I like to incrementally tighten them up in a crosswise pattern, until you get to the 31ft lb (min) spec. I think Sir Eric goes with 35 ft lb, 4 more ft lb isn't going to snap those 12.8 bolts. Guys have gone to great lengths to make sure the bolts stay put, including loctite, drilling and safety wire, but I've had no problems when I've done it like this. |
| porschetub |
Sep 26 2017, 09:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,975 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
8mm =31 ft/lb 10mm =55 ft/lb It's a special hardness bolt. High tensile 12.9 from memory,I snuck mine up to 32ft/lbs ,they can take it no problem. Make sure the joining faces are nice and clean,I didn't use gaskets as I didn't have them ...ok so far. I don't have gaskets and was suppose to get them today but have not heard from the guy. Anybody else run without gaskets? Essential or not? Never used them as mentioned,if the face's are clean,how the hell is grease getting out of there,735kms of illegal driving since conversion and no grease coming out anywhere (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) . |
| jfort |
Oct 18 2017, 08:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,187 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
I had trouble getting the Schnorr CV joint bolt washers from Pelican who referred me to McMaster-Carr. The information is in the picture.
| 11tenths |
Oct 18 2017, 10:17 AM
Ve get too soon old, und too late schmart ![]() ![]() Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States
When I removed my CVs I found the PO had used some type of sealant like RTV instead of gaskets and they hadn't leaked.
I cleaned eveything and reassembled with gaskets; we'll see who was smarter. ![]() re: Schnoor washers- Which way is the correct orientation- pointing towards the bolt head or away? (IMG:style_emoticons/default/idea.gif) - Harry |
| Dr Evil |
Oct 18 2017, 10:59 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
My $0.02
I don't use gaskets anymore and haven't for years. Gaskets are mooshy and change tq value over time. Every spring I remember threads from people who had a lost shaft beat the hell out of the underside of their car. Back in 2004 through about 2007-8 I was making drilled bolts, 12.9 hardness, 6mm allen. You likely have a set of mine, I could tell if I saw them (IMG:style_emoticons/default/wink.gif) I safety wire the bolts now, and I make sure the surface is clean at the joint and I run a bead of RTV around the joint. Let it dry and its good to go. I have personally never had an issue with this, and I know of many who have done it this way and have never had an issue. YMMV. |
| altitude411 |
Oct 18 2017, 11:11 AM
I drove my 6 into a tree ![]() ![]() ![]() Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains
re: Schnoor washers- Which way is the correct orientation- pointing towards the bolt head or away? (IMG:style_emoticons/default/idea.gif) - Harry The convex towards the bolt head. http://forums.pelicanparts.com/porsche-911...ay-they-go.html |
| rjames |
Oct 18 2017, 01:36 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,414 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
My $0.02 I don't use gaskets anymore and haven't for years. Gaskets are mooshy and change tq value over time. Every spring I remember threads from people who had a lost shaft beat the hell out of the underside of their car. Back in 2004 through about 2007-8 I was making drilled bolts, 12.9 hardness, 6mm allen. You likely have a set of mine, I could tell if I saw them (IMG:style_emoticons/default/wink.gif) I safety wire the bolts now, and I make sure the surface is clean at the joint and I run a bead of RTV around the joint. Let it dry and its good to go. I have personally never had an issue with this, and I know of many who have done it this way and have never had an issue. YMMV. Ditto. (IMG:style_emoticons/default/agree.gif) |
| Andyrew |
Oct 18 2017, 02:38 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I havent used a gasket in years either. I dont even use RTV and I dont think I've seen any grease loss.
| jfort |
Dec 6 2017, 12:42 PM
posted to the wrong thread. sorry. see engine build thread
| Mark Henry |
Dec 6 2017, 02:04 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
What's the plan wheels, brakes, etc?
Are you going 5 bolt? |
Lo-Fi Version | Time is now: 14th December 2025 - 05:06 AM |
