913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
please PM code for the block.
thanks |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Thanks we have found that for some reason URLs will move in the Godaddy website, this is the current link and as of now it working.
http://shop.914rubber.com/Battery-block-po...m?categoryId=-1 Also, I noticed that we made a mistake and didn't have the option to add the hardware active, It now is. So I asked Topher to contact all to see if they did want it so you didn't mis out if you did. Sorry about that. Thanks to all for the support. Mark |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Just bought and paid thanks
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Thanks we have found that for some reason URLs will move in the Godaddy website, this is the current link and as of now it working. http://shop.914rubber.com/Battery-block-po...m?categoryId=-1 Also, I noticed that we made a mistake and didn't have the option to add the hardware active, It now is. So I asked Topher to contact all to see if they did want it so you didn't mis out if you did. Sorry about that. Thanks to all for the support. Mark Mark- can you add a new link for the mirror glass. I ordered the battery block but can't get the group buy price for the glass. Link you pm'd me says unavailable |
Mikey914 |
The link
http://shop.914rubber.com/Mirror-glass-ear...m?categoryId=-1 Showing the code active for the Blocks, dropped you a PM and I can get this squared away for ya. Mark |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Dang it, I just ordered (and received) a 914 Rubber shipment.
I could use one of these too!!!!! |
Mikey914 |
These do ship very inexpensively. (IMG:style_emoticons/default/biggrin.gif)
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Mark,
1. I can't seem to find the hardware option for the terminal square block on your website. The square block description indicates one must select the hardware option, but no option appears. 2. I received your PM with the group buy codes, but how does one make an order with several group buy items and then apply multiple GB codes? Or do we make several individual orders and hope you combine them and hope you give us the best shipping charge? I wish to order mirror glass, terminal square block with hardware, and the shift linkage bushing kit with rear console cover and locking band. Thank you. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Mark, 1. I can't seem to find the hardware option for the terminal square block on your website. The square block description indicates one must select the hardware option, but no option appears. 2. I received your PM with the group buy codes, but how does one make an order with several group buy items and then apply multiple GB codes? Or do we make several individual orders and hope you combine them and hope you give us the best shipping charge? I wish to order mirror glass, terminal square block with hardware, and the shift linkage bushing kit with rear console cover and locking band. Thank you. Hmm. It worked for me. I had to click the check box for the hardware option, and then select to add the hardware from the drop down box. (IMG:style_emoticons/default/confused24.gif) Just got notice that it shipped. |
mb911 |
Shoot didn't realize there was a hardware selection spot..
Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,623 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
Please send the GB code PM
Also for transmission cover too Thanks |
Mikey914 |
Mark, 1. I can't seem to find the hardware option for the terminal square block on your website. The square block description indicates one must select the hardware option, but no option appears. 2. I received your PM with the group buy codes, but how does one make an order with several group buy items and then apply multiple GB codes? Or do we make several individual orders and hope you combine them and hope you give us the best shipping charge? I wish to order mirror glass, terminal square block with hardware, and the shift linkage bushing kit with rear console cover and locking band. Thank you. I have these listed in the group buy section as well as electrical and think they are in the hardware section. These codes have been set up to be combinable. You will need to enter one code then the next, and the next. It will apply to multiples as well as singles. And if you have any problems use print and call to save and drop me a PM. Should all work as planned as I've seen these come through and did test it. |
maf914 |
Mark, 1. I can't seem to find the hardware option for the terminal square block on your website. The square block description indicates one must select the hardware option, but no option appears. 2. I received your PM with the group buy codes, but how does one make an order with several group buy items and then apply multiple GB codes? Or do we make several individual orders and hope you combine them and hope you give us the best shipping charge? I wish to order mirror glass, terminal square block with hardware, and the shift linkage bushing kit with rear console cover and locking band. Thank you. I have these listed in the group buy section as well as electrical and think they are in the hardware section. These codes have been set up to be combinable. You will need to enter one code then the next, and the next. It will apply to multiples as well as singles. And if you have any problems use print and call to save and drop me a PM. Should all work as planned as I've seen these come through and did test it. Mark, Thank you. Order placed. I am a dummy. (IMG:style_emoticons/default/laugh.gif) The hardware option for the terminal block was in front of me all of the time. And it simply did not occur to me that I could use multiple GB codes in a single order. (IMG:style_emoticons/default/rolleyes.gif) |
anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,667 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
Mark,
I'm in for a positive battery cable + square block and hardware if/when you start making cables. BTW, any idea of gauge on the main cable? TIA, Steve A- |
Lo-Fi Version | Time is now: 26th June 2024 - 03:33 AM |
